- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.0
- * $Revision: 2 $
- * $Date: 15/02/06 10:22a $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Perform A/D Conversion with ADC single cycle scan mode.
- * @note
- * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M058S.h"
- #define PLL_CLOCK 50000000
- /* Define Function Prototypes */
- void SYS_Init(void);
- void UART0_Init(void);
- void AdcSingleCycleScanModeTest(void);
- /* Init System Clock */
- /* Enable Internal RC 22.1184 MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for Internal RC clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable external XTAL 12 MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for external XTAL clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Enable ADC module clock */
- CLK_EnableModuleClock(ADC_MODULE);
- /* Select UART module clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
- /* ADC clock source is 22.1184 MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
- CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
- /* Init I/O Multi-function */
- /* Set P3 multi-function pins for UART0 RXD and TXD */
- SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
- SYS->P3_MFP |= SYS_MFP_P30_RXD | SYS_MFP_P31_TXD;
- /* Disable the P1.0 - P1.3 digital input path to avoid the leakage current */
- GPIO_DISABLE_DIGITAL_PATH(P1, 0xF);
- /* Configure the P1.0 - P1.3 ADC analog input pins */
- SYS->P1_MFP &= ~(SYS_MFP_P10_Msk | SYS_MFP_P11_Msk | SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
- SYS->P1_MFP |= SYS_MFP_P10_AIN0 | SYS_MFP_P11_AIN1 | SYS_MFP_P12_AIN2 | SYS_MFP_P13_AIN3 ;
- /* Init UART */
- void UART0_Init()
- /* Reset IP */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- /* Function: AdcSingleCycleScanModeTest */
- /* Parameters: */
- /* None. */
- /* Returns: */
- /* None. */
- /* Description: */
- /* ADC single cycle scan mode test. */
- void AdcSingleCycleScanModeTest()
- uint8_t u8Option;
- uint32_t u32ChannelCount;
- int32_t i32ConversionData;
- printf("\n");
- printf("+----------------------------------------------------------------------+\n");
- printf("| ADC single cycle scan mode sample code |\n");
- while(1)
- printf("\n\nSelect input mode:\n");
- printf(" [1] Single end input (channel 0, 1, 2 and 3)\n");
- printf(" [2] Differential input (input channel pair 0 and 1)\n");
- printf(" Other keys: exit single cycle scan mode test\n");
- u8Option = getchar();
- if(u8Option == '1')
- /* Set the ADC operation mode as single-cycle, input mode as single-end and
- enable the analog input channel 0, 1, 2 and 3 */
- ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_SINGLE_CYCLE, 0xF);
- /* Power on ADC module */
- ADC_POWER_ON(ADC);
- /* clear the A/D interrupt flag for safe */
- ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
- /* start A/D conversion */
- ADC_START_CONV(ADC);
- /* Wait conversion done */
- while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
- for(u32ChannelCount = 0; u32ChannelCount < 4; u32ChannelCount++)
- i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount);
- printf("Conversion result of channel %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
- else if(u8Option == '2')
- /* Set the ADC operation mode as single-cycle, input mode as differential and
- enable analog input channel 0 and 2 */
- ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_SINGLE_CYCLE, 0x5);
- for(u32ChannelCount = 0; u32ChannelCount < 2; u32ChannelCount++)
- i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount * 2);
- printf("Conversion result of differential input pair %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
- else
- return ;
- /* MAIN function */
- int main(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- /* SAMPLE CODE */
- printf("\nSystem clock rate: %d Hz", SystemCoreClock);
- /* Single cycle scan mode test */
- AdcSingleCycleScanModeTest();
- /* Disable ADC module */
- ADC_Close(ADC);
- /* Disable ADC IP clock */
- CLK_DisableModuleClock(ADC_MODULE);
- /* Disable External Interrupt */
- NVIC_DisableIRQ(ADC_IRQn);
- printf("\nExit ADC sample code\n");
- while(1);
