看看这段
* @brief This function execute delay function.
* @param[in] us Delay time. The Max value is 2^24 / CPU Clock(MHz). Ex:
* 50MHz => 335544us, 48MHz => 349525us, 28MHz => 699050us ...
* @return None
* @Details Use the SysTick to generate the delay time and the UNIT is in us.
* The SysTick clock source is from HCLK, i.e the same as system core clock.
void CLK_SysTickDelay(uint32_t us)
SysTick->LOAD = us * CyclesPerUs;
SysTick->VAL = (0x00);
SysTick->CTRL = SysTick_CTRL_CLKSOURCE_Msk | SysTick_CTRL_ENABLE_Msk;
/* Waiting for down-count to zero */
while((SysTick->CTRL & SysTick_CTRL_COUNTFLAG_Msk) == 0);
SysTick->CTRL = 0;
