STM32固件库,Nand_if.c文件下的NAND_BuildLUT函数调试中出现问题,
即函数最后的那个do{}while ( pFreeBlock < MAX_PHY_BLOCKS_PER_ZONE );
循环中pFreeBlock 会导致LUT 数组溢出,但是我看了好久没明白这段代码的意思;
无从修改。
不知道有没有谁移植过这段程序,望指点一二。
* Function Name : NAND_BuildLUT
* Description : Build the look up table
* Input : None
* Output : None
* Return : Status
* !!!! NOTE : THIS ALGORITHM IS A SUBJECT OF PATENT FOR STMICROELECTRONICS !!!!!
static uint16_t NAND_BuildLUT (uint8_t ZoneNbr)
uint16_t pBadBlock, pCurrentBlock, pFreeBlock;
SPARE_AREA SpareArea;
1st step : Init.
/*Init the LUT (assume all blocks free) */
for (pCurrentBlock = 0 ; pCurrentBlock < MAX_PHY_BLOCKS_PER_ZONE ; pCurrentBlock++)
LUT[pCurrentBlock] = FREE_BLOCK; /* 12th bit is set to 1 */
/* Init Pointers */
pBadBlock = MAX_PHY_BLOCKS_PER_ZONE - 1;
pCurrentBlock = 0;
2nd step : locate used and bad blocks
while (pCurrentBlock < MAX_PHY_BLOCKS_PER_ZONE)
SpareArea = ReadSpareArea(pCurrentBlock * NAND_BLOCK_SIZE + (ZoneNbr * NAND_BLOCK_SIZE * MAX_PHY_BLOCKS_PER_ZONE));
if ((SpareArea.DataStatus == 0) || (SpareArea.BlockStatus == 0))
LUT[pBadBlock--] |= pCurrentBlock | (uint16_t)BAD_BLOCK ;
LUT[pCurrentBlock] &= (uint16_t)~FREE_BLOCK;
if (pBadBlock == MAX_LOG_BLOCKS_PER_ZONE)
return NAND_FAIL;
else if (SpareArea.LogicalIndex != 0xFFFF)
LUT[SpareArea.LogicalIndex & 0x3FF] |= pCurrentBlock | VALID_BLOCK | USED_BLOCK;
LUT[pCurrentBlock] &= (uint16_t)( ~FREE_BLOCK);
pCurrentBlock++ ;
printf("2nd step\r\n");
3rd step : locate Free Blocks by scanning the LUT already built partially
pFreeBlock = 0;
for (pCurrentBlock = 0 ; pCurrentBlock < MAX_PHY_BLOCKS_PER_ZONE ; pCurrentBlock++ )
if ( !(LUT[pCurrentBlock]& USED_BLOCK))
do
if (LUT[pFreeBlock] & FREE_BLOCK)
LUT [pCurrentBlock] |= pFreeBlock;
LUT [pFreeBlock] &= ~FREE_BLOCK;
break;
pFreeBlock++;
return NAND_OK;
