[STM8] STM8L152 ADC+DMA结果中第一个数据不知道干嘛的
3392|2
 楼主| liyancao001 发表于 2017-3-11 16:22 | 显示全部楼层 |阅读模式
我让单片机一直连续运行,转换6个通道,DMA中设置的数组长度是78,也就是转换13个循环后产生DMA中断。DMA把结果存到BUFFER[13][6]的数组中。
问题是BUFFER[0][0]数据与我6个通道的哪个数据都对应不上,而BUFFER[0][1]对应1通道,BUFFER[0][2]对应2通道。。。。BUFFER[1][0]对应6通道。BUFFER[1][1]对应1通道.。。。后面的也都能对应上。
这样有两个问题,一直对应上偏移了一位,理论应该是BUFFER[0][1]对应2通道,而现在是对应1通道。二是第一个数据跟哪个通道的数据都对应不上。。。。
下面附上代码:#define ADC1_DR_ADDRESS        ((uint16_t)0x5344)
#define BUFFER_SIZE            ((uint8_t) 0x4E)   //((uint8_t) 0x06)
#define BUFFER_ADDRESS          ( (uint32_t)(&Buffer))
void ADC1_Init(void)
  ADC1_GPIO_Config();                                    //ADO 端口设置
  CLK_PeripheralClockConfig(CLK_Peripheral_ADC1, ENABLE);    //时钟使能
  ADC_DeInit(ADC1);
  ADC_Init(ADC1,ADC_ConversionMode_Continuous,ADC_Resolution_12Bit,ADC_Prescaler_1);
  ADC_SamplingTimeConfig(ADC1, ADC_Group_SlowChannels,ADC_SamplingTime_384Cycles);
  ADC_VrefintCmd(DISABLE); //禁止内部电压基准源
  ADC_ChannelCmd(ADC1,ADC_Channel_11, ENABLE);      //温度 室温下一般AD值在1700-1800之间
  ADC_ChannelCmd(ADC1,ADC_Channel_12, ENABLE);
  ADC_ChannelCmd(ADC1,ADC_Channel_13, ENABLE);
  ADC_ChannelCmd(ADC1,ADC_Channel_14, ENABLE);
  ADC_ChannelCmd(ADC1,ADC_Channel_15, ENABLE);
  ADC_ChannelCmd(ADC1,ADC_Channel_16, ENABLE);
  ADC_DMACmd(ADC1, ENABLE);                                                             //ADC_DMA使能
  ADC_Cmd(ADC1,ENABLE);                                                               //ADC使能
void DMA1_Init(void)
  CLK_PeripheralClockConfig(CLK_Peripheral_DMA1, ENABLE);
  SYSCFG_REMAPDMAChannelConfig(REMAP_DMA1Channel_ADC1ToChannel0);
  DMA_GlobalDeInit();
  DMA_Init(DMA1_Channel0, BUFFER_ADDRESS,
           ADC1_DR_ADDRESS,
           BUFFER_SIZE,   //与AD通道相关
           DMA_DIR_PeripheralToMemory,
           DMA_Mode_Circular,
           DMA_MemoryIncMode_Inc,
           DMA_Priority_High,
           DMA_MemoryDataSize_HalfWord );
  DMA_Cmd(DMA1_Channel0, ENABLE);                                   //DMA Channel0 enable
  DMA_ITConfig(DMA1_Channel0, DMA_ITx_TC, ENABLE);                  // Enable DMA1 channel0 Transfer complete interrupt
  DMA_GlobalCmd(ENABLE);                                            //DMA enable
INTERRUPT_HANDLER(DMA1_CHANNEL0_1_IRQHandler,2)
  unsigned char i=0;
    IWDG_ReloadCounter();
//    DMA_GlobalCmd(DISABLE);                                            //DMA enable
    ADC_Cmd(ADC1,DISABLE);                                                               //ADC使能
    if(DMA_GetFlagStatus(DMA1_FLAG_TC0)!= RESET)
      if(AD_Finish_Flag==0)//必须在处理函数结束以后才能刷新数据。
        for(i=0;i<13;i++)
            sum0=Buffer[0];     //此值应对应通道AD11,但实际对应通道AD16
            sum1=Buffer[1];     //此值应对应通道AD12,但实际对应通道AD11
            sum2=Buffer[2];     //此值应对应通道AD13,但实际对应通道AD12
            sum3=Buffer[3];     //此值应对应通道AD14,但实际对应通道AD13
            sum4=Buffer[4];     //此值应对应通道AD15,但实际对应通道AD14
            sum5=Buffer[5];    //此值应对应通道AD16,但实际对应通道AD15
        AD_Finish_Flag=1;
    } //每个周期转换13次,分别存储在sunx[0]--sunx[12]中
    DMA_ClearITPendingBit(DMA1_IT_TC0);
定时器中还有这一段相关的代码,这里是控制AD转换开始的
        if(AD_Run_Time<25){AD_Run_Time++;}
        else
          disableInterrupts();
          DMA1_Init();
          ADC1_Init();
          enableInterrupts();
          ADC_SoftwareStartConv(ADC1);
          AD_Run_Time=0;
 楼主| liyancao001 发表于 2017-3-13 08:41 | 显示全部楼层
peterlifan 发表于 2017-6-1 17:11 | 显示全部楼层
表示这里好像看不懂 重复覆盖十三次吗 楼主是不是写错了
