/*---------------------------------------------------------------------------------------------------------*/ /* */ /* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ //*********************************************************************************************************** // Nuvoton Technoledge Corp. // Website: http://www.nuvoton.com // E-Mail : MicroC-8bit@nuvoton.com // Date : Apr/21/2016 //*********************************************************************************************************** //*********************************************************************************************************** // File Function: N76E003 APROM program DATAFLASH (APROM) demo code //*********************************************************************************************************** #include <stdio.h> #include "N76E003.h" #include "Define.h" #include "Common.h" #include "Delay.h" #include "SFR_Macro.h" #include "Function_define.h" #define CID_READ 0x0B #define DID_READ 0x0C /* Since the DATAFLASH is in the APROM. Program command is same as program APROM */ #define PAGE_ERASE_AP 0x22 #define BYTE_READ_AP 0x00 #define BYTE_PROGRAM_AP 0x21 #define PAGE_SIZE 128 #define ERASE_FAIL 0x70 #define PROGRAM_FAIL 0x71 #define IAPFF_FAIL 0x72 #define IAP_PASS 0x00 //--------------------------------------------------------------- // Following define by customer // Please confirm the start addresss not over your code size //--------------------------------------------------------------- #define DATA_SIZE 4096 #define DATA_START_ADDR 0x3800 /******************************************************************************************** Following IAP command register is also define in SFR_Macro.h #define set_IAPEN BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;CHPCON |= SET_BIT0 ;EA=BIT_TMP #define clr_IAPEN BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;CHPCON &= ~SET_BIT0;EA=BIT_TMP #define set_APUEN BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;IAPUEN |= SET_BIT0 ;EA=BIT_TMP #define clr_APUEN BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;IAPUEN &= ~SET_BIT0;EA=BIT_TMP **********************************************************************************************/ void IAP_ERROR_LED(void) { while (1) { clr_P03; Timer1_Delay1ms(100); set_P03; Timer1_Delay1ms(100); } } //-----------------------------------------------------------------------------------------------------------/ void Trigger_IAP(void) { set_IAPGO; //trigger IAP if((CHPCON&SET_BIT6)==SET_BIT6) // if fail flag is set, toggle error LED and IAP stop { clr_IAPFF; IAP_ERROR_LED(); } } /* WARNING: No matter read or writer, when IAPFF is set 1, this step process is fail. DATA should be ignore. */ //-----------------------------------------------------------------------------------------------------------/ /***************************************************************************************************************** Erase APROM subroutine: ******************************************************************************************************************/ void Erase_APROM(void) { UINT16 u16Count; set_IAPEN; // Enable IAP function IAPFD = 0xFF; // IMPORTANT !! To erase function must setting IAPFD = 0xFF IAPCN = PAGE_ERASE_AP; set_APUEN; // APROM modify Enable for(u16Count=0x0000;u16Count<DATA_SIZE/PAGE_SIZE;u16Count++) // { IAPAL = LOBYTE(u16Count*PAGE_SIZE + DATA_START_ADDR); IAPAH = HIBYTE(u16Count*PAGE_SIZE + DATA_START_ADDR); Trigger_IAP(); } clr_APUEN; clr_IAPEN; } //----------------------------------------------------------------------------------------------------------- void Erase_APROM_Verify(void) { UINT16 u16Count; set_IAPEN; IAPAL = LOBYTE(DATA_START_ADDR); IAPAH = HIBYTE(DATA_START_ADDR); IAPCN = BYTE_READ_AP; for(u16Count=0;u16Count<DATA_SIZE/PAGE_SIZE;u16Count++) { IAPFD = 0x00; Trigger_IAP(); if(IAPFD != 0xFF) IAP_ERROR_LED(); IAPAL++; if(IAPAL == 0x00) IAPAH++; } clr_IAPEN; } //----------------------------------------------------------------------------------------------------------- void Program_APROM(void) { UINT16 u16Count; set_IAPEN; set_APUEN; IAPAL = LOBYTE(DATA_START_ADDR); IAPAH = HIBYTE(DATA_START_ADDR); IAPCN = BYTE_PROGRAM_AP; for(u16Count=0;u16Count<DATA_SIZE;u16Count++) { IAPFD++; Trigger_IAP(); IAPAL++; if(IAPAL == 0) { IAPAH++; } } clr_APUEN; clr_IAPEN; } //----------------------------------------------------------------------------------------------------------- void Program_APROM_Verify(void) { UINT16 u16Count; UINT8 u8Read_Data; set_IAPEN; IAPAL = LOBYTE(DATA_START_ADDR); IAPAH = HIBYTE(DATA_START_ADDR); IAPCN = BYTE_READ_AP; u8Read_Data = 0x00; for(u16Count=0;u16Count<DATA_SIZE;u16Count++) { Trigger_IAP(); if(IAPFD != u8Read_Data) IAP_ERROR_LED(); IAPAL++; if(IAPAL == 0) { IAPAH++; } u8Read_Data ++; } clr_IAPEN; } //----------------------------------------------------------------------------------------------------------- //----------------------------------------------------------------------------------------------------------- void main (void) { Set_All_GPIO_Quasi_Mode; //---------toggle GPIO1--------- clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); //---------end toggle GPIO1--------- Erase_APROM(); Erase_APROM_Verify(); Program_APROM(); Program_APROM_Verify(); //---------toggle GPIO1--------- clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); //---------end toggle GPIO1--------- while(1); } //-----------------------------------------------------------------------------------------------------------
收藏1 举报
zhuotuzi 发表于 2017-3-18 18:46 这样就可以用多余的空间存储掉电保护的数据了。
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
发帖类勋章
等级类勋章
时间类勋章
204
3450
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
