F28069 MCbsp SPI模式 发送多字节问题
1374|3
 楼主| 洪剑平 发表于 2017-4-18 07:43 | 显示全部楼层 |阅读模式
大家好,这个问题困扰多天,只能求助各位大大了。
配置为SPI模式,发送16个16bit数据,发现数据总是不对,时钟有时候也不对,有时候是16bit,有时18bit,还有15bit,但只发一个数据的时候是正确的。
配置如下:
//*************** RESET MCBSP
        McbspaRegs.SPCR2.all=0x0000;                 // Reset FS generator, sample rate generator & transmitter
        McbspaRegs.SPCR1.all=0x0000;                 // Reset Receiver, Right justify word, Digital loopback dis.
        McbspaRegs.PCR.all=0x0F08;           //(CLKXM=CLKRM=FSXM=FSRM= 1, FSXP = 1)
        //McbspaRegs.SPCR1.bit.DLB = 1;
        McbspaRegs.SPCR1.bit.CLKSTP = 2;     // Low inactive state without delay:
        McbspaRegs.PCR.bit.CLKXP = 0;                 // transmits data on the rising edge
        McbspaRegs.PCR.bit.CLKRP = 0;        //receives data on the falling edge of MCLKR.
        McbspaRegs.RCR2.bit.RDATDLY = 1;      // FSX setup time 1 in master mode. 0 for slave mode (Receive)
        McbspaRegs.XCR2.bit.XDATDLY = 1;      // FSX setup time 1 in master mode. 0 for slave mode (Transmit)
        McbspaRegs.XCR2.bit.XPHASE = 0;  //发送使用单相位帧
        McbspaRegs.RCR2.bit.RPHASE = 0;  //接收使用单相位帧
        McbspaRegs.RCR1.bit.RWDLEN1 = 2;     // 16-bit word
        McbspaRegs.RCR1.bit.RFRLEN1 = 15;
        McbspaRegs.XCR1.bit.XWDLEN1 = 2;     // 16-bit word
        McbspaRegs.XCR1.bit.XFRLEN1 = 15;
        McbspaRegs.SRGR2.bit.CLKSM = 1;                // CLKSM=1 (If SCLKME=0, i/p clock to SRG is LSPCLK)
        McbspaRegs.SRGR1.bit.CLKGDV = 8;        //10 CLKG frequency = LSPCLK/(CLKGDV+1)
        McbspaRegs.SPCR2.bit.GRST = 1;         // Enable the sample rate generator
        //delay_loop();                        // Wait at least 2 SRG clock cycles
        McbspaRegs.SPCR2.bit.XRST = 1;         // Release TX from Reset
        McbspaRegs.SPCR1.bit.RRST = 1;         // Release RX from Reset
        delay_loop();
        McbspaRegs.SPCR2.bit.FRST = 1;         // Frame Sync Generator reset
        发送数据:
        for(i=0;i<16;i++)
                McbspaRegs.DXR1.all = Send_Dat[i];
                while( McbspaRegs.SPCR1.bit.RRDY == 1 )
                          read_data[i] = McbspaRegs.DRR1.all;
不知道是不是配置问题,望赐教,先谢谢了!
 楼主| 洪剑平 发表于 2017-4-18 07:48 | 显示全部楼层
希望有用过的人多多帮助,谢谢!
kkzz 发表于 2017-4-18 21:59 | 显示全部楼层
这个多字节还真没用过。
kkzz 发表于 2017-4-18 22:04 | 显示全部楼层
还是使用IO模拟SPI,这个好调试。
