[Kinetis] 程序编写时如何填充Unused memory, flash memory or RAM
561|0
 楼主| DongweiMiao 发表于 2017-5-29 14:43 | 显示全部楼层 |阅读模式
EMC Design Tips for Kinetis L Family
软件编写注意点
5.3 Unused memory, flash memory or RAM should be filled with a predefined content such that the MCU does not execute any unexpected instruction when the normal execution flow is disturbed by external noise sources,
这个该如何实现
我目前工程中用的是MKL16Z128,程序老师会跑非重启。
