#include "reg52.h"
#include "lcd1602.h"
#include"ds1302.h"
typedef unsigned char uchar;
typedef unsigned int uint;
sbit K1=P3^1; //选择调节的是时还是分还是秒
sbit K2=P3^0; //加数键
sbit K3=P3^2; // //连接外部中断0 ,停止时间的按键
sbit K4=P3^3;
sbit feng = P1^6;
uchar SetState,SetPlace,time_flag,clock_flag,alarm,temp;
uchar ala_flag;
uchar ala_hour/*闹钟的时*/,ala_min/*闹钟的分*/;
uchar alarmClock[2]; //code alarmClock[2]; code修饰的变量是被写入ROM的不可以被修改,所以要去掉code
uchar code nao[] = {0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
void interConfiguration();
void LcdDisplay();
void Delay10ms(void);
void setNianYueRiShiFenMiao(); //设置年月日时分秒
void set_clock_pattern(); //设置闹钟的模式
void alarm_clock(); //闹钟
void alarmDisplay(uchar ala1,uchar ala2);
void main()
Ds1302Init();
init1602();
for(;;)
if(SetState != 1) //不在调节时间模式下时读出时间
Ds1302ReadTime();
if(clock_flag != 1) //闹钟模式下不显示在DS1302跑的时间
LcdDisplay();
else
alarmDisplay(ala_hour,ala_min);
if(alarmClock[0] == TIME[2] && alarmClock[1] == TIME[1])
ala_flag = 1;
if(ala_flag)
alarm_clock();
* 函数名 : LcdDisplay()
* 函数功能 : 显示函数
* 输入 : 无
* 输出 : 无
void LcdDisplay()
writeCmd1602(0x80+0X40);
writeData1602('0'+TIME[2]/16); //时
writeData1602('0'+(TIME[2]&0x0f));
writeData1602(':');
writeData1602('0'+TIME[1]/16); //分
writeData1602('0'+(TIME[1]&0x0f));
writeData1602(':');
writeData1602('0'+TIME[0]/16); //秒
writeData1602('0'+(TIME[0]&0x0f));
writeCmd1602(0x80);
writeData1602('2');
writeData1602('0');
writeData1602('0'+TIME[6]/16); //年
writeData1602('0'+(TIME[6]&0x0f));
writeData1602('-');
writeData1602('0'+TIME[4]/16); //月
writeData1602('0'+(TIME[4]&0x0f));
writeData1602('-');
writeData1602('0'+TIME[3]/16); //日
writeData1602('0'+(TIME[3]&0x0f));
writeCmd1602(0x8D);
switch(TIME[5]&0x07)
case 0x01: writeData1602('M');writeData1602('o');writeData1602('n');break;
case 0x02: writeData1602('T');writeData1602('u');writeData1602('e');break;
case 0x03: writeData1602('W');writeData1602('e');writeData1602('d');break;
case 0x04: writeData1602('T');writeData1602('h');writeData1602('u');break;
case 0x05: writeData1602('F');writeData1602('r');writeData1602('i');break;
case 0x06: writeData1602('S');writeData1602('a');writeData1602('t');break;
case 0x07: writeData1602('S');writeData1602('u');writeData1602('n');break;
//writeData1602('0'+(TIME[5]&0x07)); //星期
* 函数名 : Int0Configuration()
* 函数功能 : 配置外部中断0,外部中断1,和定时器中断0
* 输入 : 无
* 输出 : 无
IT0=1;//跳变沿出发方式(下降沿)
EX0=1;//打开INT0的中断允许。
EA=1;//打开总中断
* 函数名 : Int0()
* 函数功能 : 外部中断0 中断函数
* 输入 : 无
* 输出 : 无
void Int0() interrupt 0 //按键3用来切换模式了
Delay10ms();
if(K3==0)
while(!K3);
SetState++;
void setNianYueRiShiFenMiao() //设置年月日时分秒
if(K1==0) //检测按键K1是否按下
delay(5); //消除抖动
if(K1==0)
while(!K1); //检测按键是否松开
if(time_flag == 1)
SetPlace++;
if(SetPlace>=7)
SetPlace=0;
if(clock_flag == 1)
alarm++;
if(alarm > 20)
alarm = 0;
if(K2==0) //检测按键K2是否按下
Delay10ms(); //消除抖动
if(K2==0)
while(!K2); //检测按键是否松kai
if(time_flag == 1)
TIME[SetPlace]++; //数组是第一个元素标号是从零开始的,第六次调节的就是年
if((TIME[SetPlace]&0x0f)>9) //换成BCD码。
TIME[SetPlace]=TIME[SetPlace]+6;
if((TIME[SetPlace]>=0x60)&&(SetPlace<2)) //分秒只能到59
TIME[SetPlace]=0;
if((TIME[SetPlace]>=0x24)&&(SetPlace==2)) //小时只能到23
TIME[SetPlace]=0;
if((TIME[SetPlace]>=0x32)&&(SetPlace==3)) //日只能到31
TIME[SetPlace]=0;
if((TIME[SetPlace]>=0x13)&&(SetPlace==4)) //月只能到12
TIME[SetPlace]=0;
if((TIME[SetPlace]>0x07)&&(SetPlace==5)) //周只能到7
TIME[SetPlace]=1;
// if(SetPlace==5) //月只能到12
// TIME[SetPlace]=;
if(clock_flag == 1)
if((alarm % 2) == 0)
ala_hour++;
alarmClock[0] = ala_hour; //将调好的闹钟时间的时存储起来,以便判断让校对时间是否到了
if(ala_hour > 24)
ala_hour = 0;
}else if((alarm%2) == 1)
ala_min++;
alarmClock[1] = ala_min; //将调好的闹钟的分存储起来
if(ala_min>59)
ala_min = 0;
void set_clock_pattern() //时钟模式选择,如调节年月日时分秒
if(SetState > 0)
switch(SetState)
//读出DS1302正在运行的数据
case 1: //Ds1302Write(0x80,0x80)/*写数据、停止计数*/;
time_flag = 1;//调节时间日期标志位置1
break;
case 2: time_flag = 0; //时间日期调节标志位清零
Ds1302Init();/*把调节好的时间日期写入DS1302*/;
case 3: ;
case 4: clock_flag = 1;/*闹钟调节标志位置1*/;
break;
case 5: SetState = 0;//模式标志位清零
clock_flag = 0;//调节好闹钟
break;
writeCmd1602(0x80+0x40);
writeData1602('A');//显示该符号表示处在闹钟模式下
writeData1602('R');//显示该符号表示处在闹钟模式下
writeData1602(' ');
writeCmd1602(0x80+0x40+3);
writeData1602(nao[ala1/10]);
writeData1602(nao[ala1 %10]);
writeData1602(':');
writeData1602(nao[ala2/10]);
writeData1602(nao[ala2%10]);
void alarm_clock() //闹钟
uchar i = 1000;
while(i--)
feng = 0;
delay(20);
feng = 1;
delay(20);
if(K3 == 0 || K1 == 0 || K2==0 || K4 ==0)
SetState = 0;
ala_flag = 0;
break;
ala_flag = 0;
* 函数名 : Delay10ms
* 函数功能 : 延时函数,延时10ms
* 输入 : 无
* 输出 : 无
void Delay10ms(void) //误差 0us
unsigned char a,b,c;
for(c=1;c>0;c--)
for(b=38;b>0;b--)
for(a=130;a>0;a--);
程序如上1602写和1302读写没问题,1602显示的秒会之跳变显示(比如上一次显示1,下一次就显示4),还有那按键失灵,调了两三天了还是不行,头痛啊,求大神帮忙,跪求大神帮忙。 |
