void RTC_CONFIG(void)
RTC_InitTypeDef RTC_InitStruct;
RTC_TimeTypeDef RTC_TIMESET;
int LSIFreq=40000;
RTC_INT();
RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR,ENABLE);//open the clock
PWR_BackupAccessCmd(ENABLE);//POWER OPEN
PWR_ClearFlag(PWR_FLAG_WU);
RCC_LSICmd(ENABLE);//OPEN LSI
/* Wait till LSI is ready */
while (RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET)
/* Check if the StandBy flag is set */
if (PWR_GetFlagStatus(PWR_FLAG_SB) != RESET)
/* Clear StandBy flag */
PWR_ClearFlag(PWR_FLAG_SB);
/* Check if the StandBy flag is cleared */
while(1);
IWDG_ReloadCounter();//FEED WACHDOG
RTC_WaitForSynchro();
/* No need to configure the RTC as the RTC config(clock source, enable,
prescaler,...) are kept after wake-up from STANDBY */
else
/* RTC Configuration ******************************************************/
/* Reset Backup Domain */
RCC_BackupResetCmd(ENABLE);
RCC_BackupResetCmd(DISABLE);
/* Select the RTC Clock Source */
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);//4000
/* Enable the RTC Clock */
RCC_RTCCLKCmd(ENABLE);
/* Wait for RTC APB registers synchronisation */
/* Get the LSI frequency: TIM14 is used to measure the LSI frequency */
//LSIFreq = GetLSIFrequency();
RTC_InitStruct.RTC_HourFormat = RTC_HourFormat_24;
RTC_InitStruct.RTC_AsynchPrediv = 127;
// RTC_InitStruct.RTC_AsynchPrediv = 88;
// RTC_InitStruct.RTC_SynchPrediv = (LSIFreq/100) - 1;
// RTC_InitStruct.RTC_SynchPrediv = 255;
RTC_InitStruct.RTC_SynchPrediv = 25;//10=3S
RTC_Init(&RTC_InitStruct);
/* Set the time to 01h 00mn 00s AM */
RTC_TIMESET.RTC_H12 = RTC_H12_AM;
RTC_TIMESET.RTC_Hours = 0x02;
RTC_TIMESET.RTC_Minutes = 0x00;
RTC_TIMESET.RTC_Seconds = 0x00;
RTC_SetTime(RTC_Format_BIN, &RTC_TIMESET);
// RTC_DeInit();//³õʼ»¯RTC¸÷¼Ä´æÆ÷Ϊ³õÖµ
// RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);//4000 RCC_RTCCLKSource_LSI LSI_VALUE RCC_RTCCLKSource_LSI
// RCC_RTCCLKCmd(ENABLE);//ENABLE rtc CLOCK
void RTC_INT(void)
EXTI_InitTypeDef EXTI_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;IWDG_ReloadCounter();//FEED WACHDOG
/* Configure EXTI Line17(RTC Alarm) to generate an interrupt on rising edge */
EXTI_ClearITPendingBit(EXTI_Line17);//¡¢¡¢RTC_IRQn
EXTI_InitStructure.EXTI_Line = EXTI_Line17;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;//EXTI_Mode_Event EXTI_Mode_Interrupt
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
/* Enable the RTC Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQn;//TIM17_IRQn
NVIC_InitStructure.NVIC_IRQChannelPriority = 2;//NVIC_IRQChannelPriority
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
//EXTI_ClearITPendingBit(EXTI_Line0 | EXTI_Line2 | EXTI_Line4 | EXTI_Line1 | EXTI_Line17); // ?? EXIT ????
void RTC_SLEEP(void)
RTC_AlarmTypeDef RTC_AlarmStructure;
RTC_AlarmCmd(RTC_Alarm_A,DISABLE);//RTC-CR-ALARM ¹ØµôÄÖÖÓ
RTC_GetTime(RTC_Format_BIN, &RTC_TIMESET);
RTC_AlarmStructure.RTC_AlarmTime.RTC_H12=RTC_H12_AM;//0
RTC_AlarmStructure.RTC_AlarmTime.RTC_Hours=0x02;
RTC_AlarmStructure.RTC_AlarmTime.RTC_Minutes=0x00;
RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds=( RTC_TIMESET.RTC_Seconds + 0x03 )%60;
// RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds=0x02; //¶¨Ê±Ê±¼äÃë
//RTC_AlarmSubSecondConfig(RTC_Alarm_A,RTC_AlarmSubSecondMask_None,0);//ÅäÖÃÄÖÖÓλ¼°ÑÇÃëÖµ RTC_AlarmSubSecondMask_None RTC_AlarmSubSecondMask_SS14_12 RTC_AlarmSubSecondMask_SS14_2
RTC_AlarmStructure.RTC_AlarmDateWeekDay = 31;
RTC_AlarmStructure.RTC_AlarmDateWeekDaySel = RTC_AlarmDateWeekDaySel_Date;
RTC_AlarmStructure.RTC_AlarmMask = RTC_AlarmMask_DateWeekDay | RTC_AlarmMask_Hours | RTC_AlarmMask_Minutes ;//RTC_AlarmMask_Seconds
RTC_SetAlarm(RTC_Format_BIN, RTC_Alarm_A, &RTC_AlarmStructure);
/* Clear RTC Alarm Flag */
RTC_ClearFlag(RTC_FLAG_ALRAF);
RTC_ClearFlag(RTC_FLAG_ALRAF);//alarm flag
RTC_ClearFlag(RTC_FLAG_WUTF);//WakeUp Timer flag
RTC_ClearITPendingBit(RTC_IT_TS);
RTC_ClearITPendingBit(RTC_IT_ALRA);
RTC_ClearITPendingBit(RTC_IT_TAMP1);
RTC_ClearITPendingBit(RTC_IT_TAMP2);
/* Enable RTC Alarm A Interrupt: this Interrupt will wake-up the system from
STANDBY mode (RTC Alarm IT not enabled in NVIC) */
RTC_ITConfig(RTC_IT_ALRA, ENABLE);
/* Enable the Alarm A */
RTC_AlarmCmd(RTC_Alarm_A, ENABLE);
// RTC_ClearFlag(RTC_FLAG_ALRAF);
// EXTI_ClearITPendingBit(EXTI_Line0 | EXTI_Line2 | EXTI_Line4 | EXTI_Line1 | EXTI_Line17); // ?? EXIT ????
// PWR_EnterSTANDBYMode();
PWR_EnterSTOPMode(PWR_Regulator_ON,PWR_STOPEntry_WFI);//WFI=every interrput PWR_Regulator_LowPower PWR_Regulator_ON
