一个可以山寨的好东西
4352|8
 楼主| drentsi 发表于 2010-6-21 10:04 | 显示全部楼层 |阅读模式
这玩意目前就看到一家卖的,246USD,呵呵,国内还没找到卖的。
原网址如下
http://www.dhgate.com/4pcs-lot-anti-camera-super-sleuth-camera/p-ff8080811eb5c587011eb9f51e193939.html
Spy Hidden Camera Lens Detector & Sweeper
It uses an array of ultra bright LEDs that create a strong reflection from a camera’s lens that is easily detected. Unique to this device, users simply look through the view-window to identify hidden cameras lens in a room.
Main features of the camera lens detector
1.
An array of ultra bright LEDs to detect camera lens
2.
Weight:38g
3.
Five model flicker frequencies of LEDs are available
4.
6 Ultra Bright Red LEDs
5.
Dimension: 62x48x9mm
6.
Power Source: Internal Li Ion Battery, 5 VDC Charging
This camera lens detector dose not rely on detecting the RF signal from a wireless camera or the oscillator frequency radiated by a wired camera, it uses an array of ultra bright LEDs that create a strong reflection from a camera’s lens that is easily detected.
Packing list
Camera lens detector x1
Charger x1
USB Cable x1
技术含量不高的,深圳有山寨货不?
 楼主| drentsi 发表于 2010-6-21 10:07 | 显示全部楼层
晕倒,现找到了,原来这玩意就是深圳造的
acute1110 发表于 2010-6-21 13:00 | 显示全部楼层
这东西好像也没有什么技术含量
acute1110 发表于 2010-6-21 13:35 | 显示全部楼层
楼上的,不会看了介绍还不知道干什么的吧?
tg.liu 发表于 2010-6-21 22:16 | 显示全部楼层
防偷拍的吧? 呵呵
lirunze 发表于 2010-6-27 19:01 | 显示全部楼层
什么玩意啊
acute1110 发表于 2010-6-28 08:43 | 显示全部楼层
PLAYMCU怎么把自己在4楼的贴子给删除了啊,版主怎么回事啊,能否给个说发呀!!!!!!!!!!!!
湘西土匪 发表于 2010-6-28 15:06 | 显示全部楼层
还有更先进的
激光无线多功能侦测器是综合目前诸多无线偷拍,有线偷拍的各种方式的特点,而专门设计的,是目前全球唯一一家做到无线和有线摄像头都能侦测的产品
doob 发表于 2011-6-23 15:20 | 显示全部楼层
什么原理?
个人签名:学习,思考。
144
