用过stm8l152+cc1100 的朋友进来看看
4038|1
 楼主| mingyuekd 发表于 2010-6-23 11:27 | 显示全部楼层 |阅读模式
/////////////stm8l152 PB4/5/6/7口初始化 如下
void SPI_FLASH_Init(void)
    /* Enable SPI clock */
  CLK_PeripheralClockConfig(CLK_Peripheral_SPI1, ENABLE);
/* Set the MOSI,MISO and SCK at high level */
  GPIO_ExternalPullUpConfig(GPIOB, P_SCLK | P_SI | P_SO, ENABLE);
  /* Configure SPI_FLASH_CS as Output push-pull, used as Flash Chip select */
GPIO_Init(GPIOB, P_CSn, GPIO_Mode_Out_PP_High_Slow);
/* Deselect the FLASH: Chip Select high */
  //SPI_FLASH_CS_HIGH();
GPIOB->ODR |= P_CSn ;      //   CSN =1
  /* SPI configuration */
SPI_Init(SPI1, SPI_FirstBit_MSB, SPI_BaudRatePrescaler_2, SPI_Mode_Master,
           SPI_CPOL_High, SPI_CPHA_2Edge, SPI_Direction_2Lines_FullDuplex,
           SPI_NSS_Soft, 0x07);
  /* Enable SPI  */
  SPI_Cmd(SPI1, ENABLE);
我现在用spi口对cc1100进行数据读写控制,采用如下子函数读写,看有不妥地方在哪?
////////////spi write 单一字节
#define WRITE_BURST     0x40
#define READ_SINGLE     0x80
#define READ_BURST      0xC0
#define WRITE_SINGLE    0x00
unsigned char SPI_write(uint8_t value)
GPIOB->ODR &= ~P_CSn ;      //   CSN =0 enable spi
SPI_FLASH_SendByte(WRITE_SINGLE);  //
SPI_FLASH_SendByte(WRITE_BURST);
SPI_FLASH_SendByte(value);
////SPI接口 从CC1100读取单一字节
unsigned char SPI_read()
  uint8_t value;
SPI_FLASH_SendByte(READ_SINGLE);
SPI_FLASH_SendByte(READ_BURST);
value=SPI_ReceiveData(SPI1);       //
return value;
若有错误地方,希望指点下。非常感谢!
 楼主| mingyuekd 发表于 2010-6-23 11:30 | 显示全部楼层
////SPI_FLASH_SendByte如下
uint8_t SPI_FLASH_SendByte(uint8_t byte)
  /* Loop while DR register in not emplty */
  while (SPI_GetFlagStatus(SPI_FLASH, SPI_FLAG_TXE) == RESET);
  /* Send byte through the SPI peripheral */
  SPI_SendData(SPI_FLASH, byte);
  /* Wait to receive a byte */
  while (SPI_GetFlagStatus(SPI_FLASH, SPI_FLAG_RXNE) == RESET);
  /* Return the byte read from the SPI bus */
  return SPI_ReceiveData(SPI_FLASH);
