官方例程关于时钟锁相环的一点疑问
2656|2
 楼主| apple武 发表于 2017-7-4 21:40 | 显示全部楼层 |阅读模式
官方例程如下:
void  InitPll(Uint16 val, Uint16 divsel)
    // Make sure the PLL is not running in limp mode
    if (SysCtrlRegs.PLLSTS.bit.MCLKSTS != 0)                            //检测到时钟信号不好,直接退出
        // Missing external clock has been detected
        // Replace this line with a call to an appropriate
        // SystemShutdown(); function.
        asm("        ESTOP0");
    // DIVSEL MUST be 0 before PLLCR can be changed from
    // 0x0000. It is set to 0 by an external reset XRSn
    // This puts us in 1/4
    if (SysCtrlRegs.PLLSTS.bit.DIVSEL != 0)                                          //分频部分先设定为4分频,在PLLCR改变之前,DIVSEL  必须为0
        EALLOW;
        SysCtrlRegs.PLLSTS.bit.DIVSEL = 0;
        EDIS;
    // Change the PLLCR
    if (SysCtrlRegs.PLLCR.bit.DIV != val)
        EALLOW;
        // Before setting PLLCR turn off missing clock detect logic
        SysCtrlRegs.PLLSTS.bit.MCLKOFF = 1;        //改变PLL倍频系数时,要把丢失时钟检测关闭
        SysCtrlRegs.PLLCR.bit.DIV = val;
        EDIS;
        // Optional: Wait for PLL to lock.        //在对时钟分频时,要保证PLL已经入锁
        // During this time the CPU will switch to OSCCLK/2 until                                      //pLL稳定之前,内核时钟为OSCCLK/2 =15M
        // the PLL is stable.  Once the PLL is stable the CPU will
        // switch to the new PLL value.        //PLL一旦稳定下来,内核时钟转变为新的值
        // This time-to-lock is monitored by a PLL lock counter.
        // Code is not required to sit and wait for the PLL to lock.                                    //代码不需要等待PLL入锁,但是,如何代码在做一些关键的事情时,需要正确的时钟
        // However, if the code does anything that is timing critical,                                 //入锁,最好等待时钟转换完成
        // and requires the correct clock be locked, then it is best to
        // wait until this switching has completed.
        // Wait for the PLL lock bit to be set.
        // The watchdog should be disabled before this loop, or fed within                                //在循环之前,要保证开门狗关闭,或者喂狗
        // the loop via ServiceDog().
        // Uncomment to disable the watchdog                                                      //打开看门狗
        DisableDog();
        while(SysCtrlRegs.PLLSTS.bit.PLLLOCKS != 1)            //等待PLL入锁
            // Uncomment to service the watchdog
            //ServiceDog();
        EALLOW;
        SysCtrlRegs.PLLSTS.bit.MCLKOFF = 0;                //振荡器时钟丢失检测使能
        EDIS;
    // If switching to 1/2
    if((divsel == 1)||(divsel == 2))
        EALLOW;
        SysCtrlRegs.PLLSTS.bit.DIVSEL = divsel;
        EDIS;
    // NOTE: ONLY USE THIS SETTING IF PLL IS BYPASSED (I.E. PLLCR = 0) OR OFF
    // If switching to 1/1
    // * First go to 1/2 and let the power settle
    //   The time required will depend on the system, this is only an example
    // * Then switch to 1/1
    if(divsel == 3)                                          //??????????????????????不明白为什么要这样来,不是直接赋成3就行了,,求解,我看网上有说是为了防止两个
    {                                                            //分频器同时分频出现错误,可是这样先分成2分频,再分成1分频就行了??????不是太懂,还望大神指点
        EALLOW;
        SysCtrlRegs.PLLSTS.bit.DIVSEL = 2;
        DELAY_US(50L);
        SysCtrlRegs.PLLSTS.bit.DIVSEL = 3;
        EDIS;
 楼主| apple武 发表于 2017-7-4 21:42 | 显示全部楼层
红色字是我自己的一些理解,还望大神指点,谢谢了
 楼主| apple武 发表于 2017-7-13 11:06 | 显示全部楼层
官方配置步骤,按照这个来,可是最后配置分频比的时候,并没有说明不分频的时候,需要先切换到2分频,再切换到不分频,感觉这是在为硬件电路进行考虑!
就先这个样子吧,结贴了,要是大神们,有见解了,再交流哈
