[matlab] 范例:opencore组织RISCMCU IP Core全套最新代码 _extint
2440|0
 楼主| yun888 发表于 2010-8-30 11:11 | 显示全部楼层 |阅读模式
---- WISHBONE RISCMCU IP Core ----
---- This file is part of the RISCMCU project ----
---- http://www.opencores.org/projects/riscmcu/ ----
---- Description ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s): ----
---- - Yap Zi He, yapzihe@hotmail.com ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG ----
---- This source file may be used and distributed without ----
---- restriction provided that this copyright statement is not ----
---- removed from the file and that any derivative work contains ----
---- the original copyright notice and the associated disclaimer. ----
---- This source file is free software; you can redistribute it ----
---- and/or modify it under the terms of the GNU Lesser General ----
---- Public License as published by the Free Software Foundation; ----
---- either version 2.1 of the License, or (at your option) any ----
---- later version. ----
---- This source is distributed in the hope that it will be ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ----
---- PURPOSE. See the GNU Lesser General Public License for more ----
---- details. ----
---- You should have received a copy of the GNU Lesser General ----
---- Public License along with this source; if not, download it ----
---- from http://www.opencores.org/lgpl.shtml ----
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity v_extint is
port( clk, clrn, extpin, clr_intf : in std_logic;
rd_mcucr, wr_mcucr, rd_gimsk, wr_gimsk : in std_logic;
extirq : out std_logic;
c : inout std_logic_vector(7 downto 0));
end v_extint;
architecture extint of v_extint is
signal int0, flag, currentstate, laststate : std_logic;
signal isc0 : integer range 0 to 3;
begin
c <= "000000" & conv_std_logic_vector(isc0,2) when rd_mcucr = '1' else
'0' & int0 & "000000" when rd_gimsk = '1' else
"ZZZZZZZZ";
extirq <= int0 and not extpin when isc0 = 0 else
int0 and flag;
process(clk, clrn)
begin
if clrn = '0' then
int0 <= '0';
isc0 <= 0;
currentstate <= '0';
laststate <= '0';
elsif clk'event and clk = '1' then
if wr_gimsk = '1' then
int0 <= c(6);
end if;
if wr_mcucr = '1' then
isc0 <= conv_integer(c(1 downto 0));
end if;
currentstate <= extpin;
laststate <= currentstate;
end if;
end process;
process(clrn, clr_intf, clk, isc0, currentstate)
begin
if clrn = '0' or clr_intf = '1' then
flag <= '0';
if isc0 = 2 then
if currentstate = '0' and laststate = '1' then
flag <= '1';
end if;
elsif isc0 = 3 then
if currentstate = '1' and laststate = '0' then
flag <= '1';
end if;
end if;
end if;
end process;
end extint;
