[产品供应] 0755-81751047罗姆二极管和部分三极管DA228KT146
1966|0
 楼主| 13684964275 发表于 2010-11-22 11:07 | 显示全部楼层 |阅读模式
罗姆快恢复二极管
RF051VA2STR      DIODE FAST REC 200V 0.5A TUMD2
RF071M2STR       FAST RECOVERY 200V 7A; Diode Type:Fast Recovery
RF101L2STE25     DIODE FAST REC 200V 1A SOD-106
RF103L2STE25     DIODE FAST REC PMDU = SOD-106
RF2L6STE25       DIODE FAST REC 600V 1.5A SOD-106
罗姆齐纳二极管和部分罗姆三极管
1SR154-400TE25   DIODE RECTIFIER 400V 1A SOD-106
1SR154-600TE25   DIODE RECTIFIER 600V 1A SOD-106
1SR156-400TE25   DIODE RECT 400V 1A SOD-106 TR
1SR159-200TE25   Diode Ultra Fast Recovery Rectifier 200V 1A PMDS T/R
CDZT2R6.2B       DIODE ZENER 100MW VMN2
CDZT2R7.5B       7.5 V   100 mW  封装 / 箱体:  VMN-2
CDZT2R8.2B       8.2 V   100 mW  封装 / 箱体:  VMN-2
EDZTE6127B       ZENER SOD-523 27V; Zener Voltage Vz Typ:27V; Max:150mW
EDZTE614.3B      DIODE,ZENER,4.3V,0.15W,SOD523
EDZTE614.7B      ZENER SOD-523 4.7V; Zener Voltage Vz Typ:4.7V Max:150mW
EDZTE615.1B      ZENER SOD-523 5.1V; Zener Voltage Vz Typ:5.1V Max:150mW
EDZTE615.6B      ZENER SOD-523 5.6V; Zener Voltage Vz Typ:5.6V Max:150mW
EDZTE616.8B      DIODE,ZENER,6.8V,0.15W,SOD523
EDZTE617.5B      ZENER SOD-523 7.5V; Zener Voltage Vz Typ:7.5V Max:150mW
EDZTE618.2B      Zener Diodes 150MW 8.2V
EDZTE619.1B      Zener Diodes 150MW 9.1V
EMZ1T2R          TRANS NPN/PNP 50V 150MA EMT6
EMZ2T2R          TRANS NPN/PNP 50V 150MA EMT6
EMZ6.8ET2R       DIODE ZENER QUAD 6.8V EMD5
EMZ6.8NTL        DIODE ZENER DUAL 6.8V SOT-416
EMZ7T2R          TRANS COMPLEX BIPO NPN/PNP EMT6
FTZ5.6ET148      DIODE ZENER QUAD 5.6V SMD5
FTZ6.8ET148      DIODE ZENER QUAD 6.8V SMD5
RR255M-400TR     DIODE RECT 0.7A 400V PMDU
RR264M-400TR     DIODE 400V 0.7A SOD-123
RR274EA-400TR    DIODE RECT DUAL 400V 0.5A SC-74
RSA30LTE25       TVS DIODE 600W 30V UNI SOD-106
RSA5LTE25        TVS DIODE 600W 5V UNI SOD-106
RSA6.1ENTR       TVS DIODE 30W 3V 2CH BI SOT-353
RSA6.1J4T2R      TVS DIODE 80W 3V 2CH BI SC-75A
RSB12JS2T2R      DIODE ZENER ESD PROT EMD6
RSB16F2T106      DIODE ZENER BIDIR 200MW UMD3
RSB18VTE-17      DIODE ZENER BIDIR 200MW UMD2
RSB27F2T106      DIODE ZENER BIDIR 200MW UMD3
RSB27VTE-17      DIODE ZENER BIDIR 200MW UMD2
RSB6.8STE61      Zener Diodes TVS ARRAY2 ELEMENTS
STZ5.6NT146      DIODE ZENER DUAL 5.6V SOT-346
STZ6.8NT146      DIODE ZENER DUAL 6.8V SOT-346
UMZ1NTR          TRANS NPN/PNP 50V 150MA SOT-363
UMZ12NT106       DIODE ZENER DUAL 12V SOT-323
UMZ2NTR          TRANS NPN/PNP 50V 150MA SOT-363
UMZ27NT106       DIODE ZENER DUAL 27V SOT-323
UMZ6.8ENTR       DIODE ZENER QUAD 6.8V SOT-353
UMZ6.8NT106      DIODE ZENER DUAL 6.8V SOT-323
UMZ7NTR          TRANS NPN/PNP 12V 500MA SOT-363
UMZ8.2NT106      DIODE ZENER DUAL 8.2V SOT-323
UMZ8.2TT106      DIODE ZENER DUAL 8.2V SOT-323
UMZC6.8NT106     DIODE ZENER LOW CAP 200MW UMD3
UMZU6.2NT106     DIODE ZENER LOW CAP 200MW UMD3
VMZ6.8NT2L       DIODE ZENER DUAL 6.8V VMD3
罗姆开关二极管
1SS380TE-17      DIODE 35V 100MA SOD-323
1SS400TE61       DIODE 80V 100MA SOD-523
1SS400CST2R      Diodes HIGH FREQUENCY SWITCHING
1SS400GT2R       DIODE 80V 100MA VMD2
DA204KT146       DIODE SWITCH 20V 100MA SOT-346
DA204UT106       DIODE SW 20V 100MA SOT-323 TR
DA221TL          DIODE SWITCH 20V 100MA SOT-416
DA221MT2L        DIODE SWITCH 100MA 20V VMD3
DA227TL          DIODE SWITCH 80V 100MA SOT-343
DA228KT146       DIODE SWITCH 100MA 80V HS SOT346
DAN202UT106      DIODE SWITCH 80V 100MA SOT-323
DAN212KT146      DIODE SWITCH SMD3
DAN217UT106      DIODE SW 80V 100MA SOT-323 TR
DAN222MT2L       DIODE,SWITCHING,0.1A,80V,VMD3
DAN235ETL        DIODE SWITCH BAND 35V SOT-416 TR
DAN235UT106      DIODE SWITCH BAND 35V SOT-323
DAP202KT146      DIODE SWITCH 80V 100MA SOT-346
DAP202UT106      DIODE SWITCH 80V 100MA SOT-323
DAP222MT2L       DIODE SWITCH 100MA 80V VMD3
DAP236UT106      DIODE SWITCH BAND 35V SOT323 TR
EMN11T2R         DIODE SWITCH 80V 100MA HS EMD6
EMP11T2R         DIODE SWITCH 80V 100MA HS EMD6
FMN1T148         DIODE SWITCH 80V 25MA SC-74A
FMP1T148         Diodes  SC-74A COMMON ANODE
UMN1NTR          HIGH SPEED SWITCHING; Diode Type:Switching;
UMN11NTN         4 DIODE ARRAY SOT-363
UMP11NTN         80 V 300 mA SMD Switching Diode-SOT-363
罗姆高频二极管
RB876WTL         DIODE SCHOTTKY 5V 10MA EMD3
RB886GT2R        DIODE SCHOTTKY 5V 10MA VMD2
RN142GT2R        PIN Diodes HIGH FREQUENCY
RN731VTE-17      DIODE: HIGH FREQUENCY SOD-323
RN739DT146       DIODE PIN HF SW 50V 50MA SMD3
RN739FT106       DIODE PIN 50V 50MA SOT-323 TR
以上罗姆二极管和部分三极管,深圳现货供应。
个人签名:contract: 伏西成 mobile:18576603015 http://www.muratafilter.com
