确定芯片的话,找芯片的规格书,找到对应的寄存器修改就行了啊
STM32CubeF1里面有ILI9320的驱动,你可以看一下
ILI9320控制刷新方向的寄存器应该是 0x03
- /* Set GRAM write direction and BGR = 1 */
- /* I/D=01 (Horizontal : increment, Vertical : decrement) */
- /* AM=1 (address is updated in vertical writing direction) */
- ili9320_WriteReg(LCD_REG_3, 0x1018);
