以下是配置描述符和报告描述符,是和Itspy网友一样的
const u8 CustomHID_ConfigDescriptor[CUSTOMHID_SIZ_CONFIG_DESC] =
0x09, /* bLength: Configuation Descriptor size */
USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType: Configuration */
CUSTOMHID_SIZ_CONFIG_DESC,
/* wTotalLength: Bytes returned */
0x00,
0x01, /* bNumInterfaces: 1 interface */
0x01, /* bConfigurationValue: Configuration value */
0x00, /* iConfiguration: Index of string descriptor describing
the configuration*/
0xC0, /* bmAttributes: Bus powered */
/*Bus powered: 7th bit, Self Powered: 6th bit, Remote wakeup: 5th bit, reserved: 4..0 bits */
0x32, /* MaxPower 100 mA: this current is used for detecting Vbus */
// 0x96, /* MaxPower 300 mA: this current is used for detecting Vbus */
/************** Descriptor of Custom HID interface ****************/
/* 09 */
0x09, /* bLength: Interface Descriptor size */
USB_INTERFACE_DESCRIPTOR_TYPE,/* bDescriptorType: Interface descriptor type */
0x00, /* bInterfaceNumber: Number of Interface */
0x00, /* bAlternateSetting: Alternate setting */
0x02, /* bNumEndpoints */
0x03, /* bInterfaceClass: HID */
0x00, /* bInterfaceSubClass : 1=BOOT, 0=no boot */
0x00, /* nInterfaceProtocol : 0=none, 1=keyboard, 2=mouse */
0, /* iInterface: Index of string descriptor */
/******************** Descriptor of Custom HID HID ********************/
/* 18 */
0x09, /* bLength: HID Descriptor size */
HID_DESCRIPTOR_TYPE, /* bDescriptorType: HID */
0x10, /* bcdHID: HID Class Spec release number */
0x01,
0x00, /* bCountryCode: Hardware target country */
0x01, /* bNumDescriptors: Number of HID class descriptors to follow */
0x22, /* bDescriptorType */
CUSTOMHID_SIZ_REPORT_DESC,/* wItemLength: Total length of Report descriptor */
0x00,
/******************** Descriptor of Custom HID endpoints ******************/
/* 27 */
0x07, /* bLength: Endpoint Descriptor size */
USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType: */
0x82, /* bEndpointAddress: Endpoint Address (IN) */
// bit 3...0 : the endpoint number
// bit 6...4 : reserved
// bit 7 : 0(OUT), 1(IN)
0x03, /* bmAttributes: Interrupt endpoint */
0x40,//0x02, /* wMaxPacketSize: 20 Bytes max */
0x00,
0x10, /* bInterval: Polling Interval (21 ms) */
/* 34 */
/* Endpoint descriptor type */
0x01, /* bEndpointAddress: */
/* Endpoint Address (OUT) */
0x00,
0x10, /* bInterval: Polling Interval (32 ms) */
/* 41 */
; /* CustomHID_ConfigDescriptor */
const u8 CustomHID_ReportDescriptor[CUSTOMHID_SIZ_REPORT_DESC] =
//#ifdef 0
0x05, 0x8c, /* USAGE_PAGE (ST Page) */
0x09, 0x01, /* USAGE (Demo Kit) */
0xa1, 0x01, /* COLLECTION (Application) */
/* 6 */
// The Input report
//0x85,0x01,
0x09,0x03, // USAGE ID - Vendor defined
0x15,0x00, // LOGICAL_MINIMUM (0)
0x26,0x00, 0xFF, // LOGICAL_MAXIMUM (255)
0x75,0x08, // REPORT_SIZE (8)
0x95,0x16, // REPORT_COUNT (20)
0x81,0x02, // INPUT (Data,Var,Abs)
//19
// The Output report
//0x85,0x02,
0x09,0x04, // USAGE ID - Vendor defined
0x26,0x00,0xFF, // LOGICAL_MAXIMUM (255)
0x91,0x02, // OUTPUT (Data,Var,Abs)
//32
0xc0 /* END_COLLECTION */
//#endif
}; /* CustomHID_ReportDescriptor */
