STM32外部中断的小问题
2793|0
 楼主| 车干21IC 发表于 2011-4-10 20:09 | 显示全部楼层 |阅读模式
初次使用中断我本想设置两个按键。但是同样的中断函数,在PB4口可以,PB3口就不能使用。
程序如下:
#include "stm32f10x.h"
void RCC_Config(void);
  //时钟配置函数
void GPIO_Config(void);
  //I/O口配置函数
void EXIT_Config(void);
  //中断选择配置
void NVIC_Config(void);
  //中断优先级选择
void  Delay (u32 nCount)
  for(; nCount != 0; nCount--);
int main(void)
RCC_Config();
GPIO_Config();
EXIT_Config();
NVIC_Config();
    while (1){
/*====LED1-ON=======*/
GPIO_SetBits(GPIOB , GPIO_Pin_6);
GPIO_ResetBits(GPIOB , GPIO_Pin_7);
GPIO_ResetBits(GPIOB , GPIO_Pin_8);
GPIO_ResetBits(GPIOB , GPIO_Pin_9);
Delay(0xfffff);
Delay(0xfffff);
Delay(0x5ffff);
/*====LED2-ON=======*/
GPIO_ResetBits(GPIOB , GPIO_Pin_6);
GPIO_SetBits(GPIOB , GPIO_Pin_7);
GPIO_ResetBits(GPIOE , GPIO_Pin_8);
GPIO_ResetBits(GPIOE , GPIO_Pin_9);
Delay(0xfffff);
Delay(0xfffff);
Delay(0x5ffff);
/*====LED3-ON=======*/
GPIO_SetBits(GPIOB , GPIO_Pin_8);
Delay(0xfffff);
Delay(0xfffff);
Delay(0x5ffff);
/*====LED4-ON=======*/
GPIO_SetBits(GPIOB , GPIO_Pin_9);
Delay(0xfffff);
Delay(0xfffff);
Delay(0x5ffff);
  /*设置I/O口使能时钟,配置I/O模式*/
  /*使能AFIO复用I/O口的时钟*/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO , ENABLE);
LED1 -> PB6
LED2 -> PB7 , LED3 -> PB8 , LED4 -> PB9
KEY1  ->PB1
KEY2  ->PB2
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 |GPIO_Pin_7 |GPIO_Pin_8 |GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/*定义错误变量HSEStartUpStatus*/
    ErrorStatus HSEStartUpStatus;
/* 这里是重置了RCC的设置,类似寄存器复位 */
    RCC_DeInit();
/* 使能外部高速晶振 */
    RCC_HSEConfig(RCC_HSE_ON);
/* 等待高速晶振稳定 */
    HSEStartUpStatus = RCC_WaitForHSEStartUp();
    if (HSEStartUpStatus == SUCCESS)
      /* HCLK = SYSCLK 设置高速总线时钟=系统时钟*/
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
      /* PCLK2 = HCLK 设置低速总线2时钟=高速总线时钟*/
      RCC_PCLK2Config(RCC_HCLK_Div1);
      /* PCLK1 = HCLK/2 设置低速总线1的时钟=高速时钟的二分频*/
      RCC_PCLK1Config(RCC_HCLK_Div2);
      /* ADCCLK = PCLK2/6 设置ADC外设时钟=低速总线2时钟的六分频*/
      RCC_ADCCLKConfig(RCC_PCLK2_Div6);
      /* 利用锁相环讲外部8Mhz晶振9倍频到72Mhz */
      RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
      /* Enable PLL 使能锁相环*/
      RCC_PLLCmd(ENABLE);
  /* Wait till PLL is ready 等待锁相环输出稳定*/
      while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
      /* Select PLL as system clock source 将锁相环输出设置为系统时钟 */
      RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
      /* Wait till PLL is used as system clock source 等待校验成功*/
      while (RCC_GetSYSCLKSource() != 0x08)
    EXTI_InitTypeDef EXTI_InitStructure; //定义结构
GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource4);
EXTI_ClearITPendingBit(EXTI_Line4);
    EXTI_InitStructure.EXTI_Line = EXTI_Line4;
    EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
    EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
    EXTI_InitStructure.EXTI_LineCmd = ENABLE;
    EXTI_Init(&EXTI_InitStructure);
    NVIC_InitTypeDef NVIC_InitStructure;
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); //占先优先级、副优先级的资源分配
    NVIC_InitStructure.NVIC_IRQChannel = EXTI4_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd  = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
void EXTI4_IRQHandler(void)
if ( EXTI_GetITStatus(EXTI_Line4) != RESET ) {
Delay(0xfffff);
Delay(0xfffff);
Delay(0xfffff);
Delay(0xfffff);
Delay(0xfffff);
Delay(0xfffff);
这个是可行的  但是所有的4改为3就不可以用了。求问这是个什么问题?
