采用单线通信协议的存储器仿真参考设计
1065|6
 楼主| dirtwillfly 发表于 2018-1-27 21:47 | 显示全部楼层 |阅读模式
描述
By applying low power modes and FRAM technology this reference design utilizes 1-wire device communication to emulate EEPROM functionality on an MSP430™ microcontroller (MCU).  This solution includes the ability to be powered parasitically from the communication line and allocates more memory space than is available than current 1-wire devices on the market.
特性
  • Complete 1-Wire protocol support assures an easy transition and effortless substitution for similar EEPROM devices
  • Uses LPMs to accomplish an average standby current consumption of 600 nA in standby mode
  • Design is achievable on any MSP430 FRAM MCU and allows for flexibility in the available EEPROM memory space
  • Includes selectable operation modes such as dedicated or parasitic power
  • Provided firmware may be nodified for use in other 1-wire applications
 楼主| dirtwillfly 发表于 2018-1-27 21:49 | 显示全部楼层
应用手册:
 楼主| dirtwillfly 发表于 2018-1-27 21:50 | 显示全部楼层
用户指南
 楼主| dirtwillfly 发表于 2018-1-27 21:52 | 显示全部楼层
设计文件
 楼主| dirtwillfly 发表于 2018-1-27 21:55 | 显示全部楼层
软件:
minzisc 发表于 2018-2-1 21:29 | 显示全部楼层
单单线通信协议的存储器是什么?优盘吗?
 楼主| dirtwillfly 发表于 2018-2-1 21:46 | 显示全部楼层
单单线通信协议的存储器是什么?优盘吗?
不是的。就是单总线的存储器
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1199
