关于IIS2始终调不通,STM32F103VCT6芯片,求高手相助!!!
4136|1
 楼主| elvyis 发表于 2011-6-12 10:21 | 显示全部楼层 |阅读模式
搞好了IIS3主发送,但是IIS2还是没有检测到波形,代码如下。*******************************************************************
void GPIO_Configuration(void)
//  GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable, ENABLE);/*JTAG+SW完全禁止*/
  /* Disable the JTAG interface and enable the SWJ interface */
  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
  /* Configure SPI2 pins: CK-PB13, WS-PB12 and SD-PB15 ---------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;/*I2S2作为主发,数据复用推挽输出*/
  GPIO_Init(GPIOB, &GPIO_InitStructure);
    /* Configure SPI2: MCK PC6,输出时钟-----------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
/* Configure I2S3 (SPI3) pins: MCLK */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
    /* Configure I2S3 (SPI3) pins: BCLK and ADCDAT */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_5;
    /* Configure I2S3 (SPI3) pins: ADCLRC (WS) */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
void I2S_Configuration(void){
      I2S_InitTypeDef I2S_InitStructure;
      SPI_I2S_DeInit(SPI3);
      SPI_I2S_DeInit(SPI2);
    /* I2S peripheral configuration */
    I2S_InitStructure.I2S_Standard = I2S_Standard_Phillips;
    I2S_InitStructure.I2S_DataFormat = I2S_DataFormat_24b; /* I also tried it with 32b... nothing */
    I2S_InitStructure.I2S_MCLKOutput = I2S_MCLKOutput_Enable;
    I2S_InitStructure.I2S_AudioFreq = I2S_AudioFreq_8k;
    I2S_InitStructure.I2S_CPOL = I2S_CPOL_Low;
    I2S_InitStructure.I2S_Mode = I2S_Mode_MasterRx;
    I2S_Init(SPI3, &I2S_InitStructure);
      I2S_InitStructure.I2S_AudioFreq = I2S_AudioFreq_48k;
      /* I2S2 configuration */
      I2S_InitStructure.I2S_Mode = I2S_Mode_MasterTx;
      I2S_Init(SPI2, &I2S_InitStructure);
      /* Enable the I2S3 RxNE interrupt */
      SPI_I2S_ITConfig(SPI3, SPI_I2S_IT_RXNE, ENABLE);
      /* Enable the I2S2 TxE interrupt */
      SPI_I2S_ITConfig(SPI2, SPI_I2S_IT_TXE, ENABLE);
      /* Enable the I2S3 */
      I2S_Cmd(SPI3, ENABLE);
      /* Enable the I2S2 */
      I2S_Cmd(SPI2, ENABLE);
//配置系统时钟,使能各外设时钟
void RCC_Configuration(void)
SystemInit();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA
                           |RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
                           |RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE
   |RCC_APB2Periph_ADC1  | RCC_APB2Periph_AFIO
                           |RCC_APB2Periph_SPI1, ENABLE );
  // RCC_APB2PeriphClockCmd(RCC_APB2Periph_ALL ,ENABLE );
     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4
                           |RCC_APB1Periph_USART3|RCC_APB1Periph_TIM2
                           , ENABLE );
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
//配置所有外设
void Init_All_Periph(void)
RCC_Configuration();
InitDis();
GPIO_Configuration();
I2S_Configuration();
NVIC_Configuration();
USART1_Configuration();
USART1Write((u8*)"    FireBull  GPIO_example",sizeof("    FireBull  GPIO_example"));
void Delay(vu32 nCount)
  for(; nCount != 0; nCount--);
int main(void)
Init_All_Periph();
        while(1)
            /* Turn on LD2 and LD3 */
            GPIO_SetBits(GPIOD, GPIO_Pin_8);
            /* Turn off LD1 */
            GPIO_ResetBits(GPIOD, GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11);
            /* Insert delay */
            Delay(0xEFFFF);
            GPIO_SetBits(GPIOD, GPIO_Pin_9);
            /* Turn off LD1 */
            GPIO_ResetBits(GPIOD, GPIO_Pin_8 | GPIO_Pin_10 | GPIO_Pin_11);
            /* Insert delay */
            Delay(0xEFFFF);
            /* Turn on LD4 */
            GPIO_SetBits(GPIOD, GPIO_Pin_10);
            /* Turn off LD2 and LD3 */
            GPIO_ResetBits(GPIOD, GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_11);
            /* Insert delay */
            Delay(0xEFFFF);
yinyangdianzi 发表于 2011-6-13 13:25 | 显示全部楼层
乱码看不懂
