1.2v内核电压纹波值200mv算不算大?
833|9
 楼主| wuhany 发表于 2018-4-12 10:14 | 显示全部楼层 |阅读模式
dsp的复位信号时间能不能过长,1.2v内核电压纹波值200mv算不算大?
jiahy 发表于 2018-4-12 10:16 | 显示全部楼层
连不上仿真器?
 楼主| wuhany 发表于 2018-4-12 10:21 | 显示全部楼层
连不上仿真器,不知道是什么问题?
jiaxw 发表于 2018-4-12 10:24 | 显示全部楼层
出错报告是啥
 楼主| wuhany 发表于 2018-4-12 10:27 | 显示全部楼层
Error connecting to the target:
Error 0x80000244/-1202
Fatal Error during: Register, Initialization, OCS,
CPU continually indicated it was 'not ready'
This is considered a catastrophic event, user can either force CPU ready
and continue the debug process by choosing button 'YES', or abort current
by reset the system
Sequence ID: 0
Error Code: -1202
Error Class: 0x80000244
Board Name: C6455 XDS560 Emulator
Cpu Name: C6400PLUS_0
Abort:  Close Code Composer Studio.
Retry:  Try to connect to the target again.
Cancel:  Remain disconnected from the target
Diagnostic: Run diagnostic utility.
Error 0x00000020/-2011
Error during: Execution,
An internal error occurred in which an illegal action (0x00000006) was requested while disconnected.
jiajs 发表于 2018-4-12 10:32 | 显示全部楼层
这还叫波纹?这应该叫交流电了好吧。。。波动都达到了1/6了
zhanghqi 发表于 2018-4-12 10:36 | 显示全部楼层
这个纹波你是怎么测到的    用示波器时一定减少地线环
记得示波器自带一个地线环
wyjie 发表于 2018-4-12 10:40 | 显示全部楼层
对于纹波到底大不大    需要看什么电源了   LDO的应该最小
开关电源就不好说了
jlyuan 发表于 2018-4-12 10:42 | 显示全部楼层
肯定大唉,可以看dsp手册,上面有电源要求的。
 楼主| wuhany 发表于 2018-4-12 10:46 | 显示全部楼层
搞定了,呵呵,犯了低级错误……结贴啦,多谢各位
