| 直接上程序。。 # coding:utf-8
 import itchat
 import urllib
 import  os
 import webbrowser
 import json
 from itchat.content import TEXT
 import pyttsx
 from itchat.content import *
 from aip import  AipSpeech
 import codecs
 import paho.mqtt.client as mqtt
 import mp3play
 import sys
 from pydub import AudioSegment
 import time
 import re
 reload(sys)
 sys.setdefaultencoding('utf8')
 import os
 APP_ID = '百度给的ID'
 API_KEY = '百度API_KEY'
 SECRET_KEY = '百度 SECRET_KEY'
 # 初始化AipSpeech对象
 aipSpeech = AipSpeech(APP_ID, API_KEY, SECRET_KEY)
 key = '图灵给的key'
 api = 'h t t p  : / / w w w  .t u l i n g 1 2 3 . c o m       /openapi/api?key=' + key + '&info='
 def getHtml(url):
 page = urllib.urlopen(url)
 html = page.read()
 return html
 def on_connect(client,userdata,password, rc):
 print("Connected with result code " + str(rc))
 msg_information = {}
 face_bug=None  #针对表情包的内容
 def get_file_content(filePath):
 with open(filePath, 'rb') as fp:
 return fp.read()
 @itchat.msg_register([TEXT, RECORDING, ATTACHMENT],isFriendChat=True)
 def handle_receive_msg(msg):
 names = itchat.search_friends(userName=msg['FromUserName'])['NickName']
 usera = itchat.search_friends(userName=msg['FromUserName'])
 nameb = usera['UserName']
 users = itchat.search_friends(name='雨电')
 namea = users[0]['UserName']
 print names
 print namea
 print nameb
 global face_bug
 msg_time_rec = 1022   #接受消息的时间
 #    msg_from = itchat.search_friends(userName=msg['FromUserName'])['NickName']   #在好友列表中查询发送信息的好友昵称
 msg_time = msg['CreateTime']    #信息发送的时间
 msg_id = msg['MsgId']    #每条信息的id
 msg_content = None      #储存信息的内容
 #    msg_share_url = None    #储存分享的链接,比如分享的**和音乐
 #    print msg['Type']
 #   print msg['MsgId']
 if msg['Type'] == 'Text' or msg['Type'] == 'Friends':     #接受文字信息
 msg_content = msg['Text']
 print msg_content
 info=msg_content
 if(names == '雨电'):              #判断发信息人 能否控制读取物联网硬件   这里我做了两个环境监测一个放家里一个放店里
 if (info.find('家里') !=-1 ):
 os.system(r'E:\dioyong\pobao1.py')
 engine = pyttsx.init()
 engine.say(u'家里环境监测完毕')
 engine.runAndWait()
 print u'家里环境监测完毕'
 elif (info.find('店里') !=-1 ):
 os.system(r'E:\dioyong\pobao.py')
 engine.say(u'店铺环境监测完毕')
 engine.runAndWait()
 print u'店铺环境监测完毕'
 elif (info.find('打开') !=-1 ):                 #做了一个灯控硬件
 os.system(r'E:\dioyong\dakai.py')
 engine.say(u'以为你打开灯')
 engine.runAndWait()
 print u'以为你打开灯'
 elif (info.find('拍照') !=-1 ):                      #做的两个拍照截取图片   一个是海康的监控摄像头  一个是USB摄像头
 os.system(r'E:\dioyong\cap.py')
 os.system(r'E:\dioyong\haikang.py')
 itchat.send_image("cap.png", namea)
 itchat.send_image("haikang.jpg", namea)
 elif (info.find('关闭') !=-1):
 os.system(r'E:\dioyong\guanbi.py')
 engine.say(u'以为你关闭灯')
 engine.runAndWait()
 print u'以为你关闭灯'
 elif (info.find('店里环境') ==-1 ):
 request = api + info.encode("utf8")
 response = getHtml(request)
 dic_json = json.loads(response)
 if dic_json['code']==100000:
 print '机器人: '.decode('utf-8') + dic_json['text']
 itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['text'].decode(),namea)        #图灵返回的的文字信息
 elif dic_json['code'] == 200000:
 itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['text'].decode(),namea)        #图灵返回有单个链接信息
 itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['url'].decode() , namea)
 #                   webbrowser.open_new(dic_json['url'])
 elif dic_json['code'] == 302000:
 itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['text'].decode(),namea)        #图灵返回有多个链接信息
 lis = dic_json['list']
 a=0
 while True:
 if a==2:
 break
 else:
 b= lis[a]['detailurl']
 itchat.send_msg('机器人小雨: '.decode('utf-8') +b , namea)
 #                         webbrowser.open_new(b)
 a =a+1
 elif dic_json['code'] == 308000:
 a=0
 while True:
 if a==2:
 break
 else:
 a =a+1
 f = codecs.open(r'E:\dioyong\wenxin.txt', "w",'utf-8')
 f.write(dic_json['text'])
 result  = aipSpeech.synthesis(dic_json['text'], 'zh', 1, {'spd': 4,'pit': 5,
 'vol': 5,'per':0,
 if not isinstance(result, dict):
 with open(r'E:\dioyong\auido2.mp3', 'wb') as f:
 f.write(result)
 clip = mp3play.load(r'E:\dioyong\auido2.mp3')
 clip.play()
 time.sleep(min(3000000, clip.seconds()))
 os.remove(r'E:\dioyong\auido2.mp3')
 else:
 itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['text'].decode(),nameb)
 itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['url'].decode() , nameb)
 a=0
 while True:
 if a==2:
 break
 else:
 itchat.send_msg('机器人小雨: '.decode('utf-8') +b , nameb)
 a =a+1
 a=0
 while True:
 if a==2:
 break
 else:
 a =a+1
 #如果发送的消息是附件、视屏、图片、语音
 elif msg['Type'] == "Attachment" or msg['Type'] == "Video" \          #接受朋友发的语音
 or msg['Type'] == 'Picture' \
 or msg['Type'] == 'Recording':
 msg_content = msg['FileName']
 msg['Text'](msg_content)
 print msg_content
 sound = AudioSegment.from_mp3(msg_content)
 sound.export(r'02.wav' , format = "wav")
 result = aipSpeech.asr(get_file_content(r'02.wav'), 'wav', 8000, {
 'lan': 'zh',
 print result['result'][0]
 info=result['result'][0]
 if(names == '雨电'):
 engine.runAndWait()
 print u'家里环境监测完毕'
 engine.runAndWait()
 print u'店铺环境监测完毕'
 engine.runAndWait()
 print u'以为你打开灯'
 engine.runAndWait()
 print u'以为你关闭灯'
 itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['text'].decode() , namea)
 itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['url'] , namea)
 a=0
 while True:
 if a==2:
 break
 else:
 a =a+1
 a=0
 while True:
 if a==2:
 break
 else:
 a =a+1
 'vol': 5,'per':0,
 f.write(result)
 clip.play()
 else:
 itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['url'] , nameb)
 a=0
 while True:
 if a==2:
 break
 else:
 a =a+1
 a=0
 while True:
 if a==2:
 break
 else:
 a =a+1
 itchat.auto_login(hotReload=True)
 itchat.send_msg()
 itchat.run()
 本来还想通过mqtt客户端接受到检测信号,让微信机器人主动给某个好友或几个好友发送信息的。。用以做报警或预警用的 一直没弄得起来mqtt客户端(要保持长期运行)没办法和微信机器人(也要保持长期运行)程序同时运行。。。由于本人能力不足。试了多进程和变量共享都没有成功。。。。希望有大神帮忙指点指点。
