DSP能连上,但下载不了程序
2826|2
 楼主| 风声112 发表于 2018-6-21 09:19 | 显示全部楼层 |阅读模式
最近做的乘用车主驱板上的DSP能连上CCS6.0软件,但是不能下载程序,报错误如下,麻烦高手指点一下,谢谢。C28xx: Failed CPU Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.507.0)
C28xx: Trouble Reading Register PC: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.507.0)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.507.0)
C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1         at (ST1&~(0x0100)) [f28035.gel:281]         at C28x_Mode() [f28035.gel:32]         at OnReset(1) .
C28xx: Trouble Writing Memory Block at 0xae0 on Page 1 of Length 0x1: (Error -1137 @ 0xAE1) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.507.0)
C28xx: Trouble Writing Memory Block at 0xae1 on Page 1 of Length 0x1: (Error -1137 @ 0xAE2) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.507.0)
C28xx: Trouble Writing Memory Block at 0xae2 on Page 1 of Length 0x1: (Error -1137 @ 0xAE3) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.507.0)
C28xx: Trouble Writing Memory Block at 0xae3 on Page 1 of Length 0x1: (Error -1137 @ 0xAE4) Device is held in reset. Take t
jjjyufan 发表于 2018-6-21 09:40 | 显示全部楼层
原理图放上来看看
jjjyufan 发表于 2018-6-21 09:42 | 显示全部楼层
5 43 59 脚是1v8 别接到3v3了
