上回我们说到了MG32F02A的TIM26进行PWM波形输出。帖子详情:https://bbs.21ic.com/icview-2556460-1-1.html
作为调试的一个极好用的方式,随时使用串口输出能够输出一些有用的信息用于帮助你调试,所以这次就来学习一下串口的使用吧。
程序如下:
- #include "MG32x02z_DRV.H"
- #include <stdio.h>
- #define URTX URT0
- typedef uint8_t u8;
- typedef uint16_t u16;
- typedef uint32_t u32;
- typedef uint64_t u64;
- void CSC_Init (void)
- CSC_PLL_TyprDef CSC_PLL_CFG;
- UnProtectModuleReg(MEMprotect); // Setting flash wait state
- MEM_SetFlashWaitState(MEM_FWAIT_ONE); // 50MHz> Sysclk >=25MHz
- ProtectModuleReg(MEMprotect);
- UnProtectModuleReg(CSCprotect);
- CSC_CK_APB_Divider_Select(APB_DIV_1); // Modify CK_APB divider APB=CK_MAIN/1
- CSC_CK_AHB_Divider_Select(AHB_DIV_1); // Modify CK_AHB divider AHB=APB/1
- /* CK_HS selection */
- CSC_IHRCO_Select(IHRCO_12MHz); // IHRCO Sel 12MHz
- CSC_IHRCO_Cmd(ENABLE);
- while(CSC_GetSingleFlagStatus(CSC_IHRCOF) == DRV_Normal);
- CSC_ClearFlag(CSC_IHRCOF);
- CSC_CK_HS_Select(HS_CK_IHRCO); // CK_HS select IHRCO
- /* PLL */
- CSC_PLL_CFG.InputDivider=PLLI_DIV_2; // 12M/2=6M
- CSC_PLL_CFG.Multiplication=PLLIx16; // 6M*16=96M
- CSC_PLL_CFG.OutputDivider=PLLO_DIV_2; // PLLO=96M/2=48M
- CSC_PLL_Config(&CSC_PLL_CFG);
- CSC_PLL_Cmd(ENABLE);
- while(CSC_GetSingleFlagStatus(CSC_PLLF) == DRV_Normal);
- CSC_ClearFlag(CSC_PLLF);
- /* CK_MAIN */
- CSC_CK_MAIN_Select(MAIN_CK_HS);
- /* Configure ICKO function */
- /* Configure peripheral clock */
- CSC_PeriphProcessClockSource_Config(CSC_UART0_CKS, CK_APB);
- CSC_PeriphOnModeClock_Config(CSC_ON_UART0,ENABLE);
- CSC_PeriphOnModeClock_Config(CSC_ON_PortB,ENABLE);
- ProtectModuleReg(CSCprotect);
- int fputc(int ch,FILE *f)
- URT_SetTXData(URTX,1,ch);
- while(URT_GetITSingleFlagStatus(URTX,URT_IT_TC)==DRV_UnHappened);
- URT_ClearITFlag(URTX,URT_IT_TC);
- return ch;
- void UartSendByte(int ch)
- void URT0_Init(void)
- URT_BRG_TypeDef URT_BRG;
- URT_Data_TypeDef DataDef;
- PIN_InitTypeDef PINX_InitStruct;
- //==Set GPIO init
- //PB8 PPO TX ,PB9 ODO RX
- PINX_InitStruct.PINX_Mode = PINX_Mode_PushPull_O; // Pin select Push Pull mode
- PINX_InitStruct.PINX_PUResistant = PINX_PUResistant_Enable; // Enable pull up resistor
- PINX_InitStruct.PINX_Speed = PINX_Speed_Low;
- PINX_InitStruct.PINX_OUTDrive = PINX_OUTDrive_Level0; // Pin output driver full strength.
- PINX_InitStruct.PINX_FilterDivider = PINX_FilterDivider_Bypass; // Pin input deglitch filter clock divider bypass
- PINX_InitStruct.PINX_Inverse = PINX_Inverse_Disable; // Pin input data not inverse
- PINX_InitStruct.PINX_Alternate_Function = PB8_AF_URT0_TX; // Pin AFS = URT0_TX
- GPIO_PinMode_Config(PINB(8),&PINX_InitStruct); // TXD at PB8
- PINX_InitStruct.PINX_Mode = PINX_Mode_OpenDrain_O; // Pin select Open Drain mode
- PINX_InitStruct.PINX_Alternate_Function = PB9_AF_URT0_RX; // Pin AFS = URT0_RX
- GPIO_PinMode_Config(PINB(9),&PINX_InitStruct); // RXD at PB9
- //=====Set Clock=====//
- //---Set BaudRate---//
- URT_BRG.URT_InteranlClockSource = URT_BDClock_PROC;
- URT_BRG.URT_BaudRateMode = URT_BDMode_Separated;
- URT_BRG.URT_PrescalerCounterReload = 0; //Set PSR
- URT_BRG.URT_BaudRateCounterReload = 3; //Set RLR
- URT_BaudRateGenerator_Config(URTX, &URT_BRG); //BR115200 = f(CK_URTx)/(PSR+1)/(RLR+1)/(OS_NUM+1)
- URT_BaudRateGenerator_Cmd(URTX, ENABLE); //Enable BaudRateGenerator
- //---TX/RX Clock---//
- URT_TXClockSource_Select(URTX, URT_TXClock_Internal); //URT_TX use BaudRateGenerator
- URT_RXClockSource_Select(URTX, URT_RXClock_Internal); //URT_RX use BaudRateGenerator
- URT_TXOverSamplingSampleNumber_Select(URTX, 25); //Set TX OS_NUM
- URT_RXOverSamplingSampleNumber_Select(URTX, 25); //Set RX OS_NUM
- URT_RXOverSamplingMode_Select(URTX, URT_RXSMP_3TIME);
- URT_TX_Cmd(URTX, ENABLE); //Enable TX
- URT_RX_Cmd(URTX, ENABLE); //Enable RX
- //=====Set Mode=====//
- //---Set Data character config---//
- DataDef.URT_TX_DataLength = URT_DataLength_8;
- DataDef.URT_RX_DataLength = URT_DataLength_8;
- DataDef.URT_TX_DataOrder = URT_DataTyped_LSB;
- DataDef.URT_RX_DataOrder = URT_DataTyped_LSB;
- DataDef.URT_TX_Parity = URT_Parity_No;
- DataDef.URT_RX_Parity = URT_Parity_No;
- DataDef.URT_TX_StopBits = URT_StopBits_1_0;
- DataDef.URT_RX_StopBits = URT_StopBits_1_0;
- DataDef.URT_TX_DataInverse = DISABLE;
- DataDef.URT_RX_DataInverse = DISABLE;
- URT_DataCharacter_Config(URTX, &DataDef);
- //---Set Mode Select---//
- URT_Mode_Select(URTX, URT_URT_mode);
- //---Set DataLine Select---//
- URT_DataLine_Select(URTX, URT_DataLine_2);
- //=====Set Data Control=====//
- URT_RXShadowBufferThreshold_Select(URTX, URT_RXTH_1BYTE);
- URT_IdlehandleMode_Select(URTX, URT_IDLEMode_No);
- URT_TXGaudTime_Select(URTX, 0);
- //=====Enable URT Interrupt=====//
- //URT_IT_Cmd(URTX, URT_IT_RX, ENABLE);
- //URT_ITEA_Cmd(URTX, ENABLE);
- //NVIC_EnableIRQ(URT0_IRQn);
- //=====Enable URT=====//
- URT_Cmd(URTX, ENABLE);
- //==See MG32x02z_URT0_IRQ.c when interrupt in
- int main()
- CSC_Init();
- URT0_Init();
- printf("Hello!\n");
这个程序里做了printf重定向,这样要输出信息直接用printf就好了。
