济南能华机电设备有限公司生产的NHWY系列开关型直流稳压稳流电源电压电流值从零至额定值连续可调,恒压恒流自动转换,在额定范围内任意选择且限制保护点。电压、电流同时 LED 数码管显示。产品具备完善的保护功能。内置温控散热风扇,既能有效散热,又能有效延长风扇寿命;过热自动关机保护;输出过压、过流和短路保护。开机避免开机输出电压过冲。产品可多台并串机,实现功率扩容。
目前NHWY系列开关型直流稳压稳流电源广泛应用于电力、工控、通信、科研、铁路、汽车、船舶、蓄电池充电、航空航天、表面处理、电化学、新能源、电容器、电机、污水处理、电子产品生产检测、LED照明、加热、地质勘探、医疗等行业。国内已有众多企业单位使用NHWY系列直流稳压稳流电源用于产品测试和老化,另外众多科研单位、研究所、航空电器、有色金属等单位,使用此电源进行高精度高强度电源供应下的科研工作,广受好评。
污水处理脉冲电源
更多直流可调电源300V高压直流稳压电源生产厂家详情浏览以下网站:
http://www.nenghua004.com/index.html
http://www.nenghua004.com/cp/fd/
http://www.nenghua004.com/cp/hy/
http://www.nenghua004.com/cp/gy/
http://www.nenghua004.com/cp/mc/
http://www.nenghua004.com/cp/ck/
http://www.nenghua004.com/cp/kg/
http://www.nenghua004.com/cp/fd/hx/1732.html
http://www.nenghua004.com/cp/hy/yx/1634.html
http://www.nenghua004.com/cp/hy/yl/
http://www.nenghua004.com/cp/hy/kt/
http://www.nenghua004.com/cp/hy/dzyj/1601.html
http://www.nenghua004.com/cp/hy/dzyj/1602.htm
http://www.nenghua004.com/cp/hy/dzyj/1600.html
http://www.nenghua004.com/cp/hy/dzyj/1592.html
http://www.nenghua004.com/cp/hy/dzyj/1597.html
http://www.nenghua004.com/cp/hy/dzyj/1599.html
http://www.nenghua004.com/cp/hy/dzyj/1596.html
http://www.nenghua004.com/cp/hy/dzyj/1594.html
http://www.nenghua004.com/cp/hy/dzyj/1593.html
http://www.nenghua004.com/cp/hy/dzyj/1595.html
http://www.nenghua004.com/cp/hy/dzyj/1638.html
http://www.nenghua004.com/cp/hy/dzyj/1605.html
http://www.nenghua004.com/cp/hy/dzyj/1640.html
http://www.nenghua004.com/cp/hy/dzyj/list_180_3.htm
http://www.nenghua004.com/cp/hy/dzyj/1591.html
http://www.nenghua004.com/cp/mc/hy/1743.html
http://www.nenghua004.com/cp/hy/yx/1632.html
http://www.nenghua004.com/cp/hy/dm/1725.html
http://www.nenghua004.com/cp/hy/jr/1735.html
http://www.nenghua004.com/cp/hy/jr/1736.html
http://www.nenghua004.com/cp/mc/hy/1532.html
http://www.nenghua004.com/cp/hy/scl/1587.html
http://www.nenghua004.com/cp/hy/drq/1737.html
http://www.nenghua004.com/cp/hy/drq/1738.html
http://www.nenghua004.com/cp/hy/dhx/1740.html
http://www.nenghua004.com/cp/hy/dhx/1728.html
http://www.nenghua004.com/cp/hy/dhx/1729.html
http://www.nenghua004.com/cp/hy/dhx/1739.html
http://www.nenghua004.com/cp/hy/dhx/1726.html
http://www.nenghua004.com/cp/hy/dhx/1731.html
http://www.nenghua004.com/cp/hy/1724.html
http://www.nenghua004.com/cp/hy/dzyj/1598.html
http://www.nenghua004.com/cp/hy/1723.html
http://www.nenghua004.com/cp/hy/1721.html
http://www.nenghua004.com/cp/hy/zldj/1720.html
http://www.nenghua004.com/cp/hy/zldj/1589.html
http://www.nenghua004.com/cp/hy/jg/1647.html
http://www.nenghua004.com/cp/hy/jg/1646.html
http://www.nenghua004.com/cp/hy/jg/1645.html
http://www.nenghua004.com/cp/hy/jg/1644.html
http://www.nenghua004.com/cp/hy/jg/1649.html
http://www.nenghua004.com/cp/hy/jg/1648.html
http://www.nenghua004.com/cp/hy/tl/1643.html
http://www.nenghua004.com/cp/hy/tl/1641.html
http://www.nenghua004.com/cp/hy/tl/1642.html
http://www.nenghua004.com/cp/hy/qc/1719.html
http://www.nenghua004.com/cp/hy/qc/1584.html
http://www.nenghua004.com/cp/hy/qc/1578.html
http://www.nenghua004.com/cp/hy/qc/1579.html
http://www.nenghua004.com/cp/hy/qc/1580.html
http://www.nenghua004.com/cp/hy/qc/1581.htm
http://www.nenghua004.com/cp/hy/qc/1583.html
http://www.nenghua004.com/cp/hy/qc/1582.html
http://www.nenghua004.com/cp/hy/qc/1576.html
http://www.nenghua004.com/cp/hy/qc/1574.html
http://www.nenghua004.com/cp/hy/qc/1575.html
http://www.nenghua004.com/cp/hy/qc/1573.html
http://www.nenghua004.com/cp/hy/qc/1577.html
http://www.nenghua004.com/cp/hy/yx/1633.html
http://www.nenghua004.com/cp/mc/hy/1535.html
http://www.nenghua004.com/cp/mc/hy/1534.html
http://www.nenghua004.com/cp/mc/1742.html
http://www.nenghua004.com/cp/mc/1745.html
http://www.nenghua004.com/cp/mc/gymc/
http://www.nenghua004.com/cp/mc/hxmc/
http://www.nenghua004.com/cp/mc/dmc/
http://www.nenghua004.com/cp/hy/yx/1628.html
http://www.nenghua004.com/cp/hy/yx/1624.html
http://www.nenghua004.com/cp/hy/yx/1630.html
http://www.nenghua004.com/cp/gy/dy/1449.html
http://www.nenghua004.com/cp/gy/dy/1450.html
http://www.nenghua004.com/cp/gy/dy/1451.html
http://www.nenghua004.com/cp/gy/dy/1452.html
http://www.nenghua004.com/cp/gy/dy/1453.html
http://www.nenghua004.com/cp/gy/dy/1454.html
http://www.nenghua004.com/cp/gy/dy/1455.html
http://www.nenghua004.com/cp/gy/dy/1456.html
http://www.nenghua004.com/cp/gy/dy/1457.html
http://www.nenghua004.com/cp/gy/dy/1458.html
http://www.nenghua004.com/cp/gy/dy/1459.html
http://www.nenghua004.com/cp/gy/dy/1460.html
http://www.nenghua004.com/cp/ck/gl/1461.html
http://www.nenghua004.com/cp/ck/gl/1482.html
http://www.nenghua004.com/cp/ck/gl/1483.html
http://www.nenghua004.com/cp/ck/gl/1484.html
http://www.nenghua004.com/cp/ck/gl/1485.html
http://www.nenghua004.com/cp/ck/gl/1487.html
http://www.nenghua004.com/cp/ck/gl/1489.html
http://www.nenghua004.com/cp/ck/gl/1490.html
http://www.nenghua004.com/cp/ck/gl/1491.html
http://www.nenghua004.com/cp/ck/gl/1492.html
http://www.nenghua004.com/cp/ck/gl/1493.html
http://www.nenghua004.com/cp/ck/gl/1494.html
http://www.nenghua004.com/cp/ck/gl/1495.html
http://www.nenghua004.com/cp/kg/gl/1512.html
http://www.nenghua004.com/cp/kg/gl/1513.html
http://www.nenghua004.com/cp/kg/gl/1514.html
http://www.nenghua004.com/cp/kg/gl/1515.html
http://www.nenghua004.com/cp/kg/gl/1516.html
http://www.nenghua004.com/cp/kg/gl/1517.html
http://www.nenghua004.com/cp/kg/gl/1518.html
http://www.nenghua004.com/cp/kg/gl/1519.html
http://www.nenghua004.com/cp/kg/gl/1520.html
http://www.nenghua004.com/cp/kg/gl/1521.html
http://www.nenghua004.com/cp/kg/gl/1522.html
http://www.nenghua004.com/cp/kg/gl/1523.html
http://www.nenghua004.com/cp/kg/gl/1524.html
http://www.nenghua004.com/cp/kg/dy/1689.html
http://www.nenghua004.com/cp/kg/dy/1690.html
http://www.nenghua004.com/cp/kg/dy/1691.html
http://www.nenghua004.com/cp/kg/dy/1692.html
http://www.nenghua004.com/cp/kg/dy/1693.html
http://www.nenghua004.com/cp/kg/dy/1694.html
http://www.nenghua004.com/cp/kg/dy/1695.html
http://www.nenghua004.com/cp/kg/dy/1696.html
http://www.nenghua004.com/cp/kg/dy/1697.html
http://www.nenghua004.com/cp/kg/dy/1698.html
http://www.nenghua004.com/cp/kg/dy/1699.html
http://www.nenghua004.com/cp/kg/dy/1701.html
http://www.nenghua004.com/cp/kg/dy/1700.html
http://www.nenghua004.com/cp/kg/dy/1702.html
http://www.nenghua004.com/cp/kg/dy/1703.html
http://www.nenghua004.com/cp/kg/dy/1704.html
http://www.nenghua004.com/cp/kg/dy/1705.html
http://www.nenghua004.com/cp/kg/dy/1706.html
http://www.nenghua004.com/cp/kg/dy/1707.html
http://www.nenghua004.com/cp/kg/dy/1708.html
http://www.nenghua004.com/cp/fd/jsdd/
http://www.nenghua004.com/cp/fd/ds/
http://www.nenghua004.com/cp/fd/zw/
http://www.nenghua004.com/cp/fd/swj/
http://www.nenghua004.com/cp/fd/plc/
http://www.nenghua004.com/cp/fd/yj/
http://www.nenghua004.com/cp/fd/n+1/
http://www.nenghua004.com/cp/fd/ll/
http://www.nenghua004.com/cp/fd/kgj/
http://www.nenghua004.com/cp/hy/dydq/
http://www.nenghua004.com/cp/hy/ckjs/
http://www.nenghua004.com/cp/hy/bm/
http://www.nenghua004.com/cp/hy/xny/
http://www.nenghua004.com/cp/gy/gl/
http://www.nenghua004.com/cp/gy/hy/
http://www.nenghua004.com/mcsy/
http://www.nenghua004.com/dd/
http://www.nenghua004.com/whyh/
http://www.nenghua004.com/mchl/
http://www.nenghua004.com/dxn/
http://www.nenghua004.com/cp/mc/gp/
http://www.nenghua004.com/cp/ck/dy/
http://www.nenghua004.com/hldy/
http://www.nenghua004.com/kgdy/
http://www.nenghua004.com/hlhy/
http://www.nenghua004.com/lh/
http://www.nenghua004.com/kg/
http://www.nenghua004.com/bat/
http://www.nenghua004.com/jy/
http://www.nenghua004.com/hx/
http://www.nenghua004.com/cp/list_3_22.html
http://www.nenghua004.com/cp/list_3_2.html
http://www.nenghua004.com/cp/list_3_11.html
http://www.nenghua004.com/cp/list_3_10.html
http://www.nenghua004.com/cp/list_3_9.html
http://www.nenghua004.com/cp/list_3_8.html
http://www.nenghua004.com/cp/list_3_7.html
http://www.nenghua004.com/cp/list_3_6.html
http://www.nenghua004.com/cp/list_3_5.html
http://www.nenghua004.com/cp/list_3_4.html
http://www.nenghua004.com/cp/list_3_3.htmlhttp://www.nenghua004.com/cp/list_3_12.html
http://www.nenghua004.com/cp/list_3_16.html
http://www.nenghua004.com/cp/list_3_15.html
http://www.nenghua004.com/cp/list_3_14.html
http://www.nenghua004.com/cp/list_3_13.html
http://www.nenghua004.com/cp/gy/list_41_1.html
http://www.nenghua004.com/xinwen/list_2_92.html
http://www.nenghua004.com/xinwen/list_2_91.html
http://www.nenghua004.com/xinwen/list_2_90.html
http://www.nenghua004.com/xinwen/list_2_89.html
http://www.nenghua004.com/xinwen/list_2_88.html
http://www.nenghua004.com/xinwen/list_2_1.html
http://www.leilatu.com.cn
http://www.leilatu.com.cn/chanpinshijie/kbc/54.html
http://www.leilatu.com.cn/chanpinshijie/zqhx/55.html
http://www.leilatu.com.cn/chanpinshijie/xdcmn/56.html
http://www.leilatu.com.cn/chanpinshijie/bj/57.html
http://www.leilatu.com.cn/chanpinshijie/scl/60.html
http://www.leilatu.com.cn/chanpinshijie/scl/61.html
http://www.leilatu.com.cn/chanpinshijie/hydy/
http://www.leilatu.com.cn/chanpinshijie/jyhk/
http://www.leilatu.com.cn/chanpinshijie/sxdc/
http://www.leilatu.com.cn/chanpinshijie/dcdc/
http://www.leilatu.com.cn/chanpinshijie/mcdy/
http://www.leilatu.com.cn/chanpinshijie/ddl/
http://www.leilatu.com.cn/chanpinshijie/gyzl/
http://www.leilatu.com.cn/chanpinshijie/ckzl/
http://www.leilatu.com.cn/chanpinshijie/zlwydy/
http://www.leilatu.com.cn/chanpinshijie/list_19_3.html
http://www.leilatu.com.cn/chanpinshijie/list_19_2.html
http://www.leilatu.com.cn/chanpinshijie/hydy/qqdy/
http://www.leilatu.com.cn/chanpinshijie/hydy/djcs/
http://www.leilatu.com.cn/chanpinshijie/ddl/50.html
http://www.leilatu.com.cn/chanpinshijie/ckzl/48.html
http://www.leilatu.com.cn/chanpinshijie/zlwydy/47.html
http://www.leilatu.com.cn/chanpinshijie/gyzl/49.html
http://www.leilatu.com.cn/chanpinshijie/mcdy/51.html
http://www.leilatu.com.cn/chanpinshijie/mcdy/52.html
http://www.leilatu.com.cn/chanpinshijie/mcdy/53.html
http://www.leilatu.com.cn/chanpinshijie/list_19_1.html
