关于DSP28335 GPIO模块的各寄存器
816|0
 楼主| Jasmines 发表于 2018-12-2 13:10 | 显示全部楼层 |阅读模式
DSP28335 GPIO模块分为三类IO口:PORTA(0-31),PORTB(32-63),PORTC(64-87)
对GPIO模块的设置主要通过三类寄存器来完成,分别是:控制寄存器、数据寄存器、中断寄存器。
1、控制寄存器
  GPxCTRL;    // GPIO x Control Register (GPIO0 to 31)
              //设置采样窗周期T=2*GPXCTRL*Tsysclk;
  GPxQSEL1;   // GPIO x Qualifier Select 1 Register (GPIO0 to 15)(32-47)
  GPxQSEL2;   // GPIO x Qualifier Select 2 Register (GPIO16 to 31)(48-63)
              //每两位控制一个引脚,确定是3周期采样还是6周期采样或者不用采样
  GPxMUX1;    // GPIO x Mux 1 Register (GPIO0 to 15)(32-47)(64-79)
  GPxMUX2;    // GPIO x Mux 2 Register (GPIO16 to 31)(48-63)(80-95)
              //配置各个引脚的功能,0:I/O功能,1:外设功能。
  GPxDIR;     // GPIO x Direction Register (GPIO0 to 31)(32-63)(64-95)
              //配置每个引脚是输入还是输出,0:数字量输入;1:数字量输出。
  GPxPUD;     // GPIO x Pull Up Disable Register (GPIO0 to 31)(32-63)(64-95)
              //使能或禁止jie口的内部上拉
2、数据寄存器
  GPxDAT;     // GPIO Data Register (GPIO0 to 31)(32-63)(64-95)
  GPxSET;     // GPIO Data Set Register (GPIO0 to 31)(32-63)(64-95)
  GPxCLEAR;   // GPIO Data Clear Register (GPIO0 to 31)(32-63)(64-95)
  GPxTOGGLE;  // GPIO Data Toggle Register (GPIO0 to 31)(32-63)(64-95)
3、中断寄存器
   GPIOXINT1SEL; // XINT1 GPIO Input Selection
   GPIOXINT2SEL; // XINT2 GPIO Input Selection
   GPIOXNMISEL;  // XNMI_Xint13 GPIO Input Selection
   GPIOXINT3SEL; // XINT3 GPIO Input Selection
   GPIOXINT4SEL; // XINT4 GPIO Input Selection
   GPIOXINT5SEL; // XINT5 GPIO Input Selection
   GPIOXINT6SEL; // XINT6 GPIO Input Selection
   GPIOXINT7SEL; // XINT7 GPIO Input Selection
   GPIOLPMSEL;   // Low power modes GP I/O input select
可以对GPIO0-63进行外部中断设置
