用VC程序能向C68013写数据,但是读不到数据
841|1
 楼主| Leeu9527 发表于 2018-12-3 17:24 | 显示全部楼层 |阅读模式
why can not read data from  bulkin endpoint 0x86
烧写了slavefifo的固件 slave.iic到芯片的eeprom里了。用自带的 streamer.exe和bulkloop.exe但是只能写,但时回读不到数据。 但是同样的硬件,用labview却是可以读写数据的。
请大神指导下,可能问题出在哪里。
下载了bulkloop.iic之后,完全没法用,芯片被搞挂了,也不能烧回来。
I am using C68013 chip.  I have downloaded the firmware from  AN61345 - Source code slave fifo  slave.iic.
using the newest driver  1.2.3.20 by 11/08/2017 on windows 7 x64.
the FPGA code is OK,  we can wirte and read data using NI-VISA driver and Labview program.
But,
I can write the data to C68013,  but can not read data from C68013.
Here is the VC++ code.  I also used the usb bus hound to look the data , there is also no data in to PC.
please help me, thank you very much!
// out endpoint  is ok
bool UsbTest::SendUsbData(unsigned char *wdata, long writeLength)
CCyUSBEndPoint *epBulkOut = m_usbDev->EndPointOf(2);
bool rst = epBulkOut->XferData(wdata, writeLength);
printf("send usb data ok\n");
return rst;
void UsbTest::RecvUsbData()
    long nCount = 0;
    long BytesXferred = 0;
    long outTransferred = 0;
bool m_bBulkLoopCompleted = false;
CCyUSBEndPoint *epBulkIn = m_usbDev->EndPointOf(0x86); // in传输   0x86
if (NULL == epBulkIn)
printf("epBulkIn is NULL\n");
return;
long totalTransferSize = epBulkIn->MaxPktSize * 16;
//epBulkIn->SetXferSize(10);
//epBulkIn->TimeOut = 1200;
unsigned char data[512] = { 0 };
OVERLAPPED inOvLap;
inOvLap.hEvent = CreateEvent(NULL, false, false, NULL);
        long readLength = 10;
UCHAR *inContext = epBulkIn->BeginDataXfer(data, readLength, &inOvLap);
if (epBulkIn->NtStatus || epBulkIn->UsbdStatus)
printf("BeginDataXfer Failed with (NT Status = 0x%X and USBD Status = 0x%X). Bailing out...\n", epBulkIn->NtStatus, epBulkIn->UsbdStatus);
        //////////Wait till the transfer completion..///////////////////////////
        if (!epBulkIn->WaitForXfer(&inOvLap, 150))
            epBulkIn->Abort();
if (epBulkIn->LastError == ERROR_IO_PENDING)
WaitForSingleObject(inOvLap.hEvent, 1500);
        ////////////Read the trasnferred data from the device///////////////////////////////////////
bool success = epBulkIn->FinishDataXfer(data, readLength, &inOvLap, inContext);
printf("read usb data ok\n");
for (int idx = 0; idx < 64; ++idx)
printf(" 0x%x, ", data[idx]);
Sleep(300000);
