[STM32L1] STM32L152 DHT12 i2c读取 死循环
1552|13
 楼主| lq2001happy 发表于 2018-12-18 20:05 | 显示全部楼层 |阅读模式
现在选用的STM32L52  去读取DHT12  通过I2C1  PB6 PB7 去读取,老是进入死循环,读取不了数据
原代码如下:
void I2C_IO_Init(void)
        I2C_InitTypeDef I2C_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOB, ENABLE);
        RCC_APB1PeriphClockCmd( RCC_APB1Periph_I2C1, ENABLE);
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_I2C1);
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_I2C1);
//        GPIOB->AFR[0] = 0x04;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
        GPIO_Init( GPIOB, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
        I2C_DeInit(I2C1);
        I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;//I2C_Mode_SMBusHost;//I2C_Mode_I2C;                                                //I2C¶¨Òå
        I2C_InitStructure.I2C_DutyCycle =  I2C_DutyCycle_2;
        I2C_InitStructure.I2C_OwnAddress1 = 0xa0;                                                //É豸×Ô¼ºµÄµØÖ· ----  ×÷Ϊ´ÓÉ豸ʱÓÐÓÃ
        I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
        I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
        I2C_InitStructure.I2C_ClockSpeed = 300000;
                I2C_Init(I2C1, &I2C_InitStructure);
        I2C_Cmd(I2C1,ENABLE);
        I2C_AcknowledgeConfig(I2C1, ENABLE);
//*********  ¶Áȡһ¸öÊý¾Ý  ***************
void I2C1_ReadByte( uchar ReadAddr, uchar *buf, uchar len)
        uchar i;
        I2C_AcknowledgeConfig( I2C1, ENABLE);                                                        //ʹÄÜÓ¦´ð  -----  Ô­À´Ã»ÓÐ
        while( I2C_GetFlagStatus( I2C1, I2C_FLAG_BUSY));        //µÈ´ýI2C²»Ã¦   wait i2c bus is not busy  µÈ´ý×ÜÏ߸´Î»
        I2C_GenerateSTART( I2C1, ENABLE);        //²úÉúÆðʼÐźŠ send start condition  ·¢ËÍÒ»¸ö¿ªÊ¼Î»
        while( !I2C_CheckEvent( I2C1, I2C_EVENT_MASTER_MODE_SELECT)) ;        //EV5  test on EV5 and clear it  µÈ´ýEV5
        I2C_Send7bitAddress( I2C1, ReadAddr, I2C_Direction_Transmitter);                //·¢Ë͵ØÖ·  send ADXL address for write ·¢ËÍÒ»¸öαдָÁî
        while( !I2C_CheckEvent( I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)) ;        //EV6  test on EV6 and clear it µÈ´ýEV6
        I2C_SendData( I2C1, 0);//ReadAddr);                //·¢ËͶÁµØÖ·   REG_HUMIDITY_HIGH
        //while( I2C_GetFlagStatus( I2C1, I2C_FLAG_BTF) == RESET) ;
        while( !I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED)) ;                //ÁíÍâÒ»ÖÖд·¨
        I2C_Send7bitAddress( I2C1, ReadAddr+1, I2C_Direction_Receiver);        //send ADXL address for read ·¢ËÍÒ»¸öαдָÁî
        while( I2C_GetFlagStatus(I2C1, I2C_FLAG_ADDR) == RESET) ;
        //while( !I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)) ;        //ÁíÍâÒ»ÖÖд·¨
        for( i = 0 ; i < len; i++)
                                while( !I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED)) ;
                                *buf = I2C_ReceiveData(I2C1);
                                buf++;
        I2C_AcknowledgeConfig( I2C1, DISABLE);                //disable acknowledgement
        I2C_GenerateSTOP( I2C1, ENABLE);                        //·¢ËÍֹͣλ
读取程序:
void ReadEnvirTempAndHump()
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
        SET_POWER();
        SET_NOINVASSENSOR();
        GPIO_SetBits( GPIOB, GPIO_Pin_6);
        Delay(10000);
        I2C_IO_Init();
        Delay(5000);
        I2C1_ReadByte( DHT12_I2C_ADDRESS, SendData, 5);
 楼主| lq2001happy 发表于 2018-12-18 20:06 | 显示全部楼层
一般都死在
这句话下面。
哪位大神,知道是怎么回事的。都忙了两天了
 楼主| lq2001happy 发表于 2018-12-18 20:16 | 显示全部楼层
有哪位大神做过类似的项目的
 楼主| lq2001happy 发表于 2018-12-18 20:55 | 显示全部楼层
有哪位大神有相关的调试经验的,谢谢
Prry 发表于 2018-12-19 00:06 | 显示全部楼层
大兄弟,用模拟i2c呀。
 楼主| lq2001happy 发表于 2018-12-19 08:28 | 显示全部楼层
我这上面挂了两个i2c器件,想着用模拟太烦了,所以想把这个调试通了
 楼主| lq2001happy 发表于 2018-12-19 08:35 | 显示全部楼层
我现在是  SCL  ---PB6 能看到波形图,  SDA---PB7 一直是低信号
 楼主| lq2001happy 发表于 2018-12-19 09:26 | 显示全部楼层
while( !I2C_CheckEvent( I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)) ;
现在是到这一步就死机?????
keaibukelian 发表于 2019-1-1 16:30 | 显示全部楼层
自己用普通的管脚模拟一下试试看
paotangsan 发表于 2019-1-1 16:32 | 显示全部楼层
用示波器看看 是不是严格的跟芯片要求相同
paotangsan 发表于 2019-1-1 16:33 | 显示全部楼层
估计是你时序有些许差距
paotangsan 发表于 2019-1-1 16:36 | 显示全部楼层
用示波器看看波形吧
renzheshengui 发表于 2019-1-1 16:44 | 显示全部楼层
用模拟吧  如果你确认时序没有问题的话
wakayi 发表于 2019-1-1 16:59 | 显示全部楼层
时序问题  微调一下试试看
