[微控制器/MCU] NXP低功耗蓝牙集成芯片QN9080C的时钟配置
876|0
 楼主| wdliming 发表于 2019-1-22 10:44 | 显示全部楼层 |阅读模式
********************** Configuration BOARD_BootClockRUN ***********************
/* TEXT BELOW IS USED AS SETTING FOR TOOLS *************************************
!!Configuration
called_from_default_init: true
outputs:
- {id: AHB_clock.outFreq, value: 16 MHz}
- {id: APB_clock.outFreq, value: 16 MHz}
- {id: RTC_SLETimer_clock.outFreq, value: 32.768 kHz}
- {id: RTC_clock.outFreq, value: 16 MHz}
- {id: WDT_clock.outFreq, value: 16 MHz}
settings:
- {id: SYSCON.AUTO_M_MULT.scale, value: '6'}
- {id: SYSCON.CLK_32K_SEL.sel, value: SYSCON.XTAL32K}
- {id: SYSCON.CLK_SYS_SEL.sel, value: SYSCON.XTAL_DIV}
- {id: SYSCON.XTAL_DIV.scale, value: '2', locked: true}
sources:
- {id: SYSCON.XTAL.outFreq, value: 32 MHz, enabled: true}
- {id: SYSCON.XTAL32K.outFreq, value: 32.768 kHz, enabled: true}
* BE CAREFUL MODIFYING THIS COMMENT - IT IS YAML SETTINGS FOR TOOLS **********/
* Variables for BOARD_BootClockRUN configuration
* Code for BOARD_BootClockRUN configuration
void BOARD_BootClockRUN(void)
    /* Power up/Power down the module. */
    /* Set up clock selectors - Attach clocks to the peripheries 系统时钟树的选择*/
    CLOCK_AttachClk(k32M_to_XTAL_CLK);                  /* Switch XTAL_CLK to 32M, 1: external crystal is 32 MHz,选择外部晶振32MHz*/
    CLOCK_AttachClk(kXTAL32K_to_32K_CLK);                  /* Switch 32K_CLK to XTAL32K, 0: digital 32 kHz clock source is external 32 kHz crystal,选择外部晶振32.768kHz*/
    CLOCK_AttachClk(kXTAL_to_SYS_CLK);                  /* Switch SYS_CLK to XTAL, 01: external 16/32 MHz crystal,系统时钟CLS_SYS选择外部晶振32MHz或16MHz*/
    CLOCK_AttachClk(kAPB_to_WDT_CLK);                  /* Switch WDT_CLK to APB, 1: watchdog run at APB clock,看门狗时钟选择APB时钟*/
    /* Set up dividers 设置分频*/
    CLOCK_SetClkDiv(kCLOCK_DivOsc32mClk, 1U);      /* Set OSC32M_DIV divider to value 2 = 16MHz 1: divides 32 MHz OSC clock into 16 MHz,32MHz分频16MHz*/
    CLOCK_SetClkDiv(kCLOCK_DivXtalClk, 1U);        /* Set XTAL_DIV divider to value 2, divide crystal clock when external crystal is 32 MHz, 1: the SYS_CLK is 16 MHz*/
    CLOCK_SetClkDiv(kCLOCK_DivAhbClk, 0U);         /* Set AHB_DIV divider to value 1, AHB_CLK: SYS_CLK / (AHB_DIV+1) AHP总线为16MHz/(0+1)= 16MHz*/
    CLOCK_SetClkDiv(kCLOCK_DivFrg1, 0U);           /* Set FRG_MULT1 to value 0, Set FRG_DIV1 to value 255 Flexcomm Clock Divider register*/
    CLOCK_SetClkDiv(kCLOCK_DivFrg0, 0U);           /* Set FRG_MULT0 to value 0, Set FRG_DIV0 to value 255 */
    CLOCK_SetClkDiv(kCLOCK_DivApbClk, 0U);         /* Set APB_DIV divider to value 1, APB总线=APB_CLK: AHB_CLK/(APB_DIV+1) = 16/(0+1)= 16MHz*/
    /* Enable/Disable clock out source and pins.*/
    /* Enable/Disable the specified peripheral clock.*/
以上就是NXP低功耗蓝牙集成芯片QN9080C的时钟配置案例,来自SDK,这里做了标注,就是RTC的时钟配置,代码中没有实现,只在开头处说是16MHz,以上是自己的学习记录,有错误的还请指出
个人签名:我的未来不是梦
76
