[STM32F7] STM32F767驱动蓝牙模块的问题
1466|4
 楼主| Cjy_JDxy 发表于 2019-3-3 12:00 | 显示全部楼层 |阅读模式
原理图如下:
用的UART7,PE7、PE8
程序如下:
//初始化IO 串口1
//bound:波特率
void uart_init(u32 bound)
        //UART 初始化设置
        UART7_Handler.Instance=UART7;                                            //USART1
        UART7_Handler.Init.BaudRate=bound;                                    //波特率
        UART7_Handler.Init.WordLength=UART_WORDLENGTH_8B;   //字长为8位数据格式
        UART7_Handler.Init.StopBits=UART_STOPBITS_1;            //一个停止位
        UART7_Handler.Init.Parity=UART_PARITY_NONE;                    //无奇偶校验位
        UART7_Handler.Init.HwFlowCtl=UART_HWCONTROL_NONE;   //无硬件流控
        UART7_Handler.Init.Mode=UART_MODE_TX_RX;                    //收发模式
        HAL_UART_Init(&UART7_Handler);                                            //HAL_UART_Init()会使能UART1
        HAL_UART_Receive_IT(&UART7_Handler, (u8 *)aRxBuffer, RXBUFFERSIZE);//该函数会开启接收中断:标志位UART_IT_RXNE,并且设置接收缓冲以及接收缓冲接收最大数据量
//UART底层初始化,时钟使能,引脚配置,中断配置
//此函数会被HAL_UART_Init()调用
//huart:串口句柄
void HAL_UART_MspInit(UART_HandleTypeDef *huart)
    //GPIO端口设置
        GPIO_InitTypeDef GPIO_Initure;
        if(huart->Instance==UART7)//如果是串口1,进行串口1 MSP初始化
                __HAL_RCC_GPIOE_CLK_ENABLE();                        //使能GPIOA时钟
                __HAL_RCC_UART7_CLK_ENABLE();                        //使能USART1时钟
                GPIO_Initure.Pin=GPIO_PIN_8;                        //PA9
                GPIO_Initure.Mode=GPIO_MODE_AF_PP;                //复用推挽输出
                GPIO_Initure.Pull=GPIO_PULLUP;                        //上拉
                GPIO_Initure.Speed=GPIO_SPEED_FAST;                //高速
                GPIO_Initure.Alternate=GPIO_AF7_UART7;        //复用为USART1
                HAL_GPIO_Init(GPIOE,&GPIO_Initure);                   //初始化PA9
                GPIO_Initure.Pin=GPIO_PIN_7;                        //PA10
                HAL_GPIO_Init(GPIOE,&GPIO_Initure);                   //初始化PA10
#if EN_UART7_RX
                HAL_NVIC_EnableIRQ(UART7_IRQn);                                //使能USART1中断通道
                HAL_NVIC_SetPriority(UART7_IRQn,3,3);                        //抢占优先级3,子优先级3
#endif
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
                if((USART_RX_STA&0x8000)==0)//接收未完成
                        if(USART_RX_STA&0x4000)//接收到了0x0d
                                if(aRxBuffer[0]!=0x0a)USART_RX_STA=0;//接收错误,重新开始
                                else USART_RX_STA|=0x8000;        //接收完成了
                        else //还没收到0X0D
                                if(aRxBuffer[0]==0x0d)USART_RX_STA|=0x4000;
                                else
                                        USART_RX_BUF[USART_RX_STA&0X3FFF]=aRxBuffer[0] ;
                                        USART_RX_STA++;
                                        if(USART_RX_STA>(USART_REC_LEN-1))USART_RX_STA=0;//接收数据错误,重新开始接收
//串口1中断服务程序
void UART7_IRQHandler(void)
        u32 timeout=0;
    u32 maxDelay=0x1FFFF;
#if SYSTEM_SUPPORT_OS                 //使用OS
        OSIntEnter();
#endif
        HAL_UART_IRQHandler(&UART7_Handler);        //调用HAL库中断处理公用函数
        timeout=0;
    while (HAL_UART_GetState(&UART7_Handler)!=HAL_UART_STATE_READY)//等待就绪
        timeout++;////超时处理
        if(timeout>maxDelay) break;
        timeout=0;
        while(HAL_UART_Receive_IT(&UART7_Handler,(u8 *)aRxBuffer, RXBUFFERSIZE)!=HAL_OK)//一次处理完成之后,重新开启中断并设置RxXferCount为1
        timeout++; //超时处理
        OSIntExit();
#endif
#endif
uart_init(9600);                        //串口初始化
HAL_UART_Transmit(&UART7_Handler,(uint8_t*)USART_RX_BUF,1,1000);        //发送接收到的数据
                if(USART_RX_STA&0x8000)
                        len=USART_RX_STA&0x3fff;//得到此次接收到的数据长度
                        if(USART_RX_BUF[0]=='0')                                        //开始
                        else if(USART_RX_BUF[0]=='1')                                //停止
                                StopDispose();
                        else if(USART_RX_BUF[0]=='2')                                //上松
                        else if(USART_RX_BUF[0]=='3')                                //下松
                        else if(USART_RX_BUF[0]=='4')                                //上升
                                UpDispose();
                        USART_RX_STA=0;
这个蓝牙模块我用STM32F103驱动成功了,可以和手机蓝牙助手连接互相通讯。
可是用STM32F767一点反应都没有。
请问高手,哪里有错?谢谢
 楼主| Cjy_JDxy 发表于 2019-3-3 14:13 | 显示全部楼层
顶一个
labasi 发表于 2019-3-11 14:40 | 显示全部楼层
如果能连接手机 那就不是他的问题 查一下另外一边的问题吧
 楼主| Cjy_JDxy 发表于 2019-3-11 14:50 | 显示全部楼层
知道了,买的蓝牙模块有问题。
只能和手机连,都是从机模式。
labasi 发表于 2019-4-1 12:06 | 显示全部楼层
知道了,买的蓝牙模块有问题。
只能和手机连,都是从机模式。
恭喜楼主找到了问题
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
