J-LINK下载有时候能下载下去,有时候下不进去
10256|10
 楼主| xiang_5288 发表于 2011-9-2 10:35 | 显示全部楼层 |阅读模式
为什么同样的程序同样的硬件,有时候程序能下载到flash有时候下不进去呢,提示信息如下,大家帮忙分析一下,是否有其他人也遇到过这个问题,是否是我的J-LINK不好!
* JLink Info: Found SWD-DP with ID 0x1BA01477
* JLink Info: TPIU fitted.
* JLink Info: ETM fitted.
* JLink Info:   FPUnit: 6 code (BP) slots and 2 literal slots
Full Chip Erase Done.
Programming Done.
Contents missmatch at: 08000000H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000001H  (Flash=FFH  Required=86H) !
Contents missmatch at: 08000002H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000003H  (Flash=FFH  Required=20H) !
Contents missmatch at: 08000004H  (Flash=FFH  Required=45H) !
Contents missmatch at: 08000005H  (Flash=FFH  Required=01H) !
Contents missmatch at: 08000006H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000007H  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000008H  (Flash=FFH  Required=4DH) !
Contents missmatch at: 08000009H  (Flash=FFH  Required=01H) !
Contents missmatch at: 0800000AH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800000BH  (Flash=FFH  Required=08H) !
Contents missmatch at: 0800000CH  (Flash=FFH  Required=4FH) !
Contents missmatch at: 0800000DH  (Flash=FFH  Required=01H) !
Contents missmatch at: 0800000EH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800000FH  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000010H  (Flash=FFH  Required=51H) !
Contents missmatch at: 08000011H  (Flash=FFH  Required=01H) !
Contents missmatch at: 08000012H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000013H  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000014H  (Flash=FFH  Required=53H) !
Contents missmatch at: 08000015H  (Flash=FFH  Required=01H) !
Contents missmatch at: 08000016H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000017H  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000018H  (Flash=FFH  Required=55H) !
Contents missmatch at: 08000019H  (Flash=FFH  Required=01H) !
Contents missmatch at: 0800001AH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800001BH  (Flash=FFH  Required=08H) !
Contents missmatch at: 0800001CH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800001DH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800001EH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800001FH  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000020H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000021H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000022H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000023H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000024H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000025H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000026H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000027H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000028H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000029H  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800002AH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800002BH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800002CH  (Flash=FFH  Required=57H) !
Contents missmatch at: 0800002DH  (Flash=FFH  Required=01H) !
Contents missmatch at: 0800002EH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800002FH  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000030H  (Flash=FFH  Required=59H) !
Contents missmatch at: 08000031H  (Flash=FFH  Required=01H) !
Contents missmatch at: 08000032H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000033H  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000034H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000035H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000036H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000037H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000038H  (Flash=FFH  Required=5BH) !
Contents missmatch at: 08000039H  (Flash=FFH  Required=01H) !
Contents missmatch at: 0800003AH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800003BH  (Flash=FFH  Required=08H) !
Contents missmatch at: 0800003CH  (Flash=FFH  Required=5DH) !
Contents missmatch at: 0800003DH  (Flash=FFH  Required=01H) !
Contents missmatch at: 0800003EH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800003FH  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000040H  (Flash=FFH  Required=7DH) !
Contents missmatch at: 08000041H  (Flash=FFH  Required=96H) !
Contents missmatch at: 08000042H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000043H  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000044H  (Flash=FFH  Required=F9H) !
Contents missmatch at: 08000045H  (Flash=FFH  Required=7BH) !
Contents missmatch at: 08000046H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000047H  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000048H  (Flash=FFH  Required=09H) !
Contents missmatch at: 08000049H  (Flash=FFH  Required=8FH) !
Contents missmatch at: 0800004AH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800004BH  (Flash=FFH  Required=08H) !
Contents missmatch at: 0800004CH  (Flash=FFH  Required=3BH) !
Contents missmatch at: 0800004DH  (Flash=FFH  Required=85H) !
Contents missmatch at: 0800004EH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800004FH  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000050H  (Flash=FFH  Required=8DH) !
Contents missmatch at: 08000051H  (Flash=FFH  Required=67H) !
Contents missmatch at: 08000052H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000053H  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000054H  (Flash=FFH  Required=1DH) !
Contents missmatch at: 08000055H  (Flash=FFH  Required=83H) !
Contents missmatch at: 08000056H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000057H  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000058H  (Flash=FFH  Required=6DH) !
Contents missmatch at: 08000059H  (Flash=FFH  Required=64H) !
Contents missmatch at: 0800005AH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800005BH  (Flash=FFH  Required=08H) !
Contents missmatch at: 0800005CH  (Flash=FFH  Required=71H) !
Contents missmatch at: 0800005DH  (Flash=FFH  Required=64H) !
Contents missmatch at: 0800005EH  (Flash=FFH  Required=00H) !
Contents missmatch at: 0800005FH  (Flash=FFH  Required=08H) !
Contents missmatch at: 08000060H  (Flash=FFH  Required=BDH) !
Contents missmatch at: 08000061H  (Flash=FFH  Required=64H) !
Contents missmatch at: 08000062H  (Flash=FFH  Required=00H) !
Contents missmatch at: 08000063H  (Flash=FFH  Required=08H) !
Too many errors to display !
auwangzhen 发表于 2011-11-22 21:06 | 显示全部楼层
不知楼主解决问题了没有?我现在Keil MDK下用Jlink下载到片外Flash也遇到这种问题了 网上查了好多,这类问题好像也遇到过,但没给出有效的解决办法啊
FutureDeveloper 发表于 2013-2-4 11:21 | 显示全部楼层
我也碰到同样的问题
uet_cache 发表于 2013-2-4 11:30 | 显示全部楼层
我用JLINK,从来没出过问题。 你可以在OPTION里面配置,只要能找到JLINK和目标板信息就应该可以下,对了,那个FLASH选项CPU选项要选对。至少MDK6.0的,CPU分的很清。。
zhl100 发表于 2013-2-5 11:13 | 显示全部楼层
没出过问题:lol
airwill 发表于 2013-2-5 21:41 | 显示全部楼层
编程出错了. 恐怕是连接,信号问题有关
拿起书本 发表于 2013-2-5 22:48 | 显示全部楼层
想知道原因进来看看,有没有可能是调试接口的问题?……
littlebadbay 发表于 2013-5-15 10:49 | 显示全部楼层
也遇到这个问题 ,复位了一下就好了
简单happy 发表于 2015-11-30 09:07 | 显示全部楼层
今天我也遇到了
hellcatembert 发表于 2016-3-4 20:10 | 显示全部楼层
请问您是怎么解决的呢
重下载j-link固件  发表于 2016-3-6 15:27
