STM32F407通过SPI发送数据出现错误,SPI配置函数如下:
void SPI1_Init(void)
SPI_InitTypeDef SPI_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE); //使能GPIOB时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE); //使能GPIOC时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE); //使能SPI2时钟
//GPIOB13,PC2,3IO口初始化设置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_13; //PC,PB2,3,13复用功能输出
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //复用功能
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; //100MHz
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化IO口
GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化IO口
GPIO_PinAFConfig(GPIOC,GPIO_PinSource2,GPIO_AF_SPI2); //PC2复用为 SPI2
GPIO_PinAFConfig(GPIOC,GPIO_PinSource3,GPIO_AF_SPI2); //PC3复用为 SPI2
//GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
GPIO_PinAFConfig(GPIOB,GPIO_PinSource13,GPIO_AF_SPI2); //PB13复用为 SPI2
//SPI口初始化
RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI2,ENABLE); //复位SPI2
RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI2,DISABLE); //停止复位SPI1
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI
SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b; //设置SPI的数据大小:SPI发送接收16位帧结构
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //串行同步时钟的空闲状态为高电平
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;//定义波特率预分频的值:波特率预分频值为64
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
//SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式
SPI_Init(SPI2, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
SPI_Cmd(SPI2, ENABLE); //使能SPI外设
主函数如下:
int main(void)
uint16_t i=0,j=0xffff;
u16 rdata[SIZE];
// *datatemp;
//IC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
delay_init(); //初始化延时函数
SPI1_Init();
for(;;)
for(i=0;i<SIZE;i++)
while (SPI_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
//SPI2->DR = i;
SPI_I2S_SendData(SPI2, j);
