关于ARM7上电启动的问题,谢谢帮助!
3689|1
 楼主| s700 发表于 2011-9-24 13:32 | 显示全部楼层 |阅读模式
芯片是LPC2368, 其中P2.0--P2.7各接上一个led,高电平点亮,即是端口输出‘1’,相应led亮。
写了一个跑马灯的程序,但是系统没一点反应,下载程序到目标板后Keil显示正常,显示如下:
Erase Done.
Programming Done.
Verify OK.
Application running ...
我运用keil写的程序,启动代码采用Keil自带的LPC2300.s。个人感觉是上电芯片未启动的问题,不知道是否正确,希望各位大神指点一下,谢过了。
程序如下:
#include "lpc23xx.h"
typedef unsigned long DWORD;
typedef char BYTE;
#define I_Bit   0x80
#define F_Bit   0x40
#define VIC_SIZE 32
#define TIMER0_INT  4
#define SYS32Mode  0x1F
#define IRQ32Mode  0x12
#define FIQ32Mode  0x11
#define FALSE 0
#define TRUE 1
#define HIGHEST_PRIORITY 0x01
#define LOWEST_PRIORITY  0x0F
#define VECT_ADDR_INDEX 0x100
#define VECT_PRIO_INDEX 0x200
#define Fcclk 48000000
#define Fpclk (Fcclk / 2)
#define TIME_INTERVAL (Fpclk/100 - 1)
static DWORD sysreg;
#define IENABLE __asm { MRS sysreg, SPSR; MSR CPSR_c, #SYS32Mode }
#define IDISABLE __asm { MSR CPSR_c, #(IRQ32Mode|I_Bit); MSR SPSR_cxsf, sysreg }
volatile DWORD timer0_counter;
void Timer0Handler (void) __irq
  T0IR = 1;
  IENABLE;
  timer0_counter++;
  IDISABLE;
  VICVectAddr = 0;
DWORD install_irq( DWORD IntNumber, void *HandlerAddr, DWORD Priority )
    DWORD *vect_addr;
    DWORD *vect_prio;
    VICIntEnClr = 1 << IntNumber; /* Disable Interrupt */
    if ( IntNumber >= VIC_SIZE )
  return ( FALSE );
    else
   vect_addr = (DWORD *)(VIC_BASE_ADDR + VECT_ADDR_INDEX + IntNumber*4);
  vect_prio = (DWORD *)(VIC_BASE_ADDR + VECT_PRIO_INDEX + IntNumber*4);
  *vect_addr = (DWORD)HandlerAddr;
  *vect_prio = Priority;
  VICIntEnable = 1 << IntNumber;
  return( TRUE );
DWORD init_timer ( BYTE timer_num, DWORD TimerInterval )
  if ( timer_num == 0 )
timer0_counter = 0;
T0MR0 = TimerInterval;
T0MCR = 3;
if ( install_irq( TIMER0_INT, (void *)Timer0Handler, HIGHEST_PRIORITY ) == FALSE )
   return (FALSE);
else
   return (TRUE);
  return (FALSE);
#define FAST_PORT  0x01
#define REGULAR_PORT 0x02
#define DIR_OUT   0x01
#define DIR_IN   0x02
#define HS_PORT_DIR_BASE   FIO_BASE_ADDR + 0x00
#define HS_PORT_DIR_INDEX   0x20
#define GPIOM   0x00000001
void GPIOInit( DWORD PortNum, DWORD PortType, DWORD PortDir )
  if ( (PortType == FAST_PORT) && (PortNum == 2))
if ( (PortNum == 0) || (PortNum == 1) )
   SCS |= GPIOM;
if ( PortDir == DIR_OUT )
   (*(volatile unsigned long *)(HS_PORT_DIR_BASE
   + PortNum * HS_PORT_DIR_INDEX)) = 0xFFFFFFFF;
else
   + PortNum * HS_PORT_DIR_INDEX)) = 0x00000000;
  return;
#define PLL_MValue   11
#define PLL_NValue   0
#define CCLKDivValue  5
#define USBCLKDivValue  5
void ConfigurePLL ( void )
  DWORD MValue, NValue;
  if ( PLLSTAT & (1 << 25) )
PLLCON = 1;
PLLFEED = 0xaa;
PLLFEED = 0x55;
  PLLCON = 0;
  PLLFEED = 0xaa;
  PLLFEED = 0x55;
  SCS |= 0x20;
  while( !(SCS & 0x40) );
  CLKSRCSEL = 0x1;
  PLLCFG = PLL_MValue | (PLL_NValue << 16);
  PLLFEED = 0xaa;
  PLLFEED = 0x55;
  PLLCON = 1;
  PLLFEED = 0xaa;
  PLLFEED = 0x55;
  CCLKCFG = CCLKDivValue;
#if USE_USB
  USBCLKCFG = USBCLKDivValue;
#endif
  while ( ((PLLSTAT & (1 << 26)) == 0) );
  MValue = PLLSTAT & 0x00007FFF;
  NValue = (PLLSTAT & 0x00FF0000) >> 16;
  while ((MValue != PLL_MValue) && ( NValue != PLL_NValue) );
  PLLCON = 3;
  PLLFEED = 0xaa;
  PLLFEED = 0x55;
  while ( ((PLLSTAT & (1 << 25)) == 0) );
  return;
void enable_timer( BYTE timer_num )
T0TCR = 1;
  else
T1TCR = 1;
  return;
void GPIOResetInit( void )
  PINSEL0 = 0x00000000;
  PINSEL1 = 0x00000000;
  PINSEL2 = 0x00000000;
  PINSEL3 = 0x00000000;
  PINSEL4 = 0x00000000;
  PINSEL5 = 0x00000000;
  PINSEL6 = 0x00000000;
  PINSEL7 = 0x00000000;
  PINSEL8 = 0x00000000;
  PINSEL9 = 0x00000000;
  PINSEL10 = 0x00000000;
  IODIR0 = 0x00000000;
  IODIR1 = 0x00000000;
  IOSET0 = 0x00000000;
  IOSET1 = 0x00000000;
  FIO0DIR = 0x00000000;
  FIO1DIR = 0x00000000;
  FIO2DIR = 0x00000000;
  FIO3DIR = 0x00000000;
  FIO4DIR = 0x00000000;
  FIO0SET = 0x00000000;
  FIO1SET = 0x00000000;
  FIO2SET = 0x00000000;
  FIO3SET = 0x00000000;
  FIO4SET = 0x00000000;
  return;
void init_VIC(void)
    DWORD i = 0;
    DWORD *vect_addr, *vect_prio;
    VICIntEnClr = 0xffffffff;
    VICVectAddr = 0;
    VICIntSelect = 0;
    for ( i = 0; i < VIC_SIZE; i++ )      {
  vect_addr = (DWORD *)(VIC_BASE_ADDR + VECT_ADDR_INDEX + i*4);    vect_prio = (DWORD *)(VIC_BASE_ADDR + VECT_PRIO_INDEX + i*4);
  *vect_addr = 0x0;
  *vect_prio = 0xF;
    return;
void TargetResetInit(void)
#ifdef __DEBUG_RAM
  MEMMAP = 0x2;
#endif
#ifdef __DEBUG_FLASH
  MEMMAP = 0x1;
#endif
#if USE_USB
  PCONP |= 0x80000000;
#endif
   ConfigurePLL();
  #if (Fpclk / (Fcclk / 4)) == 1
  PCLKSEL0 = 0x00000000;
  PCLKSEL1 = 0x00000000;
#endif
#if (Fpclk / (Fcclk / 4)) == 2
  PCLKSEL0 = 0xAAAAAAAA;
  PCLKSEL1 = 0xAAAAAAAA;
#endif
#if (Fpclk / (Fcclk / 4)) == 4
  PCLKSEL0 = 0x55555555;
  PCLKSEL1 = 0x55555555;
#endif
    MAMCR = 0;
#if Fcclk < 20000000
  MAMTIM = 1;
#else
#if Fcclk < 40000000
  MAMTIM = 2;
#else
  MAMTIM = 3;
#endif
#endif
  MAMCR = 2;
  GPIOResetInit();
  init_VIC();
  return;
int main(void)
   DWORD counter;
   init_timer( 0, TIME_INTERVAL );
   GPIOInit( 2, FAST_PORT, DIR_OUT );
   enable_timer( 0 );
   counter = 0;
   FIO2SET = 1 << counter;
   while(1)
     if ( timer0_counter >= (0x20 * counter) )
   counter++;
   if ( counter > 8 )
  counter = 0;
  timer0_counter = 0;
  FIO2CLR = 0x000000FF;
  return 0;
hnylcxq 发表于 2011-9-25 21:37 | 显示全部楼层
keil环境下开发,怎么这么麻烦啊?是不是没有板级支持包啊,我用的ADS,好像大部分工作都背ADS给完成了,没见过点亮一个灯要这么复杂的啊
