好像不能按楼上的说法做。出现如下编译错误:- Build target 'Release'
- compiling led.cpp...
- led.cpp: In member function 'void task_led1_t::routine()':
- led.cpp(57): error: 'class instantiate::task' has no member named 'get_count'
- compiling Timer.cpp...
- Timer.cpp: In member function 'void task_LOOK_TIMER_t::routine()':
- Timer.cpp(23): warning: unused variable 'msg'
- Timer.cpp: At global scope:
- Timer.cpp(71): error: no 'long unsigned int task_LOOK_TIMER_t::get_count()' member function declared in class 'task_LOOK_TIMER_t'
- Target not created
主要代码如下:
led.cpp- #include "led.h"
- #define LOOK_H 1
- #if LOOK_H == 0
- #include "NUC1xx.h"
- #include "NUC1xxM051Seriescfg.h"
- #else
- #define __HAVE_GPIO
- #include <nuc120re3an.h>
- using namespace nuvoton;
- #endif
- #include "tft.h"
- #include "Timer.h"
- task_tft_t tftObj; //创建tft对象
- // 任务类 task_led_t 的例程
- void task_led1_t::routine()
- // TODO: 在此编写 task_led_t 例程的内容
- #define X_DIS 9 //显示信息的位置
- #define Y_DIS 7
- #define FONT_HEIGHT 19 //行高
- #define REFRESH_TIMES 16 //每秒的刷新次数
- unsigned char cnt_i = 0; //次数计数器,一定次数后cnt加1
- uint32_t cnt = 0; //时间计数器,延时方式,每1s延时后加一
- unsigned long count = 0; //时间计数器,定时方式,
- unsigned char str[6] = {0};
- tftObj.LCD_Init();
- // test_lcd_mon();
- tftObj.LCD_CLEAR(0,0,240,320);
- while (true) {
- tftObj.LCD_Display();
- cnt_i++;
- if(cnt_i > (REFRESH_TIMES-1))
- cnt_i = 0;
- cnt++;
- str[0] = (unsigned char)(cnt / 10000) + 0x30;
- str[1] = cnt % 10000 / 1000 + 0x30;
- str[2] = cnt % 1000 / 100 + 0x30;
- str[3] = cnt % 100 / 10 + 0x30;
- str[4] = (unsigned char)(cnt % 10) + 0x30;
- tftObj.LCD_ShowString(X_DIS,Y_DIS,"Running Time:");
- tftObj.LCD_ShowNumStr(X_DIS+81,Y_DIS-2,str);
- count = task_LOOK_TIMER.get_count();
- str[0] = (unsigned char)(count / 10000) + 0x30;
- str[1] = count % 10000 / 1000 + 0x30;
- str[2] = count % 1000 / 100 + 0x30;
- str[3] = count % 100 / 10 + 0x30;
- str[4] = (unsigned char)(count % 10) + 0x30;
- tftObj.LCD_ShowString(X_DIS,Y_DIS+FONT_HEIGHT,"Timer Time:");
- tftObj.LCD_ShowNumStr(X_DIS+81,Y_DIS-2+FONT_HEIGHT,str);
- delay(LOOK_TICKS_PER_SEC / REFRESH_TIMES); //每秒刷新屏幕10次
- #ifdef LOOK_SCHEDULING_PRIORITY
- instantiate::task<task_led1_t, LOOK_STACK_SIZE> task_led1(0);
- instantiate::task<task_LOOK_TIMER_t, LOOK_STACK_SIZE> task_LOOK_TIMER(0);
- #else
- instantiate::task<task_led1_t, LOOK_STACK_SIZE> task_led1;
- instantiate::task<task_LOOK_TIMER_t, LOOK_STACK_SIZE> task_LOOK_TIMER;
- #endif
2.Timer.h
