STM32的定时器作为编码器的问题
10507|19
 楼主| nieyaohua 发表于 2011-10-24 15:55 | 显示全部楼层 |阅读模式
最近正在用STM32的定时器进行编码器的配置进行脉冲的读取,在网上查很多资料,我配置后通过软件仿真但总是没有反应,计数器的值没有什么变化,求高人指点迷津。
配置程序如下:
#include "stm32f10x_lib.h"
#define ENCODER_TIMER   TIM3
#define ENCODER_PPR           (u16)(500)
#define ENCODER_TIM_PERIOD 2000
#define MAX_COUNT 2300
#define SPEED_SAMPLING_TIME 4000
#define COUNTER_RESET   (u16)0
#define ICx_FILTER      (u8) 6
#define TIMx_PRE_EMPTION_PRIORITY 1
#define TIMx_SUB_PRIORITY 0
#define SPEED_SAMPLING_FREQ ((u16)(2000/(SPEED_SAMPLING_TIME+1)))
ErrorStatus HSEStartUpStatus;
volatile s32  CurrentCount  ;
void RCC_Configuration(void);
void NVIC_Configuration(void);
void Delay(vu32 nCount);
void GPIO_Configuration(void);
void ENC_Init(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_ICInitTypeDef TIM_ICInitStructure;
/* Encoder unit connected to TIM3, 4X mode */
  NVIC_InitTypeDef NVIC_InitStructure;
  /* TIM3 clock source enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  /* Enable GPIOA, clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  GPIO_StructInit(&GPIO_InitStructure);
  /* Configure PA.06,07 as encoder input */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Enable the TIM3 Update Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = TIMx_PRE_EMPTION_PRIORITY;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = TIMx_SUB_PRIORITY;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Timer configuration in Encoder mode */
  TIM_DeInit(ENCODER_TIMER);
  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Prescaler = 0x0;  // No prescaling
  TIM_TimeBaseStructure.TIM_Period = ENCODER_TIM_PERIOD;
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(ENCODER_TIMER, &TIM_TimeBaseStructure);
//TIM_EncoderMode:触发源 TIM_ IC1Polarity:TI1 极性  TIM_ IC2Polarity:TI2 极性
  TIM_EncoderInterfaceConfig(ENCODER_TIMER, TIM_EncoderMode_TI12, TIM_ICPolarity_Rising, TIM_ICPolarity_Rising); //TIMx:x 可以是 2,3 或者 4,来选择 TIM 外设
  TIM_ICStructInit(&TIM_ICInitStructure);
  TIM_ICInitStructure.TIM_ICFilter = ICx_FILTER;  //设定滤波值
  TIM_ICInit(ENCODER_TIMER, &TIM_ICInitStructure);
// Clear all pending interrupts
  TIM_ClearFlag(ENCODER_TIMER, TIM_FLAG_Update);
  TIM_ITConfig(ENCODER_TIMER, TIM_IT_Update, ENABLE);
  //Reset counter
  TIM3->CNT = COUNTER_RESET;
//  ENC_Clear_Speed_Buffer();
  TIM_Cmd(ENCODER_TIMER, ENABLE);
int main(void)
  #ifdef DEBUG
  debug();
  #endif
  RCC_Configuration();
  NVIC_Configuration();
  GPIO_Configuration();
  ENC_Init() ;
  while(1)
    CurrentCount= TIM_GetCounter(TIM3);
香水城 发表于 2011-10-24 16:01 | 显示全部楼层
你能确认软件仿真的功能有效吗?
 楼主| nieyaohua 发表于 2011-10-24 16:02 | 显示全部楼层
应该有效吧,这样不是能看的更清楚吗?这个你以前是不是做过,能不能给点指导?
 楼主| nieyaohua 发表于 2011-10-24 16:03 | 显示全部楼层
香水城 发表于 2011-10-24 16:19 | 显示全部楼层
我没有做过。我们也从来没有人用过软件仿真。你最好直接在芯片上测试验证。
香水城 发表于 2011-10-24 16:24 | 显示全部楼层
给你个文档和例程看看吧。
【应用笔记】STM32F10xxx正交编码器接口.pdf
323.4 KB, 下载次数: 1520
【应用笔记】STM32F10xxx正交编码器接口例程.zip
871.28 KB, 下载次数: 1435
oldhuang 发表于 2012-11-12 22:31 | 显示全部楼层
我需要这个例程...
oldhuang 发表于 2012-11-12 22:32 | 显示全部楼层
我需要这个例程...
wangyong123846 发表于 2012-11-30 15:36 | 显示全部楼层
这资料好
文峰聊书斋 发表于 2013-3-15 19:07 | 显示全部楼层
如何做实验呀,没有伺服电机的编码器反馈到STM32的TIM CH1 CH2上,没法做实验验证我写的定时器编码器模式接口是否是正确的?
cjhk 发表于 2013-3-15 21:24 | 显示全部楼层
好资料  多看例程   多模仿  这样才能学到很多东西   呵呵   这个主要还是看例程
谢谢版主的资料  谢谢了  版主   我顶你  呵呵
ABCDELF 发表于 2013-4-11 15:52 | 显示全部楼层
这个东西到官网怎么找啊
ABCDELF 发表于 2013-4-11 15:54 | 显示全部楼层
给你个文档和例程看看吧。
像stm32正交编码器的应用笔记到官网怎么下载
我找了几个点都没点头绪
hsz9191 发表于 2013-4-24 14:25 | 显示全部楼层
还是香主给力,顶起
cjhk 发表于 2013-4-24 19:31 | 显示全部楼层
谢谢了   香主   谢谢你的共享资料   谢谢
papermx 发表于 2014-4-18 16:33 | 显示全部楼层
请问下如果不是增量式的编码器,应该如何连接呢?买的是旋转编码器,计脉冲的原理是一样的吗?
cxq88998 发表于 2014-6-16 20:46 | 显示全部楼层
旋转编码器,计脉冲的原理是一样的吗?
GUN_xing 发表于 2015-5-11 16:27 | 显示全部楼层
。。。。为啥这资料下载不了?
sky9218 发表于 2020-12-13 15:51 | 显示全部楼层
给你个文档和例程看看吧。
找到了。谢谢。
