Little VGL作为一个优秀、源码开源的GUI库,内存占用少但界面炫酷,目前得到越来越多的支持。零知开源平台已移植了该库,下面在零知开发板-增强板上进行实验演示。
特性:- 16, 32 or 64 bit microcontroller or processor
- 16 MHz clock speed
- 8 kB RAM for static data and >2 KB RAM for dynamic data (graphical objects)
- 64 kB program memory (flash)
- 支持GPU
1、硬件准备
(1)零知开发板-增强板
(2)TFT液晶显示屏
(3)零知开发工具
(4)杜邦线若干
2、硬件连接
使用2.4寸、ILI9341驱动、带触摸屏XPT2046的TFT液晶显示屏作为显示工具,与零知增强板配合使用,硬件连接按下表进行连线:
3、编写代码
因为使用了TFT液晶显示屏作为显示工具,所以需要用到FSMC_TFT库,同时也用到触摸屏功能,也需要XPT2046的软件库,相关的库文件可到零知实验室官网免费获取。(1)显示设备
初始化:
- * Initialize your display here
- void tft_init(void)
- lv_disp_drv_t disp_drv;
- lv_disp_drv_init(&disp_drv);
- disp_drv.disp_fill = tft_fill;
- disp_drv.disp_map = tft_map;
- disp_drv.disp_flush = tft_flush;
- lv_disp_drv_register(&disp_drv);
(2)输入设备,即用触摸屏作为输入设备
初始化:
- * init touchpad here
- * Input device interface
- void touchpad_init(void)
- lv_indev_drv_t indev_drv; /*Descriptor of an input device driver*/
- lv_indev_drv_init(&indev_drv); /*Basic initialization*/
- indev_drv.type = LV_INDEV_TYPE_POINTER; /*The touchpad is pointer type device*/
- indev_drv.read = ex_tp_read; /*Library ready your touchpad via this function*/
- lv_indev_drv_register(&indev_drv); /*Finally register the driver*/
触摸位置的读取:
- * touch read position
- bool ex_tp_read(lv_indev_data_t *data)
- bool tp_is_pressed = ts.touched(); /*TODO read here the state of toush pad*/
- int16_t last_x = 0;
- int16_t last_y = 0;
- if(tp_is_pressed) {
- /*Touch pad is being pressed now*/
- TS_Point p = ts.getPoint();
- //convert to lcd position
- last_y = 320-(p.x *320)/4095; /*TODO save the current X coordinate*/
- last_x = 240-(p.y *240)/4095; /*TODO save the current Y coordinate*/
- Serial.print("touched:");
- Serial.print(last_x);Serial.print(",");Serial.println(last_y);
- data->point.x = last_x;
- data->point.y = last_y;
- data->state = tp_is_pressed ? LV_INDEV_STATE_PR : LV_INDEV_STATE_REL;
- return false; /*Return false because no moare to be read*/
注:触摸屏最好先进行校准,这样读取位置就比较精确,这里简单的进行了一下转换,对于尺寸较大的控件影响不大,如果是尺寸很小的控件不做校准,读取位置就会有很大的偏差。
(3)LVGL system tick
使用一个1ms定时器中断进行提供:
- void timer_handler(stimer_t *timer)
- lv_tick_inc(1);
- void lvgl_timer_init()
- static stimer_t m_timer;
- m_timer.timer = TIM3;
- TimerHandleInit(&m_timer, 10-1, 8400-1);//1ms timer
- attachIntHandle(&m_timer, timer_handler);
(4)创建lvgl的一个demo
这里直接调用了官方示例的demo进行演示。
4、运行效果
还可以使用PC端模拟器辅助开发调试UI,以下是windows上Qt运行效果:
更多详细资料可到零知实验室官网免费获取。
