[DemoCode下载] ADC的连续扫描模式
1241|3
 楼主| zhuomuniao110 发表于 2019-6-30 23:36 | 显示全部楼层 |阅读模式
ADC, IO, AN, RS, TE
  1. /****************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.0
  4. * $Revision: 6 $
  5. * $Date: 15/05/22 2:04p $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Perform A/D Conversion with ADC continuous scan mode.
  7. *
  8. * @note
  9. * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
  10. *
  11. ******************************************************************************/
  12. #include <stdio.h>
  13. #include "M051Series.h"
  14. #define PLL_CLOCK       50000000
  15. /*---------------------------------------------------------------------------------------------------------*/
  16. /* Define Function Prototypes        */
  17. /*---------------------------------------------------------------------------------------------------------*/
  18. void SYS_Init(void);
  19. void UART0_Init(void);
  20. void AdcContScanModeTest(void);
  21. void SYS_Init(void)
  22. {
  23.     /*---------------------------------------------------------------------------------------------------------*/
  24.     /* Init System Clock        */
  25.     /*---------------------------------------------------------------------------------------------------------*/
  26.     /* Enable Internal RC 22.1184MHz clock */
  27.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  28.     /* Waiting for Internal RC clock ready */
  29.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  30.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  31.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  32.     /* Enable external XTAL 12MHz clock */
  33.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  34.     /* Waiting for external XTAL clock ready */
  35.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  36.     /* Set core clock as PLL_CLOCK from PLL */
  37.     CLK_SetCoreClock(PLL_CLOCK);
  38.     /* Enable UART module clock */
  39.     CLK_EnableModuleClock(UART0_MODULE);
  40.     /* Enable ADC module clock */
  41.     CLK_EnableModuleClock(ADC_MODULE);
  42.     /* Select UART module clock source */
  43.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  44.     /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
  45.     CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
  46.     /*---------------------------------------------------------------------------------------------------------*/
  47.     /* Init I/O Multi-function        */
  48.     /*---------------------------------------------------------------------------------------------------------*/
  49.     /* Set P3 multi-function pins for UART0 RXD and TXD */
  50.     SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
  51.     SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
  52.     /* Disable the P1.0 - P1.3 digital input path to avoid the leakage current */
  53.     GPIO_DISABLE_DIGITAL_PATH(P1, 0xF);
  54.     /* Configure the P1.0 - P1.3 ADC analog input pins */
  55.     SYS->P1_MFP &= ~(SYS_MFP_P10_Msk | SYS_MFP_P11_Msk | SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
  56.     SYS->P1_MFP |= SYS_MFP_P10_AIN0 | SYS_MFP_P11_AIN1 | SYS_MFP_P12_AIN2 | SYS_MFP_P13_AIN3 ;
  57. }
  58. /*---------------------------------------------------------------------------------------------------------*/
  59. /* Init UART        */
  60. /*---------------------------------------------------------------------------------------------------------*/
  61. void UART0_Init()
  62. {
  63.     /* Reset IP */
  64.     SYS_ResetModule(UART0_RST);
  65.     /* Configure UART0 and set UART0 Baudrate */
  66.     UART_Open(UART0, 115200);
  67. }
  68. /*---------------------------------------------------------------------------------------------------------*/
  69. /* Function: ADC_GetConversionRate        */
  70. /*        */
  71. /* Parameters:        */
  72. /*   None.        */
  73. /*        */
  74. /* Returns:        */
  75. /*      Return the A/D conversion rate (sample/second)                                                     */
  76. /*        */
  77. /* Description:        */
  78. /*   The conversion rate depends on the clock source of ADC clock.                                         */
  79. /*   It only needs 21 ADC clocks to complete an A/D conversion.                                            */
  80. /*---------------------------------------------------------------------------------------------------------*/
  81. static __INLINE uint32_t ADC_GetConversionRate()
  82. {
  83.     uint32_t u32AdcClkSrcSel;
  84.     uint32_t u32ClkTbl[4] = {__HXT, 0, 0, __HIRC};
  85.     /* Set the PLL clock frequency */
  86.     u32ClkTbl[1] = PllClock;
  87.     /* Set the system core clock frequency */
  88.     u32ClkTbl[2] = SystemCoreClock;
  89.     /* Get the clock source setting */
  90.     u32AdcClkSrcSel = ((CLK->CLKSEL1 & CLK_CLKSEL1_ADC_S_Msk) >> CLK_CLKSEL1_ADC_S_Pos);
  91.     /* Return the ADC conversion rate */
  92.     return ((u32ClkTbl[u32AdcClkSrcSel]) / (((CLK->CLKDIV & CLK_CLKDIV_ADC_N_Msk) >> CLK_CLKDIV_ADC_N_Pos) + 1) / 21);
  93. }
  94. /*---------------------------------------------------------------------------------------------------------*/
  95. /* Function: AdcContScanModeTest        */
  96. /*        */
  97. /* Parameters:        */
  98. /*   None.        */
  99. /*        */
  100. /* Returns:        */
  101. /*   None.        */
  102. /*        */
  103. /* Description:        */
  104. /*   ADC continuous scan mode test.        */
  105. /*---------------------------------------------------------------------------------------------------------*/
  106. void AdcContScanModeTest()
  107. {
  108.     uint8_t  u8Option;
  109.     uint32_t u32ChannelCount;
  110.     int32_t  i32ConversionData;
  111.     printf("\n\nConversion rate: %d samples/second\n", ADC_GetConversionRate());
  112.     printf("\n");
  113.     printf("+----------------------------------------------------------------------+\n");
  114.     printf("|                 ADC continuous scan mode sample code                 |\n");
  115.     printf("+----------------------------------------------------------------------+\n");
  116.     printf("\nIn this test, software will get 2 cycles of conversion result from the specified channels.\n");
  117.     while(1)
  118.     {
  119.         printf("\n\nSelect input mode:\n");
  120.         printf("  [1] Single end input (channel 0, 1, 2 and 3)\n");
  121.         printf("  [2] Differential input (input channel pair 0 and 1)\n");
  122.         printf("  Other keys: exit continuous scan mode test\n");
  123.         u8Option = getchar();
  124.         if(u8Option == '1')
  125.         {
  126.             /* Set the ADC operation mode as continuous scan, input mode as single-end and
  127.                  enable the analog input channel 0, 1, 2 and 3 */
  128.             ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_CONTINUOUS, 0xF);
  129.             /* Power on ADC module */
  130.             ADC_POWER_ON(ADC);
  131.             /* clear the A/D interrupt flag for safe */
  132.             ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  133.             /* start A/D conversion */
  134.             ADC_START_CONV(ADC);
  135.             /* Wait conversion done */
  136.             while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
  137.             /* clear the A/D interrupt flag for safe */
  138.             ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  139.             for(u32ChannelCount = 0; u32ChannelCount < 4; u32ChannelCount++)
  140.             {
  141.                 i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount);
  142.                 printf("Conversion result of channel %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
  143.             }
  144.             /* Wait conversion done */
  145.             while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
  146.             /* Stop A/D conversion */
  147.             ADC_STOP_CONV(ADC);
  148.             for(u32ChannelCount = 0; u32ChannelCount < 4; u32ChannelCount++)
  149.             {
  150.                 i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount);
  151.                 printf("Conversion result of channel %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
  152.             }
  153.             /* clear the A/D interrupt flag for safe */
  154.             ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  155.         }
  156.         else if(u8Option == '2')
  157.         {
  158.             /* Set the ADC operation mode as continuous scan, input mode as differential and
  159.                enable analog input channel 0 and 2 */
  160.             ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_CONTINUOUS, 0x5);
  161.             /* Power on ADC module */
  162.             ADC_POWER_ON(ADC);
  163.             /* clear the A/D interrupt flag for safe */
  164.             ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  165.             /* start A/D conversion */
  166.             ADC_START_CONV(ADC);
  167.             /* Wait conversion done */
  168.             while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
  169.             /* clear the A/D interrupt flag for safe */
  170.             ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  171.             for(u32ChannelCount = 0; u32ChannelCount < 2; u32ChannelCount++)
  172.             {
  173.                 i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount * 2);
  174.                 printf("Conversion result of differential input pair %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
  175.             }
  176.             /* Wait conversion done */
  177.             while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
  178.             /* Stop A/D conversion */
  179.             ADC_STOP_CONV(ADC);
  180.             for(u32ChannelCount = 0; u32ChannelCount < 2; u32ChannelCount++)
  181.             {
  182.                 i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount * 2);
  183.                 printf("Conversion result of differential input pair %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
  184.             }
  185.             /* clear the A/D interrupt flag for safe */
  186.             ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  187.         }
  188.         else
  189.             return ;
  190.     }
  191. }
  192. /*---------------------------------------------------------------------------------------------------------*/
  193. /* MAIN function        */
  194. /*---------------------------------------------------------------------------------------------------------*/
  195. main(void)
  196. {
  197.     /* Unlock protected registers */
  198.     SYS_UnlockReg();
  199.     /* Init System, IP clock and multi-function I/O */
  200.     SYS_Init();
  201.     /* Lock protected registers */
  202.     SYS_LockReg();
  203.     /* Init UART0 for printf */
  204.     UART0_Init();
  205.     /*---------------------------------------------------------------------------------------------------------*/
  206.     /* SAMPLE CODE        */
  207.     /*---------------------------------------------------------------------------------------------------------*/
  208.     printf("\nSystem clock rate: %d Hz", SystemCoreClock);
  209.     /* Continuous scan mode test */
  210.     AdcContScanModeTest();
  211.     /* Disable ADC module */
  212.     ADC_Close(ADC);
  213.     /* Disable ADC IP clock */
  214.     CLK_DisableModuleClock(ADC_MODULE);
  215.     /* Disable External Interrupt */
  216.     NVIC_DisableIRQ(ADC_IRQn);
  217.     printf("\nExit ADC sample code\n");
  218.     while(1);
  219. }
wahahaheihei 发表于 2019-6-30 23:38 | 显示全部楼层
系统不干预的情况下也一直在转化?
xixi2017 发表于 2019-6-30 23:46 | 显示全部楼层
这个模式比较适合多通道一直一起不停的工作。
小明的同学 发表于 2019-7-2 09:08 | 显示全部楼层
我要搞个板子研究一下。
