- #include <avr/io.h>
- #include <util/delay.h>
- #define KEYPAD_PORT PORTB
- #define KEYPAD_DDR DDRB
- #define KEYPAD_PIN PINB
- #define Segment_PORT PORTD
- #define Segment_DDR DDRD
- typedef unsigned char BYTE;
- int key_scan(void) {
- BYTE KEY;
- BYTE temp_SW;
- //read Port D
- KEY = KEYPAD_PIN & 0x07;
- //get only low 3 bits
- //KEY &= 0x07;
- temp_SW = 0;
- if (KEY != 0x07) //if a key is pressed
- // KEY = PIND;
- // KEY &= 0x0f;
- // if(KEY != 0x0f)
- switch (KEY) {
- case 0x03: //00000011
- temp_SW = 1;
- break;
- case 0x05: //00000101
- temp_SW = 2;
- break;
- default:
- temp_SW = 3;
- return temp_SW;
- int main(void) {
- BYTE bKey;
- BYTE SEG[12] = { 0XC0, 0XF9, 0XA4, 0XB0, 0X99, 0X92, 0X82, 0XD8, 0X80, 0X90,
- 0X88, 0X8e };
- Segment_DDR = 0xff; // 7 segments
- Segment_PORT = 0xff;
- // high 4bits: output
- // low 4bits: input
- KEYPAD_DDR = 0xF8; 0x11111000
- while (1) {
- KEYPAD_PORT = 0xF7; // only bit 6 low, 0b11110111
- //PORTD = ~_BV(2); // only bit 6 low, 0b1011
- _delay_ms(20);
- bKey = key_scan();
- if (bKey == 1)
- Segment_PORT = 3;
- else if (bKey == 2)
- Segment_PORT = 6;
- else if (bKey == 3)
- Segment_PORT = 9;
- KEYPAD_PORT = 0xE8; // only bit 5 low, 0b1101
- //PORTD = ~_BV(1); // only bit 6 low, 0b1101
- _delay_ms(20);
- if (bKey == 1)
- Segment_PORT = 2;
- Segment_PORT = 5;
- Segment_PORT = 8;
- KEYPAD_PORT = 0xD8; // only bit 4 low, 0b1110
- //PORTD = ~_BV(0); // only bit 6 low, 0b1110
- _delay_ms(20);
- if (bKey == 1)
- Segment_PORT = 1;
- Segment_PORT = 4;
- Segment_PORT = 7;
