/*---------------------------------------------------------------------------------------------------------*/ /* */ /* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ //*********************************************************************************************************** // Nuvoton Technoledge Corp. // Website: http://www.nuvoton.com // E-Mail : MicroC-8bit@nuvoton.com // Date : Apr/21/2016 //*********************************************************************************************************** //*********************************************************************************************************** // File Function: N76E003 Watch Dog reste functiondemo code //*********************************************************************************************************** #include "N76E003.h" #include "Common.h" #include "Delay.h" #include "SFR_Macro.h" #include "Function_define.h" #define CFG_READ 0xC0 #define CFG_ERASE 0xE2 #define CFG_BYTE_PROGRAM 0xE1 /*********************************************************************** WDT CONFIG enable warning : this macro is only when ICP not enable CONFIG WDT function copy this marco code to you code to enable WDT reset. ************************************************************************/ void Enable_WDT_Reset_Config(void) { set_IAPEN; IAPAL = 0x04; IAPAH = 0x00; IAPFD = 0x0F; IAPCN = CFG_BYTE_PROGRAM; set_CFUEN; set_IAPGO; //trigger IAP while((CHPCON&SET_BIT6)==SET_BIT6); //check IAPFF (CHPCON.6) clr_CFUEN; clr_IAPEN; } /*********************************************************************** WDT CONFIG disable warning : this macro is for CONFIG already enable WDT Reset to disable. Since erase CONFIG is full page step 1. storage CONFIG value in RAM step 2. modify RAM CONFIG4 WDT value to disable step 3. erase CONFIG page step 4. re writer CONFIG. ************************************************************************/ void Disable_WDT_Reset_Config(void) { UINT8 cf0,cf1,cf2,cf3,cf4; set_IAPEN; IAPAL = 0x00; IAPAH = 0x00; IAPCN = CFG_READ; set_IAPGO; //Storage CONFIG0 data cf0 = IAPFD; IAPAL = 0x01; set_IAPGO; //Storage CONFIG1 data cf1 = IAPFD; IAPAL = 0x02; set_IAPGO; //Storage CONFIG2 data cf2 = IAPFD; IAPAL = 0x03; set_IAPGO; //Storage CONFIG3 data cf3 = IAPFD; IAPAL = 0x04; set_IAPGO; //Storage CONFIG4 data cf4 = IAPFD; cf4 |= 0xF0; //Moidfy Storage CONFIG4 data disable WDT reset set_CFUEN; IAPCN = CFG_ERASE; //Erase CONFIG all IAPAH = 0x00; IAPAL = 0x00; IAPFD = 0xFF; set_IAPGO; IAPCN = CFG_BYTE_PROGRAM; //Write CONFIG IAPFD = cf0; set_IAPGO; IAPAL = 0x01; IAPFD = cf1; set_IAPGO; IAPAL = 0x02; IAPFD = cf2; set_IAPGO; IAPAL = 0x03; IAPFD = cf3; set_IAPGO; IAPAL = 0x04; IAPFD = cf4; set_IAPGO; clr_CFUEN; clr_IAPEN; } /************************************************************************************************************ * Main function ************************************************************************************************************/ void main (void) { Set_All_GPIO_Quasi_Mode; clr_GPIO1; Timer0_Delay1ms(50); //toggle I/O to show MCU Reset set_GPIO1; Timer0_Delay1ms(50); clr_GPIO1; Timer0_Delay1ms(50); set_GPIO1; Timer0_Delay1ms(50); //---------------------------------------------------------------------------------------------- // WDT Init !!! ENABLE CONFIG WDT FIRST !!! // Warning: // Always check CONFIG WDT enable first, CONFIG not enable, SFR can't enable WDT reset // Please call Enable_WDT_Reset_Config() function to enable CONFIG WDT reset //---------------------------------------------------------------------------------------------- // Enable_WDT_Reset_Config(); //Software enable WDT reset CONFIG setting TA=0xAA;TA=0x55;WDCON|=0x07; //Setting WDT prescale set_WDCLR; //Clear WDT timer while((WDCON|~SET_BIT6)==0xFF); //confirm WDT clear is ok before into power down mode // EA = 1; set_WDTR; //WDT run Disable_WDT_Reset_Config(); //Software disable WDT reset CONFIG setting while (1) { clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); clr_GPIO1; set_PD; } }
收藏0 举报
幸福小强 发表于 2019-11-24 21:57 这个方法是不是很6,之前好多人想知道怎么在程序里设置配置字。
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
发帖类勋章
等级类勋章
时间类勋章
143
1727
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
