- LCD_WriteRam0_7Int32(0,0x0b060600);
- LCD_WriteRam0_7Int32(1,0x0d030f02);
以上两行代码要显示什么呢?入口参数第二个参数是啥?看不懂,可读性极差!
折腾一下,随手写了几个函数,分分钟,贴上来和大家共享。
- ***显示译码 “0,1,2,3,4,5,6,7,8,9,关闭”************
- uint16_t code[11]={0xf05,0x600,0xb06,0xf02,0x603,0xd03,0xd07,0x700,0xf07,0xf03,0x000}; // 0,1,2,3,4,5,6,7,8,9,关闭
- static void Lcd_SetPortAnalog(void)
- Gpio_SetAnalogMode(GpioPortA, GpioPin9);//COM0
- Gpio_SetAnalogMode(GpioPortA, GpioPin10);//COM1
- Gpio_SetAnalogMode(GpioPortA, GpioPin11);//COM2
- Gpio_SetAnalogMode(GpioPortA, GpioPin12);//COM3
- Gpio_SetAnalogMode(GpioPortA, GpioPin8);//SEG0
- Gpio_SetAnalogMode(GpioPortC, GpioPin9);//SEG1
- Gpio_SetAnalogMode(GpioPortC, GpioPin8);//SEG2
- Gpio_SetAnalogMode(GpioPortC, GpioPin7);//SEG3
- Gpio_SetAnalogMode(GpioPortC, GpioPin6);//SEG4
- Gpio_SetAnalogMode(GpioPortB, GpioPin15);//SEG5
- Gpio_SetAnalogMode(GpioPortB, GpioPin14);//SEG6
- Gpio_SetAnalogMode(GpioPortB, GpioPin13);//SEG7
- // Gpio_SetAnalogMode(GpioPortB, GpioPin3);//VLCDH
- // Gpio_SetAnalogMode(GpioPortB, GpioPin4);//VLCD3
- // Gpio_SetAnalogMode(GpioPortB, GpioPin5);//VLCD2
- // Gpio_SetAnalogMode(GpioPortB, GpioPin6);//VLCD1
- void LCD_config(void)
- stc_lcd_config_t stcLcdCfg;
- DDL_ZERO_STRUCT(stcLcdCfg);
- Sysctrl_SetPeripheralGate(SysctrlPeripheralLcd,TRUE);
- Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE);
- Lcd_SetPortAnalog();//和LCD相关端口都要配置为模拟端口
- LCD_SetSegCom(0,0xffffff00);//设置seg0-7
- LCD_SetSegCom(1,0x10ff);//设置com0-3
- stcLcdCfg.enDispMode = LcdMode0;
- stcLcdCfg.enBias = LcdBias3;
- stcLcdCfg.enBiasSrc = LcdInRes_Low;//内部电阻方式
- stcLcdCfg.enClk = LcdRCL;
- stcLcdCfg.enDuty = LcdDuty4;
- stcLcdCfg.enCpClk = LcdClk2k;
- stcLcdCfg.enScanClk = LcdClk128hz;
- LCD_Init(&stcLcdCfg);
- LCD_EnFunc(LcdEn,TRUE);
- LCD_ClearDisp();
- return;
- /*显示数字,成两组,左边和右边
- index : 0 左对齐,1 右对齐
- mun : 数字范围在 0 ~99
- void LCD_disp_num(uint8_t index, uint8_t mun)
- int a = 0;
- int b = 0;
- a=mun/10;
- b=mun%10;
- LCD_WriteRam0_7Int32(index,(code[b]<<16) + code[a]);
- /*显示小数点,冒号*/
- void LCD_disp_dot(uint8_t index)
- if(index == 1)
- LCD_WriteRam(0,3,1); /*first dot */
- else if(index == 2)
- LCD_WriteRam(1,3,1); /*second dot */
- else if(index == 3)
- LCD_WriteRam(1,19,1); /*third dot */
- else
- LCD_WriteRam(0,19,1); /*maohao*/
- return;
下载运行,结果OK。
