- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.00
- * $Revision: 3 $
- * $Date: 15/05/22 2:35p $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Use WDT time-out interrupt event to wake-up system.
- * @note
- * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M051Series.h"
- #define PLLCON_SETTING CLK_PLLCON_50MHz_HXT
- #define PLL_CLOCK 50000000
- /* Global Interface Variables Declarations */
- extern int IsDebugFifoEmpty(void);
- volatile uint8_t g_u8IsWDTWakeupINT = 0;
- /* Function for System Entry to Power-down Mode */
- void PowerDownFunction(void)
- printf("System enter to power-down mode.\n\n");
- /* To check if all the debug messages are finished */
- while(IsDebugFifoEmpty() == 0);
- SCB->SCR = 4;
- /* To program PWRCON register, it needs to disable register protection first. */
- CLK->PWRCON = (CLK->PWRCON & ~(CLK_PWRCON_PWR_DOWN_EN_Msk | CLK_PWRCON_PD_WAIT_CPU_Msk)) |
- CLK_PWRCON_PD_WAIT_CPU_Msk | CLK_PWRCON_PD_WU_INT_EN_Msk;
- CLK->PWRCON |= CLK_PWRCON_PWR_DOWN_EN_Msk;
- __WFI();
- * @brief IRQ Handler for WDT and WWDT Interrupt
- * @param None
- * [url=home.php?mod=space&uid=266161]@return[/url] None
- * [url=home.php?mod=space&uid=1543424]@Details[/url] The WDT_IRQHandler is default IRQ of WDT and WWDT, declared in startup_M051Series.s.
- void WDT_IRQHandler(void)
- if((WDT_GET_TIMEOUT_INT_FLAG() == 1) && (WDT_GET_TIMEOUT_WAKEUP_FLAG() == 1))
- /* Clear WDT time-out interrupt and wake-up flag */
- WDT_CLEAR_TIMEOUT_INT_FLAG();
- WDT_CLEAR_TIMEOUT_WAKEUP_FLAG();
- g_u8IsWDTWakeupINT = 1;
- printf("WDT time-out wake-up interrupt occurred.\n");
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable IRC22M clock */
- CLK->PWRCON |= CLK_PWRCON_IRC22M_EN_Msk;
- /* Waiting for IRC22M clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_IRC22M_STB_Msk);
- /* Switch HCLK clock source to HIRC */
- CLK->CLKSEL0 = CLK_CLKSEL0_HCLK_S_HIRC;
- /* Set PLL to Power-down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
- CLK->PLLCON |= CLK_PLLCON_PD_Msk;
- /* Enable external 12 MHz XTAL, IRC10K */
- CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC10K_EN_Msk;
- /* Enable PLL and Set PLL frequency */
- CLK->PLLCON = PLLCON_SETTING;
- /* Waiting for clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_IRC10K_STB_Msk);
- /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
- CLK->CLKSEL0 = CLK_CLKSEL0_STCLK_S_HCLK_DIV2 | CLK_CLKSEL0_HCLK_S_PLL;
- /* Enable peripheral clock */
- CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk | CLK_APBCLK_WDT_EN_Msk;
- /* Peripheral clock source */
- CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_PLL | CLK_CLKSEL1_WDT_S_LIRC;
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
- SystemCoreClockUpdate();
- /* Init I/O Multi-function */
- /* Set P3 multi-function pins for UART0 RXD, TXD */
- SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
- void UART0_Init(void)
- /* Init UART */
- /* Reset IP */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- /* MAIN function */
- int main(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, peripheral clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
- printf("+----------------------------------------------+\n");
- printf("| WDT Power-down and Wake-up Sample Code |\n");
- printf("+----------------------------------------------+\n\n");
- printf("# WDT Settings:\n");
- printf(" Clock source is 10 kHz; Enable interrupt; Enable Wake-up; Time-out interval is 2^16 * WDT clock.\n");
- printf("# When WDT statr counting, system will generate a WDT time-out interrupt after 6.5536 ~ 6.656 s.\n");
- printf(" Measure P0.0 low period to check time-out interval and system can be waken-up by WDT time-out event.\n\n");
- /* Use P0.0 to check time-out period time */
- GPIO_SetMode(P0, 0, GPIO_PMD_OUTPUT);
- P00 = 1;
- P00 = 0;
- /* Because of all bits can be written in WDT Control Register are write-protected;
- To program it needs to disable register protection first. */
- SYS_UnlockReg();
- /* Enable WDT wake-up function and select time-out interval to 2^16 * WDT clock then start WDT counting */
- g_u8IsWDTWakeupINT = 0;
- WDT_Open(WDT_TIMEOUT_2POW16, WDT_RESET_DELAY_1026CLK, FALSE, TRUE);
- /* Enable WDT interrupt function */
- WDT_EnableInt();
- /* Enable WDT NVIC */
- NVIC_EnableIRQ(WDT_IRQn);
- /* System entry into Power-down Mode */
- PowerDownFunction();
- /* Check if WDT time-out interrupt and wake-up interrupt flag occurred */
- while(1)
- if(((CLK->PWRCON & CLK_PWRCON_PD_WU_STS_Msk) == CLK_PWRCON_PD_WU_STS_Msk) && (g_u8IsWDTWakeupINT == 1))
- break;
- P00 = 1;
- /* Clear Power-down wake-up interrupt flag */
- CLK->PWRCON |= CLK_PWRCON_PD_WU_STS_Msk;
- /* Disable WDT counting */
- WDT_Close();
- while(1);
- /*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
