- #include <hidef.h>
- #include "derivative.h"
- #define LEDCPU PORTB_PB1 //定义连接发光二级管的PORTB_PB1口数据寄存
- //为LED,写'0'亮,写'1' 灭
- #define LEDCPU_dir DDRB_DDRB1 //定义连接发光二级管的PORTB_PB1口方向寄存器
- //为LEDCPU_dir,写'0'做输入口,写'1'做输出口
- void INIT_PLL(void) //busclock 32M
- CLKSEL_PLLSEL=0; //总线时钟来源于晶振
- PLLCTL_PLLON=0; //先关闭PLL
- SYNR=0x40 | 0x03;
- REFDV=0x80 | 0x01;
- POSTDIV=0x00; //PLL配置为64MHz
- PLLCTL_PLLON=1; //打开PLL
- _asm(nop);
- _asm(nop);
- while(!(CRG**_LOCK==1)); //确定PLL是否稳定LOCK=1 稳定,=0 不稳定
- CLKSEL_PLLSEL =1; //总线时钟来源于PLL
- void init_pwm(void)
- PWMCTL_CON01= 1; //级联0号和1号通道形成16位PWM通道号,由PWM1输出
- PWMPOL_PPOL1= 1; //通道01的极性为高电平有效
- PWMPRCLK = 0x55; //A时钟和B时钟的分频系数为32,频率为1MHz
- PWMSCLA = 25; //SA时钟设置寄存器
- //CLOCK SA=CLOCK A/(2*PWMSCLA)
- //CLOCK SA=1M/2*25=20KHz
- PWMCLK =0x02; //通道01用SA时钟作为时钟源
- PWMPER01 = 200; //通道01的周期为100Hz
- PWMDTY01 = 0; //通道01的占空比为0%
- PWME_PWME1 = 1; //使能通道01
- void delay(void)
- unsigned int i,j;
- for(i=0;i<20;i++)
- for(j=0;j<50000;j++);
- void main(void) {
- DisableInterrupts; //禁止所有中断打开
- INIT_PLL(); //初始化PLL模块
- init_pwm(); //初始化pwm模块
- LEDCPU_dir=1; //设置连接发光二级管的PORTB_PB0口为输出口
- LEDCPU=1; //初始化发光二极管为亮
- EnableInterrupts; //允许所有中断打开
- for(;;)
- delay();
- PWMDTY01=20; //占空比为10%
- delay();
- PWMDTY01=40; //占空比为20%
- delay();
- PWMDTY01=60; //占空比为30%
- delay();
- PWMDTY01=80; //占空比为40%
- delay();
- PWMDTY01=100; //占空比为50%
- delay();
- PWMDTY01=120; //占空比为60%
- delay();
- PWMDTY01=140; //占空比为70%
- delay();
- PWMDTY01=160; //占空比为80%
- delay();
- PWMDTY01=180; //占空比为90%
- delay();
- PWMDTY01=200; //占空比为100%
- delay();
- delay();
- delay();
- delay();
- delay();
- delay();
- delay();
- delay();
