[DemoCode下载] M0518的串口红外模式
776|10
 楼主| heisexingqisi 发表于 2020-1-31 19:43 | 显示全部楼层 |阅读模式
  1. /****************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * $Revision: 2 $
  5. * $Date: 14/12/25 10:24a $
  6. * @brief
  7. *           Transmit and receive data in UART IrDA mode.
  8. *           This sample code needs to work with UART_IrDA_Slave.
  9. * @note
  10. * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
  11. *
  12. ******************************************************************************/
  13. #include <stdio.h>
  14. #include "M0518.h"
  15. #define PLL_CLOCK   50000000
  16. /*---------------------------------------------------------------------------------------------------------*/
  17. /* Define functions prototype        */
  18. /*---------------------------------------------------------------------------------------------------------*/
  19. extern char GetChar(void);
  20. int32_t main(void);
  21. void IrDA_FunctionTxTest(void);
  22. /*---------------------------------------------------------------------------------------------------------*/
  23. /*  IrDA Function Transmit Test        */
  24. /*---------------------------------------------------------------------------------------------------------*/
  25. void IrDA_FunctionTxTest()
  26. {
  27.     uint8_t u8OutChar;
  28.     printf("\n");
  29.     printf("+-----------------------------------------------------------+\n");
  30.     printf("|     Pin Configure                                         |\n");
  31.     printf("+-----------------------------------------------------------+\n");
  32.     printf("|  ______                                          _______  |\n");
  33.     printf("| |      |                                        |       | |\n");
  34.     printf("| |Master|--UART1_TXD(PB.5) <==> UART1_RXD(PB.4)--|Slave  | |\n");
  35.     printf("| |      |                                        |       | |\n");
  36.     printf("| |______|                                        |_______| |\n");
  37.     printf("|                                                           |\n");
  38.     printf("+-----------------------------------------------------------+\n");
  39.     printf("\n");
  40.     printf("+-----------------------------------------------------------+\n");
  41.     printf("|     IrDA Function Test                                    |\n");
  42.     printf("+-----------------------------------------------------------+\n");
  43.     printf("|  Description :                                            |\n");
  44.     printf("|    The sample code needs two boards. One is Master and    |\n");
  45.     printf("|    the other is slave.  Master will send data based on    |\n");
  46.     printf("|    terminal input and Slave will printf received data on  |\n");
  47.     printf("|    terminal screen.                                       |\n");
  48.     printf("+-----------------------------------------------------------+\n");
  49.     /*
  50.         UART0 is set to debug port and connect with PC firstly.
  51.         The IrDA sample code needs two module board to execute.
  52.         Set the master board is IrDA TX Mode and the other is IrDA Rx mode.
  53.         Inputting char on terminal will be sent to the UART0 of master.
  54.         After the master receiving, the inputting char will send to UART0 again.
  55.         At the same time, it also sends to UART1 TX pin by IrDA mode.
  56.         Slave will print received char after UART1 send out.
  57.         Note that IrDA mode is ONLY used when baud rate equation is selected mode 0.
  58.     */
  59.     printf("\n");
  60.     printf("+-----------------------------------------------------------+\n");
  61.     printf("|     IrDA Function Mode Test (Master)                      |\n");
  62.     printf("+-----------------------------------------------------------+\n");
  63.     printf("| 1). Input char by UART0 terminal.                         |\n");
  64.     printf("| 2). UART1 will send a char according to step 1.           |\n");
  65.     printf("| 3). Return step 1. (Press '0' to exit)                    |\n");
  66.     printf("+-----------------------------------------------------------+\n");
  67.     printf("\nIrDA Sample Code Start. \n");
  68.     /* Set IrDA Tx Mode, Baud Rate configuration must be used MODE0 */
  69.     UART_SelectIrDAMode(UART1, 57600, UART_IRCR_TX_SELECT);
  70.     /* Wait Terminal input to send data to UART1 TX pin */
  71.     do
  72.     {
  73.         u8OutChar = GetChar();
  74.         printf("   Input: %c , Send %c out\n", u8OutChar, u8OutChar);
  75.         UART_WRITE(UART1, u8OutChar);
  76.     }
  77.     while(u8OutChar != '0');
  78.     printf("\nIrDA Sample Code End.\n");
  79. }
  80. void SYS_Init(void)
  81. {
  82.     /*---------------------------------------------------------------------------------------------------------*/
  83.     /* Init System Clock        */
  84.     /*---------------------------------------------------------------------------------------------------------*/
  85.     /* Enable Internal RC 22.1184MHz clock */
  86.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  87.     /* Waiting for Internal RC clock ready */
  88.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  89.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  90.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  91.     /* Enable external XTAL 12MHz clock */
  92.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  93.     /* Waiting for external XTAL clock ready */
  94.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  95.     /* Set core clock as PLL_CLOCK from PLL */
  96.     CLK_SetCoreClock(PLL_CLOCK);
  97.     /* Enable UART module clock */
  98.     CLK_EnableModuleClock(UART0_MODULE);
  99.     CLK_EnableModuleClock(UART1_MODULE);
  100.     /* Select UART module clock source */
  101.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  102.     CLK_SetModuleClock(UART1_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  103.     /*---------------------------------------------------------------------------------------------------------*/
  104.     /* Init I/O Multi-function        */
  105.     /*---------------------------------------------------------------------------------------------------------*/
  106.     /* Set GPB multi-function pins for UART0 RXD(PB.0) and TXD(PB.1) */
  107.     /* Set GPB multi-function pins for UART1 RXD(PB.4) and TXD(PB.5) */
  108.     SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk |
  109.                       SYS_GPB_MFP_PB4_Msk | SYS_GPB_MFP_PB5_Msk);
  110.     SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD |
  111.                      SYS_GPB_MFP_PB4_UART1_RXD | SYS_GPB_MFP_PB5_UART1_TXD);
  112. }
  113. void UART0_Init()
  114. {
  115.     /*---------------------------------------------------------------------------------------------------------*/
  116.     /* Init UART        */
  117.     /*---------------------------------------------------------------------------------------------------------*/
  118.     /* Reset UART0 module */
  119.     SYS_ResetModule(UART0_RST);
  120.     /* Configure UART0 and set UART0 Baudrate */
  121.     UART_Open(UART0, 115200);
  122. }
  123. void UART1_Init()
  124. {
  125.     /*---------------------------------------------------------------------------------------------------------*/
  126.     /* Init UART        */
  127.     /*---------------------------------------------------------------------------------------------------------*/
  128.     /* Reset UART1 module */
  129.     SYS_ResetModule(UART1_RST);
  130.     /* Configure UART1 and set UART1 Baudrate */
  131.     UART_Open(UART1, 115200);
  132. }
  133. /*---------------------------------------------------------------------------------------------------------*/
  134. /* MAIN function        */
  135. /*---------------------------------------------------------------------------------------------------------*/
  136. int main(void)
  137. {
  138.     /* Unlock protected registers */
  139.     SYS_UnlockReg();
  140.     /* Init System, peripheral clock and multi-function I/O */
  141.     SYS_Init();
  142.     /* Lock protected registers */
  143.     SYS_LockReg();
  144.     /* Init UART0 for printf */
  145.     UART0_Init();
  146.     /* Init UART1 for testing */
  147.     UART1_Init();
  148.     /*---------------------------------------------------------------------------------------------------------*/
  149.     /* SAMPLE CODE        */
  150.     /*---------------------------------------------------------------------------------------------------------*/
  151.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
  152.     printf("\n\nUART Sample Program\n");
  153.     /* UART sample IrDA Master function */
  154.     IrDA_FunctionTxTest();
  155.     while(1);
  156. }
 楼主| heisexingqisi 发表于 2020-1-31 19:44 | 显示全部楼层
  2. * @file     main.c
  3. * @version  V3.00
  4. * $Revision: 2 $
  6. * @brief
  8. *           This sample code needs to work with UART_IrDA_Master.
  9. * @note
  11. *
  21. void IrDA_FunctionRxTest(void);
  23. /*  IrDA Function Receive Test        */
  25. void IrDA_FunctionRxTest()
  26. {
  27.     uint8_t u8InChar = 0xFF;
  28.     printf("\n");
  39.     printf("\n");
  49.     /*
  58.     */
  59.     printf("\n");
  61.     printf("|     IrDA Function Mode Test (Slave)                       |\n");
  63.     printf("| 1). Polling RDA_Flag to check data input though UART1     |\n");
  64.     printf("| 2). If received data is '0', the program will exit.       |\n");
  65.     printf("|     Otherwise, print received data on terminal            |\n");
  66.     printf("+-----------------------------------------------------------+\n\n");
  67.     /* Set IrDA Rx Mode, Baud Rate configuration must be used MODE0 */
  68.     UART_SelectIrDAMode(UART1, 57600, UART_IRCR_RX_SELECT);
  69.     /* Reset Rx FIFO */
  70.     UART1->FCR |= UART_FCR_RFR_Msk;
  71.     while(UART1->FCR & UART_FCR_RFR_Msk);
  72.     printf("Waiting...\n");
  73.     /* Use polling method to wait master data */
  74.     do
  75.     {
  76.         if(UART_IS_RX_READY(UART1))
  77.         {
  78.             u8InChar = UART_READ(UART1);
  79.             printf("   Input: %c \n", u8InChar);
  80.         }
  81.     }
  82.     while(u8InChar != '0');
  83. }
  84. void SYS_Init(void)
  85. {
  86.     /*---------------------------------------------------------------------------------------------------------*/
  87.     /* Init System Clock        */
  88.     /*---------------------------------------------------------------------------------------------------------*/
  89.     /* Enable Internal RC 22.1184MHz clock */
  90.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  91.     /* Waiting for Internal RC clock ready */
  92.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  93.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  94.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  95.     /* Enable external XTAL 12MHz clock */
  96.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  97.     /* Waiting for external XTAL clock ready */
  98.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  99.     /* Set core clock as PLL_CLOCK from PLL */
  100.     CLK_SetCoreClock(PLL_CLOCK);
  101.     /* Enable UART module clock */
  102.     CLK_EnableModuleClock(UART0_MODULE);
  103.     CLK_EnableModuleClock(UART1_MODULE);
  104.     /* Select UART module clock source */
  105.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  106.     CLK_SetModuleClock(UART1_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  107.     /*---------------------------------------------------------------------------------------------------------*/
  108.     /* Init I/O Multi-function        */
  109.     /*---------------------------------------------------------------------------------------------------------*/
  110.     /* Set GPB multi-function pins for UART0 RXD(PB.0) and TXD(PB.1) */
  111.     /* Set GPB multi-function pins for UART1 RXD(PB.4) and TXD(PB.5) */
  112.     SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk |
  113.                       SYS_GPB_MFP_PB4_Msk | SYS_GPB_MFP_PB5_Msk);
  114.     SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD |
  115.                      SYS_GPB_MFP_PB4_UART1_RXD | SYS_GPB_MFP_PB5_UART1_TXD);
  116. }
  117. void UART0_Init()
  118. {
  119.     /*---------------------------------------------------------------------------------------------------------*/
  120.     /* Init UART        */
  121.     /*---------------------------------------------------------------------------------------------------------*/
  122.     /* Reset UART0 module */
  123.     SYS_ResetModule(UART0_RST);
  124.     /* Configure UART0 and set UART0 Baudrate */
  125.     UART_Open(UART0, 115200);
  126. }
  127. void UART1_Init()
  128. {
  129.     /*---------------------------------------------------------------------------------------------------------*/
  130.     /* Init UART        */
  131.     /*---------------------------------------------------------------------------------------------------------*/
  132.     /* Reset UART1 module */
  133.     SYS_ResetModule(UART1_RST);
  134.     /* Configure UART1 and set UART1 Baudrate */
  135.     UART_Open(UART1, 115200);
  136. }
  137. /*---------------------------------------------------------------------------------------------------------*/
  138. /* MAIN function        */
  139. /*---------------------------------------------------------------------------------------------------------*/
  140. int main(void)
  141. {
  142.     /* Unlock protected registers */
  143.     SYS_UnlockReg();
  144.     /* Init System, peripheral clock and multi-function I/O */
  145.     SYS_Init();
  146.     /* Lock protected registers */
  147.     SYS_LockReg();
  148.     /* Init UART0 for printf */
  149.     UART0_Init();
  150.     /* Init UART1 for testing */
  151.     UART1_Init();
  152.     /*---------------------------------------------------------------------------------------------------------*/
  153.     /* SAMPLE CODE        */
  154.     /*---------------------------------------------------------------------------------------------------------*/
  155.     printf("\n\nCPU @ %dHz\n", SystemCoreClock);
  156.     printf("\n\nUART Sample Program\n");
  157.     /* UART sample IrDA Slave function */
  158.     IrDA_FunctionRxTest();
  159.     while(1);
  160. }
 楼主| heisexingqisi 发表于 2020-1-31 19:47 | 显示全部楼层
这种还是自动调制成38K吗,不太清楚看看手册。
 楼主| heisexingqisi 发表于 2020-1-31 19:50 | 显示全部楼层
IrDA 功能模式(仅UART0支持)
UART0控制器也提供Serial IrDA (SIR, 串行红外)功能(用户必须设置IrDA_EN和 (UART_FUNSEL[1:0]) 为’10’)来使能IrDA功能。SIR规范定义了一个短距离红外异步串行传输模式,包括一个起始位,8个数据 位,一个停止位。最大速率115.2kbps。IrDA SIR模块包含一个IrDA SIR协议编/解码器。IrDA SIR协议是半 双工工作模式。所以它不能同时收发数据。IrDA SIR物理层规定了发送与接收数据的时间上至少10ms的时 间间隔,该延迟特性需通过软件来完成。
IrDA 模式下,寄存器BAUDM1 (UART_BAUD [29])位需被禁止。
波特率= Clock / (16 * BRD),这里BRD是UART_BAUD寄存器中定义的波特率分频器
 楼主| heisexingqisi 发表于 2020-1-31 19:51 | 显示全部楼层
IrDA SIR 接收解码
IrDA SIR 接收解码器对输入管脚的(Return-to-Zero, Inverted (RZI))串行位流进行解调,并输出NRZ 串行位 流到 UART0接收数据输入端。在空闲状态里,解码器输入端通常为高。(因此,RXINV (UART_IRCR[6]) 位默认设为1)。
当解码器输入端为低时,表明接收到一个起始位。
 楼主| heisexingqisi 发表于 2020-1-31 19:52 | 显示全部楼层
用的好像不是38K
xinxianshi 发表于 2020-1-31 19:56 | 显示全部楼层
printf默认就是使用的串口0
所以正常初始化串口1后就可以配置为红外发射了。
xinxianshi 发表于 2020-1-31 19:57 | 显示全部楼层
这个操作就简单了,先选择为红外发射功能,然后直接当串口用就行了。
xinxianshi 发表于 2020-1-31 19:59 | 显示全部楼层
接收操作也是如此,设置完模式,当串口操作就可以了。
这比IO模拟好用多了。
