[技术问答] N76E003 Timer0/1 Mode2 demo code
644|7
 楼主| darklighttt 发表于 2020-3-30 19:38 | 显示全部楼层 |阅读模式
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*        */
  3. /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
  4. /*        */
  5. /*---------------------------------------------------------------------------------------------------------*/
  6. //***********************************************************************************************************
  7. //  Nuvoton Technoledge Corp.
  8. //  Website: http://www.nuvoton.com
  9. //  E-Mail : MicroC-8bit@nuvoton.com
  10. //  Date   : Apr/21/2017
  11. //***********************************************************************************************************
  12. //***********************************************************************************************************
  13. //  File Function: N76E003 Timer0/1 Mode2 demo code
  14. //***********************************************************************************************************
  15. #include "N76E003.h"
  16. #include "Common.h"
  17. #include "Delay.h"
  18. #include "SFR_Macro.h"
  19. #include "Function_define.h"
  20. //*****************  The Following is in define in Fucntion_define.h  ***************************
  21. //****** Always include Function_define.h call the define you want, detail see main(void) *******
  22. //***********************************************************************************************
  23. #if 0
  24. //#define                TIMER0_MODE0_ENABLE                TMOD&=0x0F
  25. //#define                TIMER0_MODE1_ENABLE                TMOD&=0x0F;TMOD|=0x10
  26. //#define                TIMER0_MODE2_ENABLE                TMOD&=0x0F;TMOD|=0x20
  27. //#define                TIMER0_MODE3_ENABLE                TMOD&=0x0F;TMOD|=0x3F
  28. //#define                TIMER1_MODE0_ENABLE                TMOD&=0xF0
  29. //#define                TIMER1_MODE1_ENABLE                TMOD&=0xF0;TMOD|=0x01
  30. //#define                TIMER1_MODE2_ENABLE                TMOD&=0xF0;TMOD|=0x02
  31. //#define                TIMER1_MODE3_ENABLE                TMOD&=0xF0;TMOD|=0xF3
  32. #endif
  33. #if 1
  34.     #define TIMER0_RELOAD_VALUE     50
  35.     #define TIMER1_RELOAD_VALUE     50
  36. #else
  37.     #define TIMER0_RELOAD_VALUE     250
  38.     #define TIMER1_RELOAD_VALUE     250
  39. #endif
  40. /************************************************************************************************************
  41. *    TIMER 0 interrupt subroutine
  42. ************************************************************************************************************/
  43. void Timer0_ISR (void) interrupt 1              //interrupt address is 0x000B
  44. {
  45.     P12 = ~P12;                                 // GPIO1 toggle when interrupt
  46. }
  47. /************************************************************************************************************
  48. *    TIMER 1 interrupt subroutine
  49. ************************************************************************************************************/
  50. void Timer1_ISR (void) interrupt 3              //interrupt address is 0x001B
  51. {
  52.     P03 = ~P03;                                 //P0.3 toggle when interrupt
  53. }
  54. /************************************************************************************************************
  55. *    Main function
  56. ************************************************************************************************************/
  57. void main (void)
  58. {
  59.     Set_All_GPIO_Quasi_Mode;
  60.                 TIMER0_MODE2_ENABLE;
  61.                 TIMER1_MODE2_ENABLE;
  62.
  63.     TH0 = (256-TIMER0_RELOAD_VALUE);            //initial counter values
  64.     TL0 = (256-TIMER0_RELOAD_VALUE);
  65.     TH1 = (256-TIMER1_RELOAD_VALUE);
  66.     TL1 = (256-TIMER1_RELOAD_VALUE);
  67.
  68.     set_ET0;                                    //enable Timer0 interrupt
  69.     set_ET1;                                    //enable Timer1 interrupt
  70.     set_EA;                                     //enable interrupts
  71.     set_TR0;                                    //Timer0 run
  72.     set_TR1;                                    //Timer1 run
  73.     while(1);
  74. }
jiekou001 发表于 2020-3-30 23:19 | 显示全部楼层
两个定时器同时操作,牛
模式二自动重载,666
八层楼 发表于 2020-4-6 15:57 | 显示全部楼层
非常感谢楼主分享
观海 发表于 2020-4-6 15:58 | 显示全部楼层
非常感谢楼主分享
guanjiaer 发表于 2020-4-6 15:58 | 显示全部楼层
非常感谢楼主分享
heimaojingzhang 发表于 2020-4-6 15:58 | 显示全部楼层
非常感谢楼主分享
keaibukelian 发表于 2020-4-6 15:58 | 显示全部楼层
非常感谢楼主分享
