DMA内存发往串口实验
#include"stm32f10x.h"
#define SENDBUFF_SIZE 5000 //内存块大小
int main(void)
volatile unsigned int x;//延时计数
uint16_t i;//填充计数
uint8_t SendBuff[SENDBUFF_SIZE];//用数组开内存数据区
GPIO_InitTypeDef GPIO_InitStructure;//端口结构体
USART_InitTypeDef USART_InitStructure;//串口结构体
DMA_InitTypeDef DMA_InitStructure;//DMA结构体
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_USART1,ENABLE);//开AB端口串口时钟
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);//开DMA1时钟(注意:是AHB)
//GPIOA9串口输出
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;//复位推挽输出
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9 ;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure);
//GPIOA10串口输入
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;//浮空输入
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;
//B口0脚led输出
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;//推挽输出
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0 ;
GPIO_Init(GPIOB,&GPIO_InitStructure);
//串口设置
USART_InitStructure.USART_BaudRate=115200;//波特率
USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;//硬件流
USART_InitStructure.USART_Mode= USART_Mode_Rx | USART_Mode_Tx;//模式
USART_InitStructure.USART_Parity=USART_Parity_No;//非奇偶校验
USART_InitStructure.USART_StopBits=USART_StopBits_1;//1位停止位
USART_InitStructure.USART_WordLength=USART_WordLength_8b;//8位数据位
USART_Init(USART1,&USART_InitStructure);//串口初始化
USART_Cmd(USART1,ENABLE);//串口使能
//DMA设置
DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_BASE+0x04;//串口地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SendBuff;//内存数据地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;//内存发到外设
DMA_InitStructure.DMA_BufferSize = SENDBUFF_SIZE;//传输数据数量
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设不增址
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;//内存自动增址
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;//外设数据宽度
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;//内存数据宽度
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;//单次发送
//DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//循环发送
DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;//中等优先级
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;//禁止内存到内存传送
DMA_Init(DMA1_Channel4, &DMA_InitStructure);//配置DMA通道
DMA_Cmd (DMA1_Channel4,ENABLE);//打开DMA通道
for(i=0;i<SENDBUFF_SIZE;i++) //内存数据生成
SendBuff = 'A';//内存数据填充
USART_DMACmd( USART1, USART_DMAReq_Tx, ENABLE);//请求发送
while(1)
if (GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_0)) //检测led电平
GPIO_ResetBits(GPIOB,GPIO_Pin_0);//开灯
else GPIO_SetBits(GPIOB,GPIO_Pin_0);//关灯
for(x=0;x<0xfffff;x++);//延时
