这个是我自己 已跑过的程序 就是显示灰度不均匀 不知道是驱动的问题还是 液晶显示屏的问题
void LCD_GLASS_Init(void)//ÅäÖÃLCDÇý¶¯
LCD_InitTypeDef LCD_InitStructure;
RCC_Config();//ʱÖÓÅäÖÃ
LCD_GPIOConfig(); /*!< Configure the LCD Glass GPIO pins */
/*!< Configure the LCD interface -------------------------------------------*/
RCC_APB1PeriphClockCmd(RCC_APB1Periph_LCD, ENABLE); /*!< Enable LCD APB1 Clock */
LCD_InitStructure.LCD_Prescaler = LCD_Prescaler_512;
LCD_InitStructure.LCD_Divider = LCD_Divider_16;
LCD_InitStructure.LCD_Duty = LCD_Duty_1_4;
LCD_InitStructure.LCD_Bias = LCD_Bias_1_3;
LCD_InitStructure.LCD_VoltageSource = LCD_VoltageSource_External;//LCD_VoltageSource_Internal;//
//LCD_StructInit(&LCD_InitStructure);
LCD_Init(&LCD_InitStructure);
//LCD_MuxSegmentCmd(DISABLE);
/*!< Configure the Pulse On Duration */
LCD_PulseOnDurationConfig(LCD_PulseOnDuration_7);
LCD_DeadTimeConfig(LCD_DeadTime_1);
//LCD_HighDriveCmd(ENABLE);
/*!< Configure the LCD Contrast (3.51V) */
LCD_ContrastConfig(LCD_Contrast_Level_5);
/*!< Wait Until the LCD FCR register is synchronized */
LCD_WaitForSynchro();
/*!< Enable LCD peripheral */
LCD_Cmd(ENABLE);
/*!< Wait Until the LCD is enabled */
while(LCD_GetFlagStatus(LCD_FLAG_ENS) == RESET)
/*!< Wait Until the LCD Booster is ready */
while(LCD_GetFlagStatus(LCD_FLAG_RDY) == RESET)
void LCD_GPIOConfig(void)
/*!< Enable GPIOA, GPIOB, GPIOC, GPIOD and GPIOE AHB Clocks */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOB | RCC_AHBPeriph_GPIOC
| RCC_AHBPeriph_GPIOD | RCC_AHBPeriph_GPIOE, ENABLE);
/*!< Connect PA.06 to LCD SEG3 */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_LCD);
/*!< Connect PA.07 to LCD SEG4 */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_LCD);
/*!< Connect PA.08 to LCD COM0 */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_LCD);
/*!< Connect PA.09 to LCD COM1 */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_LCD);
/*!< Connect PA.10 to LCD COM2 */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_LCD);
/*!< Connect PB.09 to LCD COM3 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_LCD);
/*!< Connect PC.10 to LCD COM4 */
//GPIO_PinAFConfig(GPIOC, GPIO_PinSource10, GPIO_AF_LCD);
/*!< Connect PC.11 to LCD COM5 */
//GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_LCD);
/*!< Connect PC.12 to LCD COM6 */
//GPIO_PinAFConfig(GPIOC, GPIO_PinSource12, GPIO_AF_LCD);
/*!< Connect PD.2 to LCD COM7 */
//GPIO_PinAFConfig(GPIOD, GPIO_PinSource2, GPIO_AF_LCD);
#ifndef SimulationEn
/*!< Connect PA.15 to LCD SEG17 */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource15, GPIO_AF_LCD);//¹²ÓÃJTDI
#endif
/*!< Connect PB.00 to LCD SEG5 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource0, GPIO_AF_LCD);
/*!< Connect PB.01 to LCD SEG6 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_LCD);
/*!< Connect PB.03 to LCD SEG7 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_LCD);//¹²ÓÃJTDO
/*!< Connect PB.04 to LCD SEG8 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_LCD);//¹²ÓÃJRST
#endif
/*!< Connect PB.05 to LCD SEG9 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_LCD);
/*!< Connect PB.08 to LCD SEG16 */
/*!< Connect PB.10 to LCD SEG10 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_LCD);
/*!< Connect PB.11 to LCD SEG11 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_LCD);
/*!< Connect PB.12 to LCD SEG12 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_LCD);
/*!< Connect PB.13 to LCD SEG13 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_LCD);
/*!< Connect PB.14 to LCD SEG14*/
GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_LCD);
/*!< Connect PB.15 to LCD SEG15 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_LCD);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_LCD);
/*!< Connect PC.00 to LCD SEG18 */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource0, GPIO_AF_LCD);
/*!< Connect PC.01 to LCD SEG19 */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_LCD);
/*!< Connect PC.02 to LCD SEG20 */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource2, GPIO_AF_LCD);
/*!< Connect PC.03 to LCD SEG21 */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource3, GPIO_AF_LCD);
/*!< Connect PC.04 to LCD SEG22 */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_LCD);
/*!< Connect PC.05 to LCD SEG23 */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource5, GPIO_AF_LCD);
/*!< Connect PC.06 to LCD SEG24 */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_LCD);
/*!< Connect PC.07 to LCD SEG25 */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_LCD);
/*!< Connect PC.08 to LCD SEG26 */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_LCD);
/*!< Connect PC.09 to LCD SEG27 */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource9, GPIO_AF_LCD);
/*!< Connect PC.10 to LCD SEG40 */
/*!< Connect PC.11 to LCD SEG41 */
/*!< Connect PC.12 to LCD SEG42 */
/*!< Connect PD.01 to LCD SEG43 */
/*!< Connect PD.08 to LCD SEG28 */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_LCD);
/*!< Connect PD.09 to LCD SEG29 */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_LCD);
/*!< Connect PD.10 to LCD SEG30 */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_LCD);
/*!< Connect PD.11 to LCD SEG31 */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource11, GPIO_AF_LCD);
/*!< Connect PD.12 to LCD SEG32 */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_LCD);
/*!< Connect PD.13 to LCD SEG33 */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource13, GPIO_AF_LCD);
/*!< Connect PD.14 to LCD SEG34 */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_LCD);
/*!< Connect PD.15 to LCD SEG35 */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_LCD);
/*!< Connect PD.02 to LCD SEG38 */
GPIO_PinAFConfig(GPIOE, GPIO_PinSource2, GPIO_AF_LCD);
/*!< Connect PD.03 to LCD SEG39 */
GPIO_PinAFConfig(GPIOE, GPIO_PinSource3, GPIO_AF_LCD);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 |GPIO_Pin_5 | GPIO_Pin_8 | GPIO_Pin_9 | \
GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | \
GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_10 | GPIO_Pin_11 | \
GPIO_Pin_12;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 ;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_15;//Õý³£ÓÃ
#else
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;//·ÂÕæÓÃ
#endif
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_8 | GPIO_Pin_9 |\
GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_11 | GPIO_Pin_12 |\
GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; //
#else
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_5 | GPIO_Pin_8 | GPIO_Pin_9 |\
GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;//·ÂÕæÓÃ
#endif
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 |\
GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | \
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
GPIO_Init(GPIOE, &GPIO_InitStructure);
