[其它应用] 【疑惑】keil下没有JET51A可选
2130|8
 楼主| Frozen丶 发表于 2020-5-28 08:16 | 显示全部楼层 |阅读模式
从中颖电子新官网找到最新插件安装后 keil中没有显示JET51A 图中左边为我的keil 右边为教程视频
JustU 发表于 2020-5-28 09:37 | 显示全部楼层
你加我Q1327041601,我发你个老版插件试下
 楼主| Frozen丶 发表于 2020-5-28 11:45 | 显示全部楼层
可以了 我找了个1.6版的 出来JET51A了 谢谢了
 楼主| Frozen丶 发表于 2020-5-29 16:03 | 显示全部楼层
SH79M083B遇到这种问题 怎么解决
 楼主| Frozen丶 发表于 2020-5-29 16:38 | 显示全部楼层
#include "SH79M083B.h"
sbit LED1=P4^2;
sbit LED2=P4^1;
sbit LED3=P1^3;
sbit LED4=P1^7;
sbit LED5=P1^6;
sbit LED6=P1^5;
sbit LED7=P1^4;
sbit LED8=P1^1;
sbit LED9=P1^0;
void main()
LED1=1;
LED2=1;
LED3=1;
LED4=1;
LED5=1;
LED6=1;
LED7=1;
LED8=1;
LED9=1;
 楼主| Frozen丶 发表于 2020-5-29 16:39 | 显示全部楼层
$NOMOD51
;  This file is part of the C51 Compiler package
;  Copyright (c) 1988-2005 Keil Elektronik GmbH and Keil Software, Inc.
;  Version 8.01
;  *** <<< Use Configuration Wizard in Context Menu >>> ***
;  STARTUP.A51:  This code is executed after processor reset.
;  To translate this file use A51 with the following invocation:
;     A51 STARTUP.A51
;  To link the modified STARTUP.OBJ file to your application use the following
;  Lx51 invocation:
;     Lx51 your object file list, STARTUP.OBJ  controls
;  User-defined <h> Power-On Initialization of Memory
;  With the following EQU statements the initialization of memory
;  at processor reset can be defined:
; <o> IDATALEN: IDATA memory size <0x0-0x100>
;     <i> Note: The absolute start-address of IDATA memory is always 0
;     <i>       The IDATA space overlaps physically the DATA and BIT areas.
IDATALEN        EQU     80H
; <o> XDATASTART: XDATA memory start address <0x0-0xFFFF>
;     <i> The absolute start address of XDATA memory
XDATASTART      EQU     0
; <o> XDATALEN: XDATA memory size <0x0-0xFFFF>
;     <i> The length of XDATA memory in bytes.
XDATALEN        EQU     0
; <o> PDATASTART: PDATA memory start address <0x0-0xFFFF>
;     <i> The absolute start address of PDATA memory
PDATASTART      EQU     0H
; <o> PDATALEN: PDATA memory size <0x0-0xFF>
;     <i> The length of PDATA memory in bytes.
PDATALEN        EQU     0H
;</h>
;<h> Reentrant Stack Initialization
;  The following EQU statements define the stack pointer for reentrant
;  functions and initialized it:
; <h> Stack Space for reentrant functions in the SMALL model.
;  <q> IBPSTACK: Enable SMALL model reentrant stack
;     <i> Stack space for reentrant functions in the SMALL model.
IBPSTACK        EQU     0       ; set to 1 if small reentrant is used.
;  <o> IBPSTACKTOP: End address of SMALL model stack <0x0-0xFF>
;     <i> Set the top of the stack to the highest location.
IBPSTACKTOP     EQU     0xFF +1     ; default 0FFH+1
; </h>
; <h> Stack Space for reentrant functions in the LARGE model.
;  <q> XBPSTACK: Enable LARGE model reentrant stack
;     <i> Stack space for reentrant functions in the LARGE model.
XBPSTACK        EQU     0       ; set to 1 if large reentrant is used.
;  <o> XBPSTACKTOP: End address of LARGE model stack <0x0-0xFFFF>
XBPSTACKTOP     EQU     0xFFFF +1   ; default 0FFFFH+1
; </h>
; <h> Stack Space for reentrant functions in the COMPACT model.
;  <q> PBPSTACK: Enable COMPACT model reentrant stack
;     <i> Stack space for reentrant functions in the COMPACT model.
PBPSTACK        EQU     0       ; set to 1 if compact reentrant is used.
;   <o> PBPSTACKTOP: End address of COMPACT model stack <0x0-0xFFFF>
PBPSTACKTOP     EQU     0xFF +1     ; default 0FFH+1
; </h>
;</h>
;  Memory Page for Using the Compact Model with 64 KByte xdata RAM
;  <e>Compact Model Page Definition
;  <i>Define the XDATA page used for PDATA variables.
;  <i>PPAGE must conform with the PPAGE set in the linker invocation.
; Enable pdata memory page initalization
PPAGEENABLE     EQU     0       ; set to 1 if pdata object are used.
; <o> PPAGE number <0x0-0xFF>
; <i> uppermost 256-byte address of the page used for PDATA variables.
PPAGE           EQU     0
; <o> SFR address which supplies uppermost address byte <0x0-0xFF>
; <i> most 8051 variants use P2 as uppermost address byte
PPAGE_SFR       DATA    0A0H
; </e>
; Standard SFR Symbols
ACC     DATA    0E0H
B       DATA    0F0H
SP      DATA    81H
DPL     DATA    82H
DPH     DATA    83H
                NAME    ?C_STARTUP
?C_C51STARTUP   SEGMENT   CODE
?STACK          SEGMENT   IDATA
                RSEG    ?STACK
                DS      1
                EXTRN CODE (?C_START)
                PUBLIC  ?C_STARTUP
                CSEG    AT      0
?C_STARTUP:     LJMP    STARTUP1
                RSEG    ?C_C51STARTUP
STARTUP1:
IF IDATALEN <> 0
                MOV     R0,#IDATALEN - 1
                CLR     A
IDATALOOP:      MOV     @R0,A
                DJNZ    R0,IDATALOOP
ENDIF
IF XDATALEN <> 0
                MOV     DPTR,#XDATASTART
                MOV     R7,#LOW (XDATALEN)
  IF (LOW (XDATALEN)) <> 0
                MOV     R6,#(HIGH (XDATALEN)) +1
  ELSE
                MOV     R6,#HIGH (XDATALEN)
  ENDIF
                CLR     A
XDATALOOP:      MOVX    @DPTR,A
                INC     DPTR
                DJNZ    R7,XDATALOOP
                DJNZ    R6,XDATALOOP
ENDIF
IF PPAGEENABLE <> 0
                MOV     PPAGE_SFR,#PPAGE
ENDIF
IF PDATALEN <> 0
                MOV     R0,#LOW (PDATASTART)
                MOV     R7,#LOW (PDATALEN)
                CLR     A
PDATALOOP:      MOVX    @R0,A
                INC     R0
                DJNZ    R7,PDATALOOP
ENDIF
IF IBPSTACK <> 0
EXTRN DATA (?C_IBP)
                MOV     ?C_IBP,#LOW IBPSTACKTOP
ENDIF
IF XBPSTACK <> 0
EXTRN DATA (?C_XBP)
                MOV     ?C_XBP,#HIGH XBPSTACKTOP
                MOV     ?C_XBP+1,#LOW XBPSTACKTOP
ENDIF
IF PBPSTACK <> 0
EXTRN DATA (?C_PBP)
                MOV     ?C_PBP,#LOW PBPSTACKTOP
ENDIF
                MOV     SP,#?STACK-1
; This code is required if you use L51_BANK.A51 with Banking Mode 4
;<h> Code Banking
; <q> Select Bank 0 for L51_BANK.A51 Mode 4
#if 0
;     <i> Initialize bank mechanism to code bank 0 when using L51_BANK.A51 with Banking Mode 4.
EXTRN CODE (?B_SWITCH0)
                CALL    ?B_SWITCH0      ; init bank mechanism to code bank 0
#endif
;</h>
                LJMP    ?C_START
                END
robin1024 发表于 2020-7-11 17:49 | 显示全部楼层
我也遇到你这种情况,用KEIL打开就找不到JET51A,但用ProWrite打开是能够自动识别到JET51A的,因此确认JET51A是好的,问题出在KEIL。后来演讲打开KEIL的时候用右键,选择“以管理员身份运行”,问题就解决了。
duo2182 发表于 2020-9-5 11:27 | 显示全部楼层
我也遇到这个问题,可以把1.6版本发上来吗?或者给个下载联接
自己造声卡 发表于 2020-9-6 07:52 | 显示全部楼层
我是一个新手,期待和大家一起学习,一起进步,谢谢。谢谢楼主分享.
