请教LWIP DHCP使用
760|0
 楼主| 哈金 发表于 2018-7-4 16:54 | 显示全部楼层 |阅读模式
我把STM32做成了CLIENT,使用的预先指定静态IP,这样做有些不方便。所以想用自动分配IP,想知道除了在lwipopts.h中#define LWIP_DHCP 1
#define LWIP_ARP  1
和将dhcp.h包含进相关的源文件里,还需要做其它的什么吗。DHCP是UDP协议工作的,是不是要用UDP才行。
void LwIP_Init( void )
  struct ip_addr ipaddr;
  struct ip_addr netmask;
  struct ip_addr gw;
   /*调用LWIP初始化函数,
   初始化网络接口结构体链表、内存池、pbuf结构体,启动协议栈管理进程*/
   lwip_init();
#if LWIP_DHCP
  ipaddr.addr = 0;
  netmask.addr = 0;
  gw.addr = 0;
#else
  IP4_ADDR(&ipaddr, 192, 168, 0, 16);                  //设置网络接口的ip地址
  IP4_ADDR(&netmask, 255, 255, 255, 0);                //子网掩码
  IP4_ADDR(&gw, 192, 168, 0, 1);  //网关
#endif
  netif_add(&enc28j60, &ipaddr, &netmask, &gw, NULL, eernetif_init, eernet_input);
  netif_set_default(&enc28j60);
#if LWIP_DHCP                                   //若使用了DHCP
  dhcp_start(&enc28j60);           //启动DHCP
#endif
  netif_set_up(&enc28j60); //使能enc28j60接口
void tcp_client_init(void)
        struct tcp_pcb* client_pcb;
        struct tcp_client_app_arg* app_arg;
        printf("tcp client inti
        destip.addr = (uint32_t)192+(168<<8)+(0<<16)+(105<<24);
        client_pcb = tcp_new();
        if(client_pcb != NULL)
                tcp_arg(client_pcb, mem_calloc(sizeof(struct tcp_client_app_arg), 1));
                app_arg = client_pcb->callback_arg;
                app_arg->app_state = CLIENT_WAITING_FOR_CONNECTION;
                tcp_connect(client_pcb, &destip, 2200, tcp_client_connected);
        else
                printf("tcp alloc failed
void LwIP_Periodic_Handle(__IO uint32_t localtime)
        if(ETH_INT == 1)
                 ETH_INT = 0;
                    /* Read a received packet from the Ethernet buffers and send it to the lwIP for handling */
                IN:        ethernetif_input(&enc28j60);                         //轮询是否接收到数据
        if(GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_2) == RESET) goto IN;
        /* TCP periodic process every 250 ms */
        if (localtime - TCPTimer >= TCP_TMR_INTERVAL)
           TCPTimer =  localtime;
           tcp_tmr();                 //每250ms调用一次
        /* ARP periodic process every 5s */
        if (localtime - ARPTimer >= ARP_TMR_INTERVAL)
           ARPTimer =  localtime;
           etharp_tmr();          //每5s调用一次
#if LWIP_DHCP
          /* Fine DHCP periodic process every 500ms */
          if (localtime - DHCPfineTimer >= DHCP_FINE_TIMER_MSECS)
            DHCPfineTimer =  localtime;
            dhcp_fine_tmr();
          /* DHCP Coarse periodic process every 60s */
          if (localtime - DHCPcoarseTimer >= DHCP_COARSE_TIMER_MSECS)
            DHCPcoarseTimer =  localtime;
            dhcp_coarse_tmr();
#endif
