[STM32] 矩阵键盘的问题
1245|5
 楼主| 比神乐 发表于 2020-7-9 10:49 | 显示全部楼层 |阅读模式
我写了个矩阵键盘的程序,效果不太好。
原理图:
代码:
//初始化PA8和PD2为输出口.并使能这两个口的时钟
//LED IO初始化
void KEY_Init(void)
GPIO_InitTypeDef  GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOE, ENABLE);         //使能PB,PE端口时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;                  //开漏输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度为50MHz
GPIO_Init(GPIOE, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;                  //浮空输入
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
GPIO_Init(GPIOB, &GPIO_InitStructure);
unsigned char GetKey(void)
        unsigned char keyvalue = 0;
        uint16_t hangvalue=0;
        GPIO_ResetBits(GPIOE,GPIO_Pin_6 | GPIO_Pin_5 | GPIO_Pin_4 | GPIO_Pin_3);          //PE.6,5,4,3 输出低
        hangvalue=(GPIO_ReadInputData(GPIOE)&0x07)+((GPIO_ReadInputData(GPIOB)&0x0380)>>4);
        if (hangvalue != 0x3f)        // 读出的不是0x3f说明有按键被按下
                delay_ms(20);                                //延时消抖
                        GPIO_ResetBits(GPIOE,GPIO_Pin_6);                                                  //PE.6输出低
                        GPIO_SetBits(GPIOE,GPIO_Pin_5 | GPIO_Pin_4 | GPIO_Pin_3);
                        hangvalue=(GPIO_ReadInputData(GPIOE)&0x07)+((GPIO_ReadInputData(GPIOB)&0x0300)>>5);
                        //hangvalue=(GPIO_ReadInputData(GPIOE)&0x07)+((GPIO_ReadInputData(GPIOB)&0x0380)>>4);
                        switch (hangvalue)
                                case 0x0F:
        keyvalue=4;
                                        break;
                                case 0x17:
        keyvalue=5;
                                        break;
                                case 0x1b:
        keyvalue=1;
                                        break;
                                case 0x1d:
        keyvalue=2;
                                        break;
                                case 0x1e:
        keyvalue=3;
                                        break;
                                default: break;
                if(keyvalue==0)
                        GPIO_ResetBits(GPIOE, GPIO_Pin_5 );
                        GPIO_SetBits(GPIOE,GPIO_Pin_6 | GPIO_Pin_4 | GPIO_Pin_3);
                        switch (hangvalue)
                                case 0x0F:
        keyvalue=9;
                                        break;
                                case 0x17:
        keyvalue=10;
                                        break;
                                case 0x1b:
        keyvalue=6;
                                        break;
                                case 0x1d:
        keyvalue=7;
                                        break;
                                case 0x1e:
        keyvalue=8;
                                        break;
                                default: break;
        if(keyvalue==0)
                GPIO_ResetBits(GPIOE, GPIO_Pin_4 );
                GPIO_SetBits(GPIOE,GPIO_Pin_6 | GPIO_Pin_3 | GPIO_Pin_5);
                // 第一回合中算出行号
                        switch (hangvalue)
                                case 0x1F:
        keyvalue=14;
                                        break;
                                case 0x2F:
        keyvalue=15;
                                        break;
                                case 0x37:
        keyvalue=16;
                                        break;
                                case 0x3B:
        keyvalue=11;
                                        break;
                                case 0x3D:
        keyvalue=12;
                                        break;
                                case 0x3E:
        keyvalue=13;
                                        break;
                                default: break;
                if(keyvalue==0)
                        GPIO_SetBits(GPIOE,GPIO_Pin_6 | GPIO_Pin_4 | GPIO_Pin_5);
                        GPIO_ResetBits(GPIOE, GPIO_Pin_3 );
                        switch (hangvalue)
                                case 0x1F:
        keyvalue=20;
                                        break;
                                case 0x2F:
        keyvalue=21;
                                        break;
                                case 0x37:
        keyvalue=22;
                                        break;
                                case 0x3B:
        keyvalue=17;
                                        break;
                                case 0x3D:
        keyvalue=18;
                                        break;
                                case 0x3E:
        keyvalue=19;
                                        break;
                                default: break;
                        while (hangvalue != 0x3f)
                        return keyvalue;
                return 0;
        return 0;
有的按键检测不准:
按键1,2,3,4,5,是1,2,3,4,5
按键6,7,8,9,10,是1,2,3,9,10
按键11,12,13,14,15是1,2,3,14,15.
按键16,17,18,19,20是16,1,2,3,20
请问高手,哪里有错?谢谢!
wandersky 发表于 2020-7-9 11:54 | 显示全部楼层
这后面加延迟, delay_ms(1);
应该可以解决
或者把GPIO_Mode_IN_FLOATING浮动输入改为普通输入,应该也行
 楼主| 比神乐 发表于 2020-7-9 13:36 | 显示全部楼层
GPIO ...
谢谢!好了。
不过普通输入是什么意思?上拉输入吗?
ZHMSGE 发表于 2020-7-10 10:19 | 显示全部楼层
用AD口不好吗?
 楼主| 比神乐 发表于 2020-7-10 10:50 | 显示全部楼层
板子已经设计好啦,不过没听说矩阵键盘用AD口的
没说矩阵键盘用AD 口,按键接成分压式,用AD口检测电压  发表于 2020-7-13 09:45
