STM32H7的MPU支持的几个参数,方便以后直接查看配置
419|0
 楼主| 考哥 发表于 2018-8-10 11:38 | 显示全部楼层 |阅读模式
结构体:
#if (__MPU_PRESENT == 1)
/** @defgroup CORTEX_MPU_Region_Initialization_Structure_definition MPU Region Initialization Structure Definition
  * @brief  MPU Region initialization structure
typedef struct
  uint8_t                Enable;                /*!< Specifies the status of the region.
                                                     This parameter can be a value of @ref CORTEX_MPU_Region_Enable                 */
  uint8_t                Number;                /*!< Specifies the number of the region to protect.
                                                     This parameter can be a value of @ref CORTEX_MPU_Region_Number                 */
  uint32_t               BaseAddress;           /*!< Specifies the base address of the region to protect.                           */
  uint8_t                Size;                  /*!< Specifies the size of the region to protect.
                                                     This parameter can be a value of @ref CORTEX_MPU_Region_Size                   */
  uint8_t                SubRegionDisable;      /*!< Specifies the number of the subregion protection to disable.
                                                     This parameter must be a number between Min_Data = 0x00 and Max_Data = 0xFF    */
  uint8_t                TypeExtField;          /*!< Specifies the TEX field level.
                                                     This parameter can be a value of @ref CORTEX_MPU_TEX_Levels                    */
  uint8_t                AccessPermission;      /*!< Specifies the region access permission type.
                                                     This parameter can be a value of @ref CORTEX_MPU_Region_Permission_Attributes  */
  uint8_t                DisableExec;           /*!< Specifies the instruction access status.
                                                     This parameter can be a value of @ref CORTEX_MPU_Instruction_Access            */
  uint8_t                IsShareable;           /*!< Specifies the shareability status of the protected region.
                                                     This parameter can be a value of @ref CORTEX_MPU_Access_Shareable              */
  uint8_t                IsCacheable;           /*!< Specifies the cacheable status of the region protected.
                                                     This parameter can be a value of @ref CORTEX_MPU_Access_Cacheable              */
  uint8_t                IsBufferable;          /*!< Specifies the bufferable status of the protected region.
                                                     This parameter can be a value of @ref CORTEX_MPU_Access_Bufferable             */
}MPU_Region_InitTypeDef;
#endif /* __MPU_PRESENT */
