linux恢复 rm -rf 删除的文件:extundelete
171|0
 楼主| 香菇选手 发表于 2018-9-27 15:16 | 显示全部楼层 |阅读模式
linux, TE, RF, ev, ST
下载
http://extundelete.sourceforge.net/bunzip2 extundelete-0.2.0.tar.bz2tar xvf extundelete-0.2.0.tarcd extundelete-0.2.0makemake install
configure时出现了一个错误:Can't find ext2fs library,解决方法:sudo apt-get install e2fslibs-dev e2fslibs-dev,然后make,make install即可
root@lhbo-desktop:/home/lhbo/Tools/extundelete-0.2.4# df -lFilesystem           1K-blocks      Used Available Use% Mounted on/dev/sda1             79607672  34712108  40851636  46% /none                    508980       252    508728   1% /devnone                    513228       252    512976   1% /dev/shmnone                    513228       112    513116   1% /var/runnone                    513228         0    513228   0% /var/locknone                    513228         0    513228   0% /lib/init/rw
--------------根据inode恢复文件。查看文件inode:ls -i/usr/local/bin/extundelete /dev/sda1 --restore-inode 222
--------------恢复一个被误删除的文件
extundelete /dev/sda1 --restore-file /an/important/file
--------------恢复一个被误删除的文件夹extundelete /dev/sda1 --restore-directory /an/important
例如:
